Physically, what is the difference between systems of ODEs and PDEs?
ODEs describe physical phenomena that depend on a single independent variable, such as time, exemplified by classic problems like harmonic oscillators and radioactive decay. In contrast, PDEs model systems with multiple independent variables, such as temperature distribution on a plate or wave propagation in three-dimensional space. The distinction lies in the dimensionality of the variables involved; ODEs are one-dimensional while PDEs are multi-dimensional. However, when the degrees of freedom increase significantly, both ODEs and PDEs can effectively describe the same physical systems. Ultimately, the choice between using ODEs or PDEs depends on the complexity and nature of the system being modeled.
zheng89120
What kind of systems do ODEs describe?
What kind of systems do PDEs describe?
ODEs are used in case of a physical phenomena which can be modeled with functions of a variable only.
PDEs are used in case of a physical phenomena which can be modeled with functions of not only a variable, but several.
PDEs occur usually in dimension >1.
ODE's: problems with one independent variable (like time). Classic 1-dimensional F = ma problems (x depends on t), harmonic oscillators, transient response in a circuit (I depends on t), radioactive decay.
PDE's: problems where there is more than 1 independent variable. Temperature distribution on a plate (depends on x, y, and time), waves on a string, plate or sphere (the amplitude can depend on x,y,z and t), electric potential on a conductor... you get the idea.
If
<br /> u:[0,1]\times\mathbb{R}\to\mathbb{R}<br />
is some function that is supposed to satisfy
<br /> \partial_t u(x,t) = -\partial_x^2 u(x,t)<br />
that is a PDE.
If
<br /> u:\{1,2,\ldots, N\}\times\mathbb{R}\to\mathbb{R}<br />
<br /> \partial_t u(n,t) = -\frac{1}{N^2}\big(u(n+1,t) - 2u(n,t) + u(n-1,t)\big),\quad\quad (u(0,t)=0,\; u(N+1,t)=0)<br />
that is an ODE system.
When the amount of degrees of freedom is very large, physically they describe the same thing, because physically there is no difference in having infinite degrees of freedom or a very large but finite amount of degrees of freedom. You can describe the same physical systems with different mathematical models such that some are ODEs and some are PDEs.
  • · Replies 0 ·
