Photon Size: Uncertainty Principle & QM Explained
  • Context: Graduate
  • Thread starter Thread starter Thinker007
    Photon
65 replies · 19K views
Thinker007
I was listening to a physics professor lecturing on QM and he raised the question "How big is a photon?" and indicated it had arisen during his PhD defense.
He than began to discuss the accurately known frequency and wavelength of a laser emitted photon (and thus accurately known momentum) in the context of the uncertainty principle. The product of the uncertainty in position and accurately measured momentum is greater than or equal to (up to a small numerical factor) Planck's constant. He then concluded that in the direction of travel, the position was unknown to within a surprisingly large distance - a meter or so. Or more accurately, that is how I interpreted it. He didn't say position is unknown, he was still talking about "size".
Without really saying it, the implication was that the answer to the question was that a photon was a meter or so long in the direction of travel (and the emitting aperture wide in the transverse direction).
Does that description of "size" make sense to those here? I would probably have said that the photon is a point particle unless we're doing string theory, and the location was just poorly known along the travel direction. If the photon was truly "big" I'd think it would take 3 nanoseconds to finish arriving at a detector assuming a foot or so per nanosecond speed of light, and that should easily be measurable. Do photons take a finite amount of time to "arrive" at a detector?
Thanks.
The current theory works very well with a pointlike particle approximation of a quanta of the electromagnetic field. I don't know of a successful model (i.e. predictive and confirmed by experiments) of a finite size photon particle.
Uncertainty and size aren't the same thing. Like dextercioby said, photons, like all elementary particles, are point-like.
Uncertainty in position of a photon produced by a finely tuned laser can, indeed, be quite macroscopic. That shouldn't be surprising. Even in classical treatment, in order to have a precise frequency, the oscillation must have significant duration. Therefore, a precisely localized photon cannot possibly have a precise frequency.
But it doesn't mean the photon is one meter long now. It means that the photon is still a point particle that's distributed over span of space of one meter.
The size of a photon depends on its environment. If you have a cube with mirrored surfaces on the inside, then the photons that describe the electromagnetic field inside that cube are the size of the cube -- whether it is 1 micrometer or 1 kilometer.
You are still talking about the probability distribution, not the location of a particle. If you insist on talking about EM field in terms of particles, photon is point-like.
I think your professor is just expressing a sentiment like "the particle is part of a beam, and that beam is extracted at some time. So the particle is localized to some extent. ... To a particle the beam is the whole universe, and it is big!" http://books.google.com/books?id=CNCHDIobj0IC&dq=veltman+mysteries+facts&source=gbs_navlinks_s (p117).
It's similar to Redbelly98's reply.
Can a photon be localized? Some people think not eg. http://arxiv.org/abs/0903.3712.
Photon in a cavity might as well be considered localized. Yes, realistically, the barrier is finite, so there will be an exponentially decaying tail. But you can make skin depth thin enough and walls thick enough to make the description of localized photon be as valid as it needs to be.
But none of this still has anything to do with size of a photon.
Because this was a simplified minimal mathematics lecture series for the general public I would have assumed that his "size" comment was just a fuzzy way of introducing related concepts, except that he presented it as a specific trick question he was asked during his PhD defense.
Perhaps what he was getting at is that when detected, the photon has size that interacts with the detector with pointlike properties, but while propagating before detection it has size that is described with wavelike properties distributed over the meter distance. IOW, I suppose he was trying to emphasize wave particle duality and that both are legitimate descriptions of the real world, with an equal claim to the concept of "size."
I know I tend to think of the particle as the "real" thing and the wave function as describing a probability for where that real thing is "really" located, but I know that's sort of a non-QM bias I have from growing up in a macro sized world.
Thanks for the comments.
It's been known since the mid 20th century that the wave trails of photons are typically some millions of cycles long (several meters). But that says nothing about a photon's possible extent in other spatial directions.
A photon may even be considered enigmatic if we ask the question: "What is a photon? Is it a particle that binds energy into a highly compressed region or is it a wave that potentially spreads into infinity as it's edges dissipate in time and space?"
Which parameter do you mean here?
Coherence length of most light sources is shorter than that (just a few wavelengths). You need a laser to get coherence lengths of meters with visible light.
I think we'd need to look at the experiments that produced those results. Sorry, I don't have a reference handy at the moment.
How about re-framing the question as follows:
If a photon travels down a direction in vacuum, how small a hole will need to be to stop it entirely.
The question might need to be asked first for visible light and then for other wavelengths should there be interesting differences (like the barrier might need to of different material).
The answer might need to be in probabilistic form, like if the photon is 450nm wavelength and if the hole is 500nm in diameter, the photon might go through 70% time.
I think you should explain this.
This depends on the way the light approaches the hole. A well-focused laser beam? A flashlight?
There will always be some light getting through, but for lengths smaller than the wavelength a better focus does not help any more, and the maximal (!) fraction going through begins to drop.
laser or flashlight? It shouldn't matter. The question is for one photon. The source should not matter except for a laser, all the photons would be same wavelength and the flashlight would be many.
No, photons certainly have different propties depending on the source. You can't strictly speaking have a single photon from a flashlight, since those photons are thermal; you can only talk about a definitite number of photons (e.g. 1) for sources that emitt photons in a number state. This is why you can't create a real single photon source by simply attenuating a normal source of light (not even a laser, sine a laser emitts coherent photons).
Moreover, and perhaps more relevant to the OP, single photons can even have different "shapes"; at least if you believe that what is being measured is actually a "real" property of a photon
see e.g.
http://arxiv.org/abs/1203.5614
The correlation plots in e.g. fig 2 represent the "shape" of a single "two-peak" photon, at least if you believe the authors (I saw a talk about this at a confence a couple of months ago)
f95toli said:
No, photons certainly have different propties depending on the source. You can't strictly speaking have a single photon from a flashlight, ...
Ah, a bit of clarification needed here. I meant when you get down to one photon, the source should not matter except that the source would determine the wavelength or a range of wavelengths.
From the article, I find this "Here, we demonstrate that single photons deterministically emitted from a single atom into an optical cavity...". So it seems now feasible to emit single photons at will.
But it DOES matter. There are lots of different single photon sources available, so we now know how to generate snlge photons at many different wavelenghs.
However, all of these sources are fundamentally "quantum mechanical" in that they are able to generate a single excitation, they are very different from a flashlight.
If you start with a thermal source you can of course attenuate it so that it looks like it on average emitts say a single photon per second when you measure the energy it outputs; but it won't be a true single photon source since a thermal field (as it is known) does not contain a fixed number of photons. The emitted radiation simply does not HAVE a property "X number of photons". A source that can generate single photons emitts radiation that is in what is known as a number (or Fock) state, and then this property exists (but the price you pay is that now the phase is undetermined).
From the OP:
That's a good description, I think...
Here are a few from others:
Carlo Rovelli:
“…we observe that if the mathematical definition of a particle appears somewhat problematic, its operational definition is clear: particles are the objects revealed by detectors, tracks in bubble chambers, or discharges of a photomultiplier…”
A particle is in some sense the smallest volume/unit in which the field or action of interest can operate….Most discussions regarding particles are contaminated with classical ideas of particles and how to rescue these ideas on the quantum level. Unfortunately this is hopeless.
... A particle detector measures a local observable field quantity (for instance the energy of the field, or of a field component, in some region). This observable quantity is represented by an operator that in general has discrete spectrum.
presented in Weinberg's "The quantum theory of fields" vol.1...
For realistic systems with varying numbers of particles we build the Fock space as a direct sum of products of irreducible representations spaces. Then the sole purpose of quantum fields (=certain linear combinations of particle creation and annihilation operators) is to provide "building blocks" for interacting generators of the Poincare group in the Fock space. In this logic quantum fields are no more than mathematical tools.
... strictly speaking there are two distinct notions of particles in QFT. Local particle states correspond to the real objects observed by finite size detectors. ... On the other hand, global particle states...can be defined only under certain conditions... uniquely-defined particle states do not exist in general, in QFT on a curved spacetime.
and from a prior discussion in these forums:
Marcus quoting a prior post:
Marcus :
As a general rule the world is not made of particles, it is more correct and less confusing to say that it is made of fields. Unless I'm mistaken all or most of us at the Forum realize this?
Marcus' comment:
I don't count myself in this group. As Naty1's quote said "particles are the objects revealed by detectors, tracks in bubble chambers, or discharges of a photomultiplier." This means that particles (not some mysterious fields) are the objects studied by real experimental physics. If "curved spacetime" does not agree with the particle concept, so bad for the "curved spacetime".
And you will note, of course, these are not all in agreement...
My understanding is that when we make a measurement we are really poking at the wavefunction, which holds all the measurable information about a particle within it. When the measurement is made it causes any probabilities to collapse and take on a definite value.
Let us assume that a photon propagate in z direction.
For the z direction size, we can make it as small as possible (at least theoretically) by superpositioning a various wavelength photon states, which becomes a delta function in position space while it's just a plane wave in momentum space. Moreover, we can also make it small in x and y direction by superpositioning standing waves, thereby make it small.
If you express a photon as a wave packet, we can see that the wavefunction does not spread as time goes on.(for a mass zero particle while for electrons which as a finite mass it spreads out)
I think, if the principle of superposition in quantum mechanics is valid in all circumstances, we can make it localized in position space.
This already implies that this "duration" of the wavepacket defines some photon size. This is incorrect - besides that you do not take into account emission time uncertainties, there is no reasonable and accepted definition of photon size.
Can you? Really? So what defines your "photon size" then. You can get some superposition to get some kind of spatial localization of the real space photon wavefunction. If you then go ahead and calculate the energy density distribution of that photon, you will find that it is not locally connected to your real space wavefunction. It spreads and falls off as r^-7. Even worse you will find a non-zero detection probability away from the position where you "localized" your wavefunction. This probability also falls off as r^-7. So, which of these quantities defines size now?
For details, read the famous quantum optics bible "optical coherence and quantum optics" by Mandel and Wolf. In my edition chapter 12.11 discusses the problems of a meaningful localization of photons.
So while we are at it describing the 'size of a fundamental particle' and seeing there is no 'real' answer, at least no simple one, here is perhaps the craziest explanation of all. From Leonard Susskind whose work in black hole complementarity has won him widespread recognition, from THE BLACK HOLE WAR, Chapter 20:
[Susskind is relating here views of quantum field theory and string theory and while he uses 'atom' in the following description, he is could just as well have used 'particle' or 'photon'
Black Hole complementary was proposing something...radical. Depending on the state of motion an atom might remain a tiny microscopic object or it might spread out over an entire horizon of an enormous black hole...William Unruh showed that near a black hole horizon thermal and quantum jitters get mixed up in a odd way...
[This refers to the fact than a hovering observer and a free falling observer will 'read' very different radiations emanating from a black hole horizon. So the observed 'size' of a particle as well as the very existence of a particle is impacted by the presence of a cosmological horizon.]
Elementary particles are usually imagined to be very small objects. Quantum Field Theory begins by postulating particles that are so small they can be regarded as mere points in space. But that picture soon breaks down...
He compares such 'particles' to a rotating airplane propeller...where maybe all we can see is the hub, and maybe the inner portion of the blades...but progressively faster high speed photos would reveal additional extended structure...we can see further out on the rotating blades...see further quantum jitters!
...If experiments cannot tell us whether particles have outlying high-frequency, vibrating structures, then we have to appeal to out best theories...[so when you speed up the shutter] what you see is is that every piece of the string is fluctuating and vibrating so the new pictures looks more tangled and spread out...String theory and QFT share the property that things appear to change as the shutter speed increases. But in QFT, the objects do not grow...String theory is different and works more like [an airplane propeller]...as things slow down, more and more 'stringy' propellers come into view. They occupy an increasing amount of space so that the entire complex structure grows...To most [Quantum Field Theorists] the notion of growing particles with unbounded, jittering structures was extremely foreign...Ironically the only other person who had hinted at such a possibility...was Gerard't Hooft...his work also expressed a sense that things grow as they are examined with increasing time resolution.
Size isn't something with a precise physical meaning in this context. The size of a photon depends on how you measure it.
There are basically two (compatible) definitions of a photon. The usual one is that it is an eigenmode of the electromagnetic spectrum. In the strict sense an eigenmode does not change in time. Therefore in a cavity the eigenmode fills the whole cavity, and in free space a photon is an infinite plain wave (with no amplitude... but well...) Inside these eigenmodes energy is stored, and that is the real idea of a photon. The intensity of the eigenmode drops by a quantized amount a multiple of [tex]\hbar \omega[/tex] when the light field interacts with something else.
When particle physics are discussed they are usually discussed in Fourier space. One infinite plain wave of say protons interacts with another infinite plain wave of protons and they exchange an infinite plain wave of photons or other stuff. The reason why one sees the particle traces in collider experiments is that protons in colliders are a short bit of such a plain wave: a wave packet. But the main physics is captured by the plain wave description.
The interaction of a photon with the other elementary particles in the beams is point like, because its interaction does not depend on the momentum of the particles that it interacts width, leading to flat line in Fourier space and thus a delta peak in real space, for particles like neutrons which have an extend the interaction changes with the momentum of the interacting partners.
So in a way photons are point like (in their interaction) but in another way they can be really large, in a mathematical description as large as the universe.
Sorry if this reply is very technical, but we have gone a long way since the corpuscle theory of Newton, and this is all very much wave particle duality stuff.
I think it's worth pointing out that 'the photon' cannot be pictured as some sort of 'burst of oscillations' passing through the aether or as a little bullet. These seem to be the most popular visualisations.
Old habits die hard and, before finally biting the bullet and realising that it's much harder than that, people tend to hang on to the idea that QM is, in fact, just like the old mechanical system but with a few inconsequential tweaks. No. It's 180 degrees different and you just have to get over it. "Physical Interpretation"? Not possible.
Size defined as the apparture of your measuring device? Being build of the same stuff your detector is made off, it becomes complex to measure size of your own building block. It then is going to depend on how well (a part of) the wave will interact with your detector, transfering just enough energy to make a difference.
Sounds ever so much like a diffraction argument is creeping in, in disguise.
. . . . . Which leads to the conclusion that 'size' is just not a relevant property for a photon. That is, if it can be regarded as both a point and of infinite extent - haha.
The general picture that people seem to carry in their heads (and is how it's often drawn) is a a squiggle or short burst of oscillations, a few wavelengths long. I guess that fails in most respects.
