PHP Static Variables: Why Doesn't It Reset?
Homework Helper
Insights Author
MHB
The code
<?php
function myTest() {
static $x = 0;
echo $x;
$x++;
myTest();
echo "<br>";
myTest();
echo "<br>";
myTest();
is supposed to generate
My question is this: If we declare $x = 0 in the function then why doesn't it reset to 0 every time we run the function?
-Dan
Hey Dan,
A static variable exists only in a local function scope, but it does not lose its value when program execution leaves this scope. [m]$x[/m] is initialized only in the first call of the function and every time the myTest() function is called, it will print the value of [m]$x[/m] and increment it. :)
MarkFL said:
Hey Dan,
Thank you. But couldn't we do the same thing by declaring $x as a global variable?
-Dan
-Dan
Yes, you could write:
PHP:
function increment_x()
	global $x;
	echo $x;
	$x++;
$x = 0;
increment_x();
echo "<br>";
increment_x();
echo "<br>";
increment_x();
For the record, a static and a global variable are the same thing as far as life time is concerned (called static duration).
The difference is that a static variable has limited visibility - it can only be accessed within the scope in which it has been defined (that is, up to the enclosing '}').
