Photoelectric effect wavelength
To find the wavelength of an emitted electron given its kinetic energy, one can use the kinetic energy equation E=0.5mv² to determine the velocity (v) of the electron. After finding v, the de Broglie wavelength can be calculated using the relationship λ = h/p, where p is the momentum. There is some confusion regarding whether to apply de Broglie's relationship or Planck's equation, as the latter typically pertains to electromagnetic radiation. Clarification on the specific question posed would help in determining the appropriate approach. Understanding the context of the question is crucial for selecting the correct formula.
blindsided
This is not a specific question; I'm just unclear about a concept.
Given the kinetic energy of an electron emitted, how would you find the wavelength?
E=h*frequency
or
E=0.5mv2
I'm thinking I would use the secon equation, find v, then use de Broglie's relationship to find wavelength. Am I on the right track?
Assuming that the question is to find the de Broglie wavelength of the electron, then you are on the right track.
Hmm...
The question hadn't specified de broglie wavelength- hence my confusion as to whether I would use de Broglie's relationship or just Planck's equation.
I thought Planck's equation only pertained to EM radiation?
Post the question word for word as it was given to you.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
