PDE Heat Equation 2 Dimensions
9 replies · 2K views · last reply
RJLiberator
Show that if v(x,t) and w(y,t) are solutions of the 1-dimensional heat equation (v_t = k*v_xx and w_t = k*w_yy), then u(x,y,t) = v(x,t)w(y,t) satisfies the 2-dimensional heat equation. Can you generalize to 3 dimensions? Is the same result true for solutions of the wave equation?
Honestly, I have no idea what I am doing. This is all very interesting and it SEEMS like it should be answered by a "oh, yes, that's obvious just do this" quick few lines.
But I'm so foreign with my PDE course that this is causing great stress.
I need a start, if you can tell me what I should look at, or where I should start, please do so. I will attack it then.
Step 1: write down the 2D heat equation for a general function u(x,y,t).
Step 2: plug in the suggested form for u(x,y,t) to see if it "works".
I agree with your method and can see that this problem isn't that hard... once you understand the heat equation.
I am searching now for more information on the 2D heat equation.
A good starting point?
Homogeneous Dirichlet B.C.:
Boxed equation (1): u_t = c^2 ∇^2 u = c^2(u_xx + u_yy), followed by the domain condition for 0 < x < a, 0 < y < b.
Not much of a start I'd say. A better start would be to write down what you are given, then write down what you are to prove. Then you could start working on it...
@LCKurtz ,
I have an extension on this assignment.
I am going to go through some intense studying tonight and I will report back with my updated tries for this problem and the other PDE problem I posted.
Thank you for your guidance thus far! Hopefully I come through.
@Ray Vickson
The 2D heat equation I am wondering what this means.
I have the 1d heat equation as follows:
u_t =k∇^2u
u(x,t) = k*∇^2u
is the 2d heat equation just
u(x,y,t) = k*(uxx+kuyy)
Separation of variable yiels
T'/(K*T) = X''/X = Y''/Y = -v^2
RJLiberator said:
@Ray Vickson
u_t =k∇^2u
u(x,t) = k*∇^2u
You mean ##u_t = k(u_{xx}+u_{yy})##, but, yes, that is what it means.
This problem has nothing to do with separation of variables. Start by following my advice in post #5.
Okay, what do we know?
Well, we know the 2 dimension heat equation now:
u(x,y,t) = k(U_xx+U_yy)
we know u(x,y,t) = v(x,t)w(y,t) from problem description.
we know
V_t = k*V_xx and w_t=k*w_yy
Do we set:
v(x,t)w(y,t) = k(U_xx+U_yy)
The thing that is confusing me is the left hand side, how do I work with a function of this nature.
It is very bad form, not to mention confusing, when you use both u and U and v and V to represent the same thing as you have done below. Don't do that.
I wouldn't call that u(x,y,t) because it suggests it is the same u in the heat equation. Call it something new like$$F(x,y,t) = v(x,t)w(y,t)$$
The question is whether or not ##F(x,y,t)## satisfies the heat equation ##u_t = k(u_{xx} + u_{yy})##.
we know
Do we set:
No. You plug ##F(x,y,t)## into the heat equation and see if what you are given makes it work.
