Period of Motion for Masses on Rod w/ Spring Constant 5.4 Nm.rad-1
  • Thread starter Thread starter Dennydont
    Motion Period
The problem involves a light rod of length 0.5 m with two point masses of 1.6 kg each attached at either end. The rod is pivoted at its center and connected to a spring that exerts a moment proportional to the angle of displacement from equilibrium. The rod is displaced by 0.27 rad and released, with the goal of finding the period of the resulting motion, given a spring constant of 5.4 Nm.rad-1.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the appropriate equations to use, particularly relating torque to angular acceleration and the moment of inertia for the system. There are questions about how to derive the period from the given equations and whether the spring constant can be related to torque.
The discussion is ongoing, with participants exploring various interpretations of the moment of inertia and the relationship between torque and angular motion. Some guidance has been offered regarding the equations to consider, but no consensus has been reached on the correct approach to find the period.
Participants note the complexity of deriving the moment of inertia for the two-point masses and the need to solve a differential equation to find the period. There is also mention of constraints related to the lightness of the rod and its contribution to the moment of inertia being negligible.
Dennydont
A light rod of length 0.5 m has two point masses of mass 1.6 kg attached at either end. The rod is pivoted about its centre and is attached to a spring which exerts a moment on the rod that is proportional to the angle the rod is displaced from the equilibrium position and which attempts to return the rod to the equilibrium position. The rod is displaced 0.27 rad from the equilibrium position and released from rest. If the spring constant is 5.4 Nm.rad-1 what is the period of the resulting motion?
y = Asin(ωt) = Asin(√((k/m)t))
I'm not sure if that's even the correct equation that I would use in this situation. All the variables are there, so it must be so... How would I derive period t from that?
You need to use the equation relating torque to angular acceleration.
Greetings,
I'll answer your question with resources:
http://mmsphyschem.com/oscSpring.html .
SHM.
http://www.pstcc.edu/departments/natural_behavioral_sciences/Web%20Physics/Chapter015.htm.
Please note I am not into this spring and motion stuff...I tried my best gathering the most valuable data related on the internet.
τ=ml^2α
Okay, done. Now what do I do with this equation? I've been given the mass and the length for this equation but that's about it. How is torque necessary in this problem?
Dennydont said:
τ=ml^2α
The moment of inertia of the rod with the two point masses is not ##m \ell^2 \ ##.
That's how torque is related to the angular velocity.
How does the spring produce that torque?
Dennydont said:
τ=ml^2α
Rewrite α in terms of the angle θ the rod makes with the position corresponding to zero torque. Then combine in the equation relating torque to the moment of inertia I, and θ. What is the torque expression? Hint: think spring constant relating torque to θ. BTW you may also want to think about what poster #5 said about your expression for I.
I'm not sure if this is correct, but could I relate spring constant to torque? τ=-kθ
And I realize now that ml^2 isn't the inertia for two-point masses? That should be: I = (mM/m+M)x^2
If I relate it to τ= Iα then: -kθ = Iα
Hmmm, can I say that α = ω/t where t is the period and just try to find that? Or did I come up with something that makes no sense?
Dennydont said:
I'm not sure if this is correct, but could I relate spring constant to torque? τ=-kθ.
Right.
what is your x? m and M are the same, just use m.
right.
No. What is the definition of α really?
rude man said:
Right.
right.
x = 0.5, that's the distance between the two m's. Okay, but is that the right equation for two-point masses? I = (m2/2m)x^2 since m and M are the same?
α = d2θ/dt2 something like that?
Don't like your choice of x.
Let's agree the bar has total length L.
Suppose you had only one mass m at one end of a bar of length L/2. What would I be if the axis of rotation were at the other end?
EXACTLY like that!
So what does the torque equation look like? Leave I = I for the moment until you have that figured out in terms of L and m.
EXACTLY like that!
I always have issues with the moment of inertia. But okay the expression should look like: d2θ/dt2*I = -kθ and I should rearrange everything to find dt which happens to be the period?
I don't quite understand the inertia but perhaps it is the sum of the contributions from the two masses? So m = 3.2kg multiplied by L2? No that doesn't sound right...
The moment of inertia is the sum of:
The moment of inertia of a rod of length, L, about its center.
The moment of inertia two point masses at opposite ends of a mass-less rod of length, L.​
Added in Edit:
It's a light bar, so ignore its contribution to the moment of inertia.
No. You need to solve the differential equation. That will give you the period along with everything else.
If youi haven't had diff. eq's then you need to compare this equation with the equation of a mass on a spring.
If I is the inertia of a mass at the end of a bar of length L/2 pivoted at the other end, then the I of two identical bars, identically pivoted, is twice the I of one of the bars.
Don't use numbers until you have figured out I(L,m).
ml^2 = I? Multiplied by 2 since the inertia for one of the bars is the same as the other?
How on Earth do I solve this differential equation for period T?
Look at the Formula sheet Doctor Moore provided you with!
What's the expression for a point mass a distance L/2 away from the pivot point?
It's a simple 2nd order linear, constant-coefficient ODE. You should wind up with something like θ = θ0cos(ωt) with θ0 the amplitude and ω a function of some of your given parameters. Surely you can deduce the period of a signal cos(ωt) if ω is given.
I'll have to sign off here.
  • · Replies 51 ·
