- 6,031
- 3,159
Without the surface currents, magnetized materials would produce rather small magnetic fields, and in addition, there wouldn't be a significant magnetic field inside the material to maintain the magnetization. e.g. Uniformly magnetized discs with the direction of magnetization perpendicular to the face of the disc produce only weak magnetic fields because there are minimal surface currents with this geometry. ## \\ ## Without any surface currents, the exchange interaction, which is energetically much stronger, would still dominate, but by itself, would not explain why it takes such a tremendously strong reverse solenoid current to reverse the direction of magnetization in a permanent magnet. This feature is explained simply by the surface currents. ## \\ ## @ZapperZ Your suggestion for an alternate title, to change the word from "explained" to "described" is perhaps a good one. ## \\ ## The type of discussion I'm still hoping for though is a comparison of the calculations of magnetic "pole" model with those of the "surface current." Even J.D. Jackson's Classical Electrodynamics textbook, which emphasizes the "pole" model, treats ## H ##, (including the ## H ## from the "poles"), erroneously as a second type of magnetic field (besides what he calls the magnetic induction ## B ##). A thorough study of the surface current calculations shows that the ## H ## from the poles in the material is simply a geometric correction factor for geometries other than the cylinder of infinite length. (Mathematically, J.D. Jackson's treatment of ## H ## as a second type of magnetic field works for the purposes of computation, but his ## H ## is actually unphysical. ## H ## is simply a useful mathematical construction that is used to help compute the magnetic field ## B ##. ) ## \\ ## Meanwhile, the article I wrote is intended to help give the student a solid introduction to some E&M fundamentals, rather than trying to explain any details of the exchange interaction.
