- 36,989
- 15,969
What is the size operator? If there is no such operator then the question is poorly defined. If there is such an operator then it is just a matter of plugging it into a single-photon Fock state to see what the result is.
We're into (piece of) string, perhaps?DaleSpam said:What is the size operator? If there is no such operator then the question is poorly defined. If there is such an operator then it is just a matter of plugging it into a single-photon Fock state to see what the result is.
My understanding is that when we make a measurement we are really poking at the wavefunction, which holds all the measurable information about a particle within it. When the measurement is made it causes any probabilities to collapse and take on a definite value.
photons certainly have different propties depending on the source.
I think it's worth pointing out that 'the photon' cannot be pictured as some sort of 'burst of oscillations' ... as a little bullet.
[This is analogous to what Susskind says with his 'propeller' description.Size isn't something with a precise physical meaning in this context. The size of a photon depends on how you measure it.
[yes to the first part, no to the second]the photon has size that interacts with the detector with pointlike properties, but while propagating before detection it has size that is described with wavelike properties distributed over the meter distance.
[see the following for some further clarification of this valid point.]'size' is just not a relevant property for a photon.
has a center that travels analogous to a classical point particle.
This position of a registration of a photon is a well defined physical quantity that can be measured, the position of a photon in the strict sense of an observable cannot even be defined in principle! For details, see
http://arnold-neumaier.at/ph.../position.html
If a photon were truly free, not interacting with any other particles, its PLANE wave would extend across the universe to the cosmological horizon.
http://en.wikipedia.org/wiki/Quantum_field_theory#Unification_of_fields_and_particlesTo account for the particle interpretation that phenomenon [double slit experiment] is called probability distribution but behaves according to Maxwell's equations. However, experiments confirm that the photon is not a short pulse of electromagnetic radiation; it does {MAY} not spread out as it propagates, nor does it divide when it encounters a beam splitter.
The photon seems to be a point-like particle since it is absorbed or emitted as a whole by arbitrarily small systems, systems much smaller than its wavelength, such as an atomic nucleus (≈10−15 m across) or even the point-like electron. Nevertheless, the photon is not a point-like particle whose trajectory is shaped probabilistically by the electromagnetic field, as conceived by Einstein and others. According to our present understanding, the electromagnetic field itself is produced by photons, which in turn result from a local gauge symmetry and the laws of quantum field theory
The "second quantization" procedure that we have outlined in the previous section takes a set of single-particle quantum states as a starting point. Sometimes, it is impossible to define such single-particle states, and one must proceed directly to quantum field theory. For example, a quantum theory of the electromagnetic field must be a quantum field theory, because it is impossible (for various reasons) to define a wavefunction for a single photon.
It has been shown that a photon can be arbitrarily "localized" in spacetime, i.e. there is not fundamental limit from the theory that forbids the complete localization of a one-photon state.
http://prl.aps.org/abstract/PRL/v79/i9/p1585_1
Edit: Localization is meant in the sense of arbitrarily small extent of its mode function as it travels with 'c', not that you localize it in a position eigenstate.
This right here is the hot button issue. The situation is not so straightforward in relativistic QM, partly because a single particle cannot be localized in a region smaller than a Compton wavelength.ZapperZ said:1. There is a position operator in QM, and that gives you the value of the position of the particle.
Bill_K said:This right here is the hot button issue. The situation is not so straightforward in relativistic QM, partly because a single particle cannot be localized in a region smaller than a Compton wavelength.
For particles with mass, the Newton-Wigner position operator is the accepted answer. However it is argued that for photons no position operator exists.
This is the key problem that makes the question itself ill-posed. The only way to answer questions about the size of something in QM is to have a size operator and calculate its expectation.ZapperZ said:3. There is no "size operator" yet well-defined in QM.
Of course there is. But to talk about the size of an object you have to talk about an object that has a size to begin with! Which leaves out all the elementary particles, including photons, since they are pointlike.DaleSpam said:Since there is no generally accepted size operator, I think that the OP is free to define one. Until they do, however, the question is incomplete and cannot be answered.
Bill_K said:Of course there is. But to talk about the size of an object you have to talk about an object that has a size to begin with! Which leaves out all the elementary particles, including photons, since they are pointlike.
Composite objects such as protons and neutrons have a size. For a proton it's the charge radius. A neutron's size can be defined in terms of its form factors. Nonspherical nuclei have rotational degrees of freedom, and for them the size can be defined in terms of the moment of inertia.
I'm seeing people confusing, say, the uncertainty in position as being the "size" of the object.
Bill_K said:To talk about the size of an object you have to talk about an object that has a size to begin with! Which leaves out all the elementary particles, including photons, since they are pointlike.
Have you seen the two-volume set by Bjorken and Drell? The first book is called "Relativistic Quantum Mechanics", while the second is "Relativistic Quantum Field Theory". That's the kind of distinction I was thinking of. In the first case (aka First Quantization) you treat the Klein-Gordon and Dirac Equation as direct relativistic generalizations of the Schrödinger equation - wave equations for the probability amplitude of a single particle. Thus "position operator" unambiguously refers to position of that single particle. Relativistic QFT (aka Second Quantization) is about multiparticle states from the word go, and negative energy states are replaced by antiparticles.Naty1 said:Is 'relativistic QM' the same 'relativistic QFT' of the Standard Model??...or should I be aware of some distinctions...
Then please write down the size operator for a particle that has a size.Bill_K said:Of course there is. But to talk about the size of an object you have to talk about an object that has a size to begin with!
Sure, it's just r2.DaleSpam said:Then please write down the size operator for a particle that has a size.
Bill_K said:Sure, it's just r2.The size of an object is its RMS radius, which is <r2>1/2.
But not for a particle, I said "composite object". Do this for an atomic electron and you will get the size of the atom, not the size of the electron. The size of a composite object such as a proton or nucleus is determined by the uncertainty in the position of its components.
I could accept that iff the object is located at the origin. However, since we cannot generally localize the object to the origin what this actually gives us is not just the size of the object but also the probability of finding it a certain distance from the origin. So this isn't a good candidate for a size operator.Bill_K said:Sure, it's just r2.The size of an object is its RMS radius, which is <r2>1/2.
If you had a valid size operator then you should simply be able to apply it to any particle's wavefunction to get the size of the particle. Whether it is a fundamental particle or not shouldn't matter.Bill_K said:But not for a particle, I said "composite object". Do this for an atomic electron and you will get the size of the atom, not the size of the electron. The size of a composite object such as a proton or nucleus is determined by the uncertainty in the position of its components.
There are no photons classically.Maui said:the 'classical' size of photons
DaleSpam said:There are no photons classically.
If a photon were a classical particle with some size then it wouldn't diffract at all.Maui said:You could state the same of all elementary particles, that's why 'classically' was in quotes denoting that size seems to play a practical role(e.g. the example of light diffraction in optics).
DaleSpam said:If a photon were a classical particle with some size then it wouldn't diffract at all.
Yes, for sure that's the majority conclusion, but there seems to be some controversy remaining about it, and maybe the difficulty has been overstated. There's a candidate position operator that was found in 1948 by Pryce,vanhees71 said:There's not even a well-defined position operator for a photon!
The three components of the Pryce operator cannot be simultaneously diagonalized, so that one cannot find states localized exactly at a given point in space. Newton and Wigner argued that this makes the photon non-localizable. However, we will show that although the commutator of the three components is non-vanishing, one can find states which are ”localized" within an arbitrarily small region.
Maui said:I agree but I didn't say a photon was a classical particle. Only that in some practical respects photon's wavelength attributes a physical size that appears to be a limit in photography and optics in general(microscopes, etc.).
Are you saying that a photon's wavelength has no associated width? How do you explain diffraction patterns below the 200 nm? It sounds like a contradiction to measure the practically measured wavelength of photons in nm and at the same consider the photon as not spatially extended.sophiecentaur said:Wavelength and size are not related.Diffraction calculations are based on an infinitely long wave train. The effect of one photon is just an individual occurrence. How can you say there is some sort of correspondence between the wavelength and any idea of 'size'? Any 'entity' that can have a 'single' wavelength needs to have infinite extent. An entity with very limited extent needs a very large range of associated wavelengths. That's the (Fourier) relationship between temporal and frequency domains (or the equivalent spatial thing), surely.
It seems most physicists think of photons as part of the EM field which is of infinite extent and 'photons' with definite and detectable properties as excitations of that field upon measurement.Thinker007 said:I was listening to a physics professor lecturing on QM and he raised the question "How big is a photon?" and indicated it had arisen during his PhD defense.
He than began to discuss the accurately known frequency and wavelength of a laser emitted photon (and thus accurately known momentum) in the context of the uncertainty principle.
You need to go back to elementary diffraction theory and see what it is really saying. There is nothing to do with 'width' of the waves in the calculation of the interference between two slits. The pattern is related to the spacing of the slits and the wavelength (longitudinal variation). There is nothing 'special' about the wavelength of 200nm; the same theory applies to 200km or 2nm. The 'lateral extent' of a photon, as a concept, is meaningless because there is a probability that it can be measured over the whole area of a 100m sphere after it has 'travelled' for just 300ns from a point source. This is true for whatever wavelength of EM we are considering.Maui said:Are you saying that a photon's wavelength has no associated width? How do you explain diffraction patterns below the 200 nm? It sounds like a contradiction to measure the practically measured wavelength of photons in nm and at the same consider the photon as not spatially extended.
After all the wavelength of photons is a real measureable phenomenon determining properties of the EM field(colors, visible light, etc.).
But in practice there is something special in that photons at 200 nm are already in the UV portion of the EM field. Ordinary light microscopes hit the diffraction limit of visible light just above the 200 nm limit or at 1 PHz. AFAIK 200-300 nm is exactly the diffraction limit of visible light.sophiecentaur said:There is nothing 'special' about the wavelength of 200nm; the same theory applies to 200km or 2nm. The 'lateral extent' of a photon, as a concept, is meaningless because there is a probability that it can be measured over the whole area of a 100m sphere after it has 'travelled' for just 300ns from a point source. This is true for whatever wavelength of EM we are considering.
This seems to imply that my impression was correct in stating that -When talking about the interaction with matter, it is more precise to talk in terms of frequency. The energy of a photon is normally given by E =hf, with good reason. The wavelength, locally, is not actually going to be the same as the free space wavelength because, by definition, the photon is not interacting in free space but in the presence of matter. The frequency is going to be unchanged but what actual value of wavelength can you give your photon? (certainly not c/f)
Maui said:It seems most physicists think of photons as part of the EM field which is of infinite extent and 'photons' with definite and detectable properties as excitations of that field upon measurement.
