Percent change in mass when gaining charge.
7 replies · 20K views · last reply
Cllzzrd
When an object such as a plastic comb is charged by rubbing it with a cloth, the net charge is typically a few microcoulombs.
If that charge is 3.6*10^-6 C, by what percentage does the mass of a 39g comb change during charging?
n/a?
Ok here it goes...
total charge/electron charge=number of electrons
3.6*10^-6 / 1.60*10^-19 =2.47*10^13 Electrons
number of electrons* mass of electron at rest= change in mass
2.47*10^13 * 9.11*10^-31=2.05*10^-17g
change in mass/mass of comb= %change
2.05*10^-17 / .39 = 5.25*10^-17%
It says this is wrong, but I don't know of any other way to work this problem.
Check comb mass. And don't forget to give answer with correct number of significant figures.
Ok... checking units now...
I will just do unit calculations without the numbers... then substitute the numbers back in later if I am correct.
C*(e/C)*(kg/e)= kilograms gained... right?
When I calculate this using the numbers, I still get the same, incorrect answer.
You have written for the mass of the electrons:
Is the mass of one electron 9.11*10^-31 g?
ehild
I thought it was 9.11*10^-31Kg... If that is not it, what is? Is that where my calculations are going wrong?
g or kg? If kg - why do you list mass in grams?
39 g - how many kg?
