Phase shift formula for sine wave by days in Excel
7 replies · 4K views · last reply
steven757
TL;DR
Phase Shift
Hi,
I have created a sine wave with the following options:
1.) - changing the period/length in days of the sine wave (Cycle Length in Days)
2.) - calculating the start value of the "dummy" so that the sine wave always starts with -1 (Dummy Start at Cycle Trough) when the phase shift is set to "0".
3.) - calculating the phase shift, so that the sine wave moves a specific amount of time/days forward when I enter a positive value greater "0" in the "Phase Shift" input cell ("N2") or backward when I enter a negative value smaller "0" in the "Phase Shift" input cell ("N2").
Here is my Excel formula:
=+SIN((2*PI()*$H$2*B4)-$N$2)
I have attached my Excel file so you can easily see how my calculations work.
Now my problem/question:
I want make a phase shift of the sine wave with a specific amount of days e.g. 20 days forward or backward.
How can I calculate the phase shift value I enter in the cell "N2" with a formula so that the sine wave moves exactly e.g. 20 days forward or backward?
This formula should of course also work when I change the period/length in days of the sine wave (Cycle Length in Days) I enter in cell "F2".
Many thanks for your help.
Steven
A sine wave has the expression ##y(t)=A\cdot \sin(ct+p)##. ##A## is the amplitude, ##1/c## the period, and ##p## the phase shift.
steven757 said:
Summary:: Phase Shift
Three sine wave graphs of amplitude against t labelled In-phase (φ = 0°), Positive Phase (+φ) and Negative Phase (-φ), with formulas A(t) = Am sin(ωt), A(t) = Am sin(ωt+φ) and A(t) = Am sin(ωt-φ).
https://www.electronics-tutorials.ws/wp-content/uploads/2018/05/accircuits-acp27.gif
Hi fresh_42 and berkeman,
Thank you for your answers.
I have understood the sine wave functionality and the issue with the positive and negative phase.
What I want is a formula to calculate the phase shift exactly as described in my post above. I have also attached an Excel file so you can see what I want.
Thanks
How many days is a full cycle of the sine wave? That corresponds to a full ##2\pi## cycle of the sine wave.
We generally don't open Excel file attachments around here. It's too easy for there to be problems embedded in them. Instead, just attach a screenshot PDF or JPEG that shows the cells and formulas that you are asking about. Thanks.
Hi berkeman,
I have attached three screenshots:
1.) - with NO phase shift (in cell P2 the value 0.00 is entered)
2.) - with POSITIVE phase shift (in cell P2 the value 1.00 is entered)
3.) - with NEGATIVE phase shift (in cell P2 the value -1.00 is entered)
All screenshots uses 80 days for a full cycle of the sine wave. BUT the cycle length changes, it is NOT always 80 days it could be also 125 days, 95 days, 168 days, and so forth.
I hope this helps.
  • Excel spreadsheet with a line chart titled Sine Wave with NEGATIVE Phase Shift, showing a sine wave plotted over dates from 01/01/2000 to 10/21/2000, with y-axis from -1.50 to 1.50.
  • Excel spreadsheet with a line chart titled Sine Wave with NO Phase Shift, plotting values from about -1.00 to 1.00 across dates from 01/01/2000 onward, with four full cycles of 80 days each.
  • Excel spreadsheet with date and sine wave columns beside a line chart titled Sine Wave with POSITIVE Phase Shift, showing a blue sine curve over dates from 01/01/2000 to 10/21/2000.
I have noticed that the screenshots are not very sharp and also can't easily be read so I have attached a PDF file.
You want a different form of the sine wave, sin(k(d - d0))
A positive value of d0 will shift the sine wave left by d0 days, a negative value will shift it right.
I'm not sure which of those cell references corresponds to the day number d. But basically you want the shift to be grouped with the day, (d - d0).
