Period of motion of an object dropped through the Earth
The problem involves an object of mass moving through a straight tunnel dug between two points on the Earth's surface, exploring the conditions under which it exhibits simple harmonic motion. The original poster seeks to express this motion mathematically and determine its period, assuming uniform density of the Earth.
  • Participants discuss the relationship between force and displacement in simple harmonic motion, questioning how mass varies with radius when within the Earth. There are attempts to derive expressions for acceleration and gravitational force, considering the angle of motion relative to the center of the Earth.
Several participants have provided insights into the mathematical relationships involved, with some confirming the correctness of derived equations. There is ongoing exploration of how to express the gravitational force component in relation to the tunnel's orientation. The discussion reflects a productive exchange of ideas, with participants questioning and refining their understanding of the problem.
Participants are working under the assumption of uniform Earth density and are considering the implications of the tunnel's orientation on the forces acting on the object. There is a focus on ensuring dimensional consistency in the derived equations.
kubaanglin
An object of mass ##m## moves in a smooth, straight tunnel dug between two points on the Earth’s surface. Show that the object moves with simple harmonic motion, ##a = - ω^2 x##. Find the period of this motion. You can assume that the Earth’s density is uniform.
$$F=G\frac{Mm}{r^2}$$
$$V_{sphere}=\frac{4}{3}πr^3$$
$$ρ = \frac{M}{V}$$
I have been staring at this problem for the past 30 minutes. I would be very appreciative if someone could give me a hint on how to start this. I intuitively understand why the object would experience simple harmonic motion, I just can't figure out how to express it mathematically, especially since the hole does not have to go through the center of Earth.
For SHM, ##F\propto r## when r is the displacement from an equilibrium point.
Notice that the two points on the surface of the Earth do not have to be diametrically opposite each other.
However - you have ##F\propto r^{-2}## for the case that r>R. But that is not the case here.
How does M vary with r when r<R (R=radius of the earth)?
##M=\frac{4}{3}πr^3ρ=(\frac{4}{3}πr^3)(\frac{M_{Earth}}{\frac{4}{3}πR^3})=\frac{r^3M_{Earth}}{R^3}##
##a=G\frac{M}{r^2}=G\frac{\frac{r^3M_{Earth}}{R^3}}{r^2}=G\frac{rM_{Earth}}{R^3}##
Is this correct so far?
That is the magnitude of radial acceleration if the object were not constrained to move in the tunnel.
Multiply by mass, m, to find the magnitude of the gravitational force. What component of that force is in the direction of the tunnel?
##F = G\frac{rmM_{Earth}}{R^3}\cosθ## where ##θ## is the angle between ##r## and the direction of motion. ##\cosθ = \frac{x?}{r}##.
kubaanglin said:
where θ is the angle between r and the direction of motion.
If you fall into a vertical hole, what is the angle between your direction of motion and the line joining you to the centre of the Earth?
The angle would be ##0°## so then ##\cos(0°)=1##. That leaves me with ##F = G\frac{rmM_{Earth}}{R^3}##. How would that account for the component of the force if the tunnel was not through the center of the Earth?
I'm sorry - I misread the question.
So let x be the distance from the midpoint of the tunnel. Express theta as a function of x and r.
So ##\cos(θ)=\frac{x}{r}## and then ##F = G\frac{mMx}{R^3}##?
Yes.
Okay, so then
##a=ω^2x=G\frac{Mx}{R^3}##
##ω=\sqrt{\frac{GM}{R^3}}=\frac{2πr}{T}##
##T=\frac{2πr}{\sqrt{\frac{GM}{R^3}}}##
Is this correct?
kubaanglin said:
Okay, so then
Is this correct?
What is r there? Check the dimensional consistency.
Oh, ##ω=\frac{2π}{T}\neq\frac{2πr}{T}##
Then this should be the answer:
$$T=\frac{2π}{\sqrt{\frac{GM}{R^3}}}$$
$$T=\frac{2π}{\sqrt{\frac{(6.67⋅10^{-11})(5.96⋅10^{24})}{(6.37⋅10^6)^3}}}=5066 s=84.44 min$$
Looks right.
Thank you so much for your help!
  • · Replies 26 ·
