Period of a mass oscillating on a spring
In summary, the conversation discussed the period of a mass oscillating on a Hookeian spring and the equations used to find it. The correct solution was given using integration, while a simpler solution was also mentioned using the equation F = ma = -kx. The period was found to be T = 2pi/w, where w = sqrt(k/m).
jgens
50
The period of a mass m oscillating on a hookian spring of negligible mass.
F = -kx
I'm using x in place of ∆x for convienance.
F = -kx
dv/dt = -kx/m
∫vdv = -k/m∫xdx
v^2 = C - k(x^2)/m: Placing the restraint that if v = 0, x = xi
v^2 = k(xi^2)/m - k(x^2)/m
v = sqrt(k(xi^2)/m - k(x^2)/m)
t = sqrt(m/k)∫dx/sqrt(xi^2 - x^2)
t = arcsin(x/xi)sqrt(m/k). Therefore, if we allow ∆x = 0
t = arcsin(0)sqrt(m/k). Hence, if we want the time for one period:
t = 2pisqrt(m/k)
Is this correct? Thanks!
Yes that is correct.
But if you didn't want to integrate you could have just put F=ma=-kx
such that a= -(k/m)x
which is in the form a=-(w^2)x meaning that w=sqrt(k/m)
and the period T=2pi/w
Thanks! That's a much simpler derivation.
What is the period of a mass oscillating on a spring?
The period of a mass oscillating on a spring is the time it takes for the mass to complete one full cycle of oscillation, returning to its original position and velocity.
What factors affect the period of a mass oscillating on a spring?
The period of a mass oscillating on a spring is affected by the mass of the object, the spring constant, and the amplitude of the oscillation.
How is the period of a mass oscillating on a spring calculated?
The period of a mass oscillating on a spring can be calculated using the formula T = 2π√(m/k), where T is the period, m is the mass, and k is the spring constant.
Can the period of a mass oscillating on a spring be changed?
Yes, the period of a mass oscillating on a spring can be changed by altering the mass, spring constant, or amplitude of oscillation.
What is the relationship between the period and frequency of a mass oscillating on a spring?
The period and frequency of a mass oscillating on a spring are inversely related. The period is equal to 1/frequency, or T = 1/f.
