Pendulum simulation in C++ energy grows without bound
  • Context: Graduate
  • Thread starter Thread starter franznietzsche
    Modeling Pendulum
62 replies · 16K views
Franz,
There must remain a significant error in your code. The last run should match the small angle approximation solution of
[tex]\theta (t)= .1 cos( \frac {gt} l)[/tex]
This says the max velocity should .1 g/l. if you look at the run I did in Excel with a simple Euler method you can verify that. Also you should have a period of 2.007 seconds, this corresponds to my Euler run but not your last run.
unfortunately there remains a problem in your code. I cannot see it yet but will return to this shortly
(My wifes car has a flat, seems that she thinks that problem has priority! The Nerve!) :smile:
Originally posted by Integral
Franz,
Using conservation of energy and a starting position of 0.1 radians i calculate a maximum veolcity of 0.312919 m/s. then running the program again i get:
Enter a value for g: -9.8
Enter an initial angular position:0.1
Enter the pendulum length: 1
Enter the time interval between predictions: .100354
Enter run-time length of simulation: 2.00709
Press any key to continue . . .
Time: 0 Velocity: 0 Position: 0.1
Time: 0.100354 Velocity: -0.0619174 Position: 0.0937863
Time: 0.200708 Velocity: -0.11999 Position: 0.0817448
Time: 0.301062 Velocity: -0.170611 Position: 0.0646233
Time: 0.401416 Velocity: -0.210634 Position: 0.0434854
Time: 0.50177 Velocity: -0.237567 Position: 0.0196446
Time: 0.602124 Velocity: -0.249735 Position: -0.00541737
Time: 0.702478 Velocity: -0.24638 Position: -0.0301426
Time: 0.802832 Velocity: -0.22771 Position: -0.0529941
Time: 0.903186 Velocity: -0.194888 Position: -0.0725519
Time: 1.00354 Velocity: -0.149957 Position: -0.0876006
Time: 1.10389 Velocity: -0.0957117 Position: -0.0972057
Time: 1.20425 Velocity: -0.0355232 Position: -0.100771
Time: 1.3046 Velocity: 0.0268709 Position: -0.098074
Time: 1.40496 Velocity: 0.0875967 Position: -0.0892833
Time: 1.50531 Velocity: 0.142883 Position: -0.0749444
Time: 1.60566 Velocity: 0.189295 Position: -0.0559479
Time: 1.70602 Velocity: 0.223946 Position: -0.0334741
Time: 1.80637 Velocity: 0.244679 Position: -0.00891951
Time: 1.90673 Velocity: 0.250204 Position: 0.0161895
Time: 2.00708 Velocity: 0.240176 Position: 0.0402922
the max velocity should occur at 0.50177 sec, but it doesn't. the question then is whether the eroor is from the code, or the Runge-Kutta algorithm itself (since the error would be squared due to an application of the algorithm to its own results.)
Edit: Pff, everyuone knows Newtonian mechanics are WAY more important than auto mechanics. silly her..hehe.
Also i just noticed something else in the errors:
Enter an initial angular position:0.785398
Enter the time interval between predictions: 0.0100354
Enter run-time length of simulation: 2.50886
Time: 1.53542 Velocity: 2.30635 Position: -0.129727
Time: 1.54545 Velocity: 2.31847 Position: -0.10646
Time: 1.55549 Velocity: 2.32843 Position: -0.0830934
Time: 1.56552 Velocity: 2.3362 Position: -0.0596486
Time: 1.57556 Velocity: 2.34179 Position: -0.0361479
Time: 1.58559 Velocity: 2.34517 Position: -0.0126131
Time: 1.59563 Velocity: 2.34635 Position: 0.0109335
Time: 1.60566 Velocity: 2.34533 Position: 0.0344698
Time: 1.6157 Velocity: 2.3421 Position: 0.0579737
Time: 2.00708 Velocity: 0.795103 Position: 0.74091
Time: 2.01712 Velocity: 0.731119 Position: 0.748247
Time: 2.02715 Velocity: 0.666608 Position: 0.754937
Time: 2.03719 Velocity: 0.60162 Position: 0.760974
Time: 2.04722 Velocity: 0.536204 Position: 0.766355
Time: 2.05726 Velocity: 0.470407 Position: 0.771076
Time: 2.06729 Velocity: 0.404279 Position: 0.775133
Time: 2.07733 Velocity: 0.337867 Position: 0.778524
Time: 2.08736 Velocity: 0.271217 Position: 0.781246
Time: 2.0974 Velocity: 0.204378 Position: 0.783297
Time: 2.10743 Velocity: 0.137396 Position: 0.784676
Time: 2.11747 Velocity: 0.0703191 Position: 0.785381
Time: 2.1275 Velocity: 0.00319285 Position: 0.785413
Time: 2.13754 Velocity: -0.0639356 Position: 0.784772
Time: 2.14758 Velocity: -0.13102 Position: 0.783457
Time: 2.15761 Velocity: -0.198012 Position: 0.78147
the position should max out at 2.00708 seconds, but it doesn't, it keeps rising until 2.1275 seconds, at which point it is only .001 radians off from what the maximum position should be. Also the highest velocity listed is 2.34635 m/s, which is only 0.04963 m/s less than the predicted maximum veolcity. The inaccuracy exists in that these are predicted at the wrong times, but the actual predicted maximum and minimum values of position and velocity are very close to what they should be.
Also another thought just occered to me. the Newtonian equation for the period of a pendulum [tex]T = 2*pi*sqrt(l/g)[/tex] is only an approximation and only accurate for small displacements. Now i noticed that with the 0.1 starting position the program predicted a shorter period that the Newtonian equation, but for the 0.785398 radian initial displacement it predicted a longer period.
Now is it possible that the computer program is following the actual period more closely than Newton's equation? Does anyone here know what the real equation for the period of a pendulum (or other harmonic oscillator) is?
That is why I wanted to see the run with initial position of .1, it should be modeled very nicly by the closed form approximate solution. For that run you would expect the period to be spot on. That is not true for the ~.7 initial postion, we would expect to see some variation at that amplitude. If we cannot get good results with .1 amplitude, then we cannot get meaningful results anywhere.
edit: yes, English is my native language, believe it or not!
Franz,
At .1 initial postion the difference between this equation and our RK model should be on the order of h^4, we should agree to 3-4 decimals.
BTW g in this model must be positive, its sign has been factored in already.
the sign isn't built-in in my runge-kutta algorith though because the angular is acceleration is (g/l)*sin(theta). SO i input it as a negative.
Also I'm going to run the program for many variations of g, l, and initial position to try and see if the period that the program gives is a consistent function of those values and how close it is to Newton's equation. It is certainly more likely that the model is simply flawed, but it is worthwhile to examine it more closely, because it is also known that Newton's equation is overly simplistic, and because the period was smaller in the model at a low amplitude, and larger in the model for a larger amplitude i think it is possible even if unlikely that the model is following what the real equation predicts within the predicted error.
ran a new simulation for h=0.0100354 and initial position 0.1:
Time: 0.481699 Velocity: -0.303909 Position: 0.00845068
Time: 0.491735 Velocity: -0.304701 Position: 0.00539289
Time: 0.50177 Velocity: -0.305206 Position: 0.00233003
Time: 0.511805 Velocity: -0.305424 Position: -0.000735027
Time: 0.521841 Velocity: -0.305355 Position: -0.00379939
the actual calculation for the equilibrium point is t = 0.5017724078863 seconds, and the max velocity would be -0.3129. This h value is ten times smaller than the previous one and much more accurate. I think now that the problem is that error is doubled, not squared or some other change when using the algorithm on itself.
i wrote another program to calculate the period using the previous program's Runge-Kutta algoithm. it is:
Code:
#include<iostream.h>
#include<math.h>
#include<stdlib.h>
#include<pendulumfunctions.h>
int main()
 g = -9.8;
 cout << "Enter the length of the pendulum: ";
 cin >> l;
 gl = g/l;
 cout << "Enter the initial angular position: ";
 cin >> ang;
 cout << "Enter duration of simulation: ";
 cin >> z;
 iang = ang;
 y = ang;
 w = 0;
 av = 0;
 t = 0;
 h=0.00001;
 while (t<z)
  ang = y;
  av = w;
  velocity(gl, ang);
  position(gl, ang);
  if ((iang-ang)<0.000000001)
   cout << "Time: " << t << "\tVelocity: " << velocity(gl, ang) << "\tPosition: " << position(gl, ang) << endl;
   system("PAUSE");
  t = t + h;
 system("PAUSE");
 return 0;
[B]Pendulumfunctions.h:[/B]
#include<math.h>
typedef double dou;
dou g, l, ang, iang, av, aa, t, h, w, y, v, z, gl;
dou aac(dou gl, dou ang) //Function for angular acceleration, radians/sec
dou aa;
aa = gl*sin(ang);
return (aa);
inline dou vkone()
return(aac(gl, ang));
inline dou vktwo()
return(aac(gl, (ang + (h/2)*vkone())));
inline dou vkthree()
return(aac(gl, (ang + (h/2)*vktwo())));
inline dou vkfour()
return(aac(gl, (ang + h*vkthree())));
dou ave(dou gl, dou ang) //Uses Runge-Kutta Algorithm for angular velocity
if (t==0)
return av;
else
w = av +(h/6)*(vkone() + 2*vktwo() + 2*vkthree() + vkfour());
return w;
dou velocity(dou gl, dou ang)
v = ave(gl, ang)*l;
return (v);
inline dou pkone()
return(ave(gl, ang));
inline dou pktwo()
return(ave(gl, ang + (h/2)*pkone()));
inline dou pkthree()
return(ave(gl, ang + (h/2)*pktwo()));
inline dou pkfour()
return(ave(gl, (ang + h*pkthree())));
dou position(dou gl, dou ang)  //Uses Runge Kutta algorithm for position
if (t==0)
return iang;
else
y = ang + (h/6)*(pkone() + 2*pktwo() + 2*pkthree() + pkfour());
return y;
The header file pendulumfunctions.h is unchanged between the two programs, its the main file that differs. here are the period results for 0.1 radians starting position and 0.785398 starting position:
Enter the length of the pendulum: 1
Enter the initial angular position: 0.1
Enter duration of simulation: 8
Time: 1e-05 Velocity: -9.7832e-06 Position: 0.1
Time: 2e-05 Velocity: -1.95664e-05 Position: 0.1
Time: 3e-05 Velocity: -2.93496e-05 Position: 0.1
Time: 4e-05 Velocity: -3.91328e-05 Position: 0.1
Time: 5e-05 Velocity: -4.8916e-05 Position: 0.1
Time: 2.00836 Velocity: 3.33546e-05 Position: 0.1
Time: 2.00837 Velocity: 2.35714e-05 Position: 0.1
Time: 2.00838 Velocity: 1.37882e-05 Position: 0.1
Time: 2.00839 Velocity: 4.00496e-06 Position: 0.1
Time: 2.0084 Velocity: -5.77824e-06 Position: 0.1
Time: 2.00841 Velocity: -1.55614e-05 Position: 0.1
Time: 2.00842 Velocity: -2.53446e-05 Position: 0.1
Time: 2.00843 Velocity: -3.51278e-05 Position: 0.1
Time: 2.00844 Velocity: -4.4911e-05 Position: 0.1
and for 0.785398 (pi/4 or 45 degrees):
Enter the initial angular position: 0.785398
Time: 0 Velocity: 0 Position: 0.785398
Time: 1e-05 Velocity: -6.92941e-05 Position: 0.785398
Time: 2e-05 Velocity: -0.000138588 Position: 0.785398
Time: 2.08735 Velocity: 6.80124e-05 Position: 0.785398
Time: 2.08736 Velocity: -1.28162e-06 Position: 0.785398
Time: 2.08737 Velocity: -7.05757e-05 Position: 0.785398
Time: 2.08738 Velocity: -0.00013987 Position: 0.785398
I bolded the times that gave the lowest velocities. Now these two use a very low h value for the algorithm, h = 0.00001 which causes the period predicted on the first one to be within .001 of the predicted period. The period for the larger amplitude is farther from the predicted, but this is too be expected as Newton's equation becomes invalid for large initial amplitudes.
Based upon this data it looks like the inaccuracy noted earlier was caused not by any flaws in the algorithm (the two programs use the exact same algorithm) but by using an h value that was altogether too large. So the predictions made by the program that gives the position are accurrate given a low enough value of h.
http://home.comcast.net/~rossgr1/Math/Eulererror.pdf is a PDF showing the deviation of a simple Euler method from the closed form solution. With a similer step size the RK method should be a better approximation, it is not. I have coded in VB both a Euler method (it produced the numbers in this pdf) and an RK method. My RK is produceing similar results as yours. I am staring at the equations, and think I am close to finding the problem in our implementation.
I think the problem is the application of the RK algorithm to its ownresults. I've been doing regression analysis for the past few hours of the predicted periods, and for small enough theta they match Newton's equation near exactly. What i have is a quadratic (with theta being the variable that is squared) with very small (about [tex].06159L+0.078092[/tex] and [tex]0.019259L+0.017962[/tex] respectively) a and b coefficients, and the c value is Newton's equation for the period.
Ok, http://home.comcast.net/~rossgr1/Math/Rkerror.PDF is the way an R-K method SHOULD look! Note that this run has the same step size as the Euler method I posted earlier, but has at least 2 more good digits!
Code:
k1 = h * Velocity_old
l1 = h * RHS(L, Position_old)
k2 = h * (Velocity_old + (l1 / 2))
l2 = h * RHS(L, Position_old + (k1 / 2))
k3 = h * (Velocity_old + (l2 / 2))
l3 = h * RHS(L, Position_old + k2 / 2)
k4 = h * (Velocity_old + l3)
l4 = h * RHS(L, Position_old + k4)
      Velocity_new = Velocity_old + (l1 + 2 * l2 + 2 * l3 + l4) / 6
      Position_new = Position_old + (k1 + 2 * k2 + 2 * k3 + k4) / 6
I finally found the section in Conte and Deboor dealing with R-K and SYSTEMS of equations. You cannot compute the corrections seperatly, notice in the above code the ls are corrections for velocity but they depend on the ks and visa versa.
In this code snipit RHS is for Right Hand Side, it is your Acc.
This works.
Whew... Being beating my head on this all day!
QUOTE]
Code:
Function RHS(Length, Position)
g = 9.80665
RHS = -g * Sin(Position) / Length
End Function
Is that better? :)
(I carry the negitive with the function.)
Opps... Make that it is your aac
Edit one more time!:
I see that you are factoring your step out of the k2 (your Vkone ) . Can't do that! note that since k2 depends on l1 if you do not have the factor of h in l1 , k2 will be wrong.
That make sense?
I've finally had some time to think about this. The euler method doesn't conserve energy. You can see this by graphing theta vs t. you'll see theta_max increases with each period. YOu can use Euler-Cromer method which is the next easiest method.
JMD
nbo10,
The Euler method works fine. I do not see any increase in amplitude with time. As well as the fact that it has been in use for years and has always worked fine, considering its inherent errors. Perhaps you need to examine your implementation.
In general Eulers methods fine, but not when you use it to solve the pendulum problem. Calculate the energy and graph the results. The attached gif is what you'll see. YOu can decrease the error in Eulers method by decreaseing dt, but you still won't conserve energy.
JMD
Euler-Kromer method
JMD
Once again, it is your implementation that is at fault. Not Euler.
Since the Euler method is simply a discretization of a derivative, it cannot effect the energy of the system. However, careless implementation can result in garbage, such as you are seeing.
http://home.comcast.net/~rossgr1/Math/Eulerc.PDF is a chart of my implementation of the Euler method. There is NO tendency to increase in amplitude. Please stop blaming the method for your implementation errors.
I'm not going to sit here and argue about this, I have too much to do. For periodic functions Eulers method is unstable. Run YOUR program using Eulers method for 100 periods check the results. It's unstable. THis is my last post about this subject.
Code:
t[i+1] = t[i] + dt;
omega[i+1] = omega[i] - (g/l) * theta[i] * dt;
theta[i+1] = theta[i] + omega[i] * dt;
Energy[i+1] = g*l*(1 - Math.Cos(3.1415*theta[i])/180 ) + 0.5 * omega[i]*omega[i];
This doesn't work, Euler method.
Code:
t[i+1] = t[i] + dt;
theta[i+1] = theta[i] + omega[i+1] * dt;
This does work, Euler-Kromers method.
JMD
Please provide some references concerning the instability of Euler for periodic functions.
First of note that you are using the small angle approximation to the pendulum. It is not necessary to apply numerical methods to that problem. It has a nice closed form solution which I have already posted in this thread.
I am not sure what your problem is. Euler could well fail after 100 periods simply due to accumulated error. It is prone to that. R-K is much better in that respect. To the best of my knowledge, Euler is not any more unstable for Periodic functions then it is for any other class of function.
If you have some hard core references please provide them. If not then please speak carefully when expressing such opinions.
Using the closed form of the solution enhances the problem of energy conservation.
Code:
do {
i++;
t[i+1] = t[i] + dt;
omega[i+1] = omega[i] - (g/l) * Math.Sin(3.1415*theta[i]/180)* dt;
Energy[i+1] = g*l*(1 - Math.Cos(3.1415*theta[i])/180 ) + 0.5 *l*l* omega[i]*omega[i];
omega1[i+1] = omega1[i] - (g/l) * Math.Sin(3.1415*theta1[i]/180) * dt;
theta1[i+1] = theta1[i] + omega1[i+1] * dt;
Energy1[i+1] = g*l*(1 - Math.Cos(3.1415*theta1[i])/180 ) + 0.5 * l*l*omega1[i]*omega1[i];
while (t[i+1] <= 10*per);
thetaplot.PlotXY(t,Energy1);
omegaplot.PlotXY(t,Energy);
theta, omega, energy, use Euler method.
theta1, omega1, energy1 use Euler-Kromer method.
Here is the result a plot of energy vs time.
I believe Numerical Analysis, 6th Ed. Talks about the problems of Eulers method. I can't be for sure because, I don't have my copy handy.
JMD
I can find no reference to Kromer in my books. But looking at what you are doing it is clear that your Kromers method is simply the correct implementation of Euler's method to a SYSTEM of equations. Your first code (what you call simply Euler's) is not the way to solve a system. While the second is. So yes your first program will not work.
Edit:
There is no doubt that there are inherent troubles with Euler, even if implemented correctly. But it is no more unstable or inaccurate for Periodic solutions as any other 2nd order equation.
It's Cromer and not Kromer, my mistake. Every book I've read has Euler as the way that I have it above.
You can show that in Euler-Cromer method (for oscillatory motion over a period) the Energy increase is ~dt^3, while Euler method energy is increase is ~dt.
JMD
Remember that this is a system of equations. Look at the variation of the Runga Kutta method that was need to correctly model a system of equations. The same follows for Euler's. The trouble comes with how to best solve the system as much as the method used.
Could you please expand on this?
I cannot see how you can meaingfully relate discretiontion error to energy conservation. If there were something physically incorrect, as you imply, then it would not matter how small a step size you take, the method would still "not conserve energy". The fact is Euler has error ~h (or dt as you call it) So what you say is trivial and has nothing to do with energy or periodic functions.
Integral, numerical analysis involves a lot more than using Taylor series to show roundoff error.
Certain methods with apparently identical roundoff can be better or worse at solving specific problems. Periodic motion tends to rack up large numerical errors after many periods, so naive implementations won't last long. nbo's labeling of "Euler" and "Euler-Cromer" methods is standard, and it is easy to show that Euler's method leads to monotonically increasing energy (if I remember right - I don't feel like writing anything right now), whereas Euler-Cromer does not.
Codes for more difficult systems like hydrodynamics often have conserved quantities explicitly built into the integration scheme. Things are much more stable that way. Runge-Kutta is useful for lots of things, but its not always the best tool.
Anyways, the pendulum can be solved analytically without the small angle approximation in terms of elliptic integrals. The properties of these functions are commonly tabulated in books, you can plot them in mathematica, etc (just like trig functions...).
My posts are based on the error analysis given in Elementary Numerical Analysis by Conte and de Boor and A Survey of Numerical Methods by Young and Gregory.
Certainly a compounding discretization error will lead to diverging amplitudes. You can call this failure to conserve energy if you wish, I will call it discretization error. Mainly because it can be controlled by choosing a smaller step size. Though why anybody would want to use Euler's or slight variations is not clear. Certainly there are better methods then R-K but it works.
I am surprised that the Cromer variation is not named in any of my texts, though comparing to Nob code, the Euler's numbers I generated were with the Cromers variation. I did it that way because it felt good!
One thing I do know about Numerical Methods is that you must watch your numbers like a hawk. The line between a stable solution and garbage is very thin. That is the reason I wanted to see some small amplitude numbers, those can be verified independently. If a model can be shown to be good for one set of IC it will also be good for other IC which are not hugely different.
I suppose you could solve the pendulum with elliptic integrals... What fun would that be? :)
Look here
for a comparison of Euler, Euler-Cromer, Runge-Kutta methods. It includes Matlab scripts.
In particular, notice that the straight Euler method gives energy error that grows exponentially; so whoever claimed first that Euler method is unstable for periodic motion appears to be correct.
I've done a lot of this kind of problem and have always used RK; it has never let me down.
