Photoelectric effect and blue light
12 replies · 4K views · last reply
leslielau
A beam of blue light falls on the cathode of a photocell so that electrons are emitted. The blue beam is then replaced by a yellow one with the same intensity and electrons are also emitted. What would happen to each of the following physical quantities when the blue beam is replaced by the yellow beam?
K: Maximum KE of electrons emitted
I : The magnitude of photoelectric current
A. K increases, I uncahged
B. K decreases , I unchanged
C. K decreases, I increases
D. K decreases, I decreases
Photoelectric equation : KE(max)= hf - (work function)
h = Planck constant, f = frequency of incident light, KE(max) = maximum KE of photoelectron
Since yellow light is now used, frequency decreased --> so K decreases
Since Intensity is unchanged, current unchanged --> so I unchanged
so I chose B.
Correct Answer : C
Which part did I understand wrongly? Thanks !
I is the magnitude of the photoelectric current, not the intensity of the incident beam as stated in the question
since current = charge per unit time,
if you have less electron ejected per unit time due to the lower frequency yellow light, your photoelectric current magnitude will thus decrease
hmm... maybe the answer is D?
i don't know... someone else might know
but since (KE)max decreases, doesn't it mean that the current decreases?
sorry, i was still editing my answer
but , anyway, i don't think its because KE decreases, that current decreases
its more about the frequency of photon ejecting the electrons that will determine the current magnitude
current is charge per unit time.
if you switch to yellow which is lower frequency, photons will thus have a lower frequency of hitting out the electrons, so the current should decrease.
Light intensity tells us how much energy is delivered per second.
To deliver the same energy per second with low energy yellow photons means more photons per second
If we assume every photon releases an electron then there are more electrons emmitted per second
I increases. C is correct.
hmm , if you say more photons per second, wouldn't that mean the frequency of yellow light increase?
if i put it mathematically,
I = P/A , P = E/t
I = E/ (tA) , E = hf
I = hf / (tA)
if i switch to yellow light, frequency would drop. so for constant I, A has to drop?
since area drops, you have lesser emitted photoelectrons for a smaller area per unit time, and hence current should drop?
but also from wiki,
For a given metal and frequency of incident radiation, the rate at which photoelectrons are ejected is directly proportional to the intensity of the incident light.
so since the yellow incident light has the same intensity as blue, wouldn't it then mean that the rate of photoelectrons ( which is current) is the same? so magnitude of photoelectric current should not change?
quietrain said:
I = P/A , P = E/t
I = hf / (tA)
E = hf is the energy of a single photon, not the energy of the entire beam. To compute the intensity this way, you would need to know, and account for, the number of photons incident on the area per unit time. This won't be the same for different frequencies and intensities.
quietrain said:
but also from wiki,
This means for a fixed frequency, i.e. for the same colour light. In the case of the above experiment, the intensity is fixed, while the frequency is varied.
apelling is correct.
doesn't the frequency of light , e.g yellow, tell you the number of incident photons per unit time?
so if intensity is fixed, then like what apelling said, that more photons per sec are required for yellow light to make intensity constant, then wouldn't it mean that yellow light has increased frequency which makes it a blue light now?
No the rate at which photons arrive is not the same as the frequency of the light.
The frequency of the light is the frequency of oscillation of the electromagnetic fields within each photon wave packet. This is the frequency in E=hf. The number of photons per second is indeed proportional to the intensity but inversely proportional to the frequency of the light.
Just to clarify what apelling said to avoid further confusion:
  • The flux of photons per unit time is proportional to the intensity for fixed frequency
  • The flux of photons per unit time is inversely proportional to the frequency for fixed intensity
Thanks for all the help ! I understand it clearly now !
