Physics Elastic Collision Question
A physics problem involving a head-on elastic collision between a 0.060 kg tennis ball and a 0.090 kg ball is discussed, focusing on the conservation of momentum and kinetic energy equations. The initial speeds are 2.5 m/s and 1.15 m/s, respectively. The solution process involves setting up two equations to find the final velocities after the collision, leading to confusion about handling two unknowns. Guidance is provided on correctly manipulating the equations and applying the quadratic formula, ultimately confirming the final speeds of 0.88 m/s for the tennis ball and 2.23 m/s for the other ball. The discussion emphasizes the importance of not omitting terms and correctly solving quadratic equations in physics problems.
eo1989
a .060kg tennis ball, moving with a speed of 2.5 m/s, collides head-on with a .09kg ball initially moving away from it at a speed of 1.15m/s. Assuming a perfect collision, what are the speed and direction of each ball after the collision
MaVa + MbVb = MaV’a + MbV’b (conservation of momentum)
½MaV²a +½ MbV²b = ½MaV’²a + ½MbV’²b (?)
I plugged in the numbers into both equations and got...
1. (.06kg)(2.5m/s) + (.09kg)(1.15m/s) = (.06kg)(V1f) + (.09kg)(V2f)
and...
2. 1/2(.06kg)(2.5m/s)^2 + 1/2(.09kg)(1.15m/s)^2 = 1/2(.06kg)(V1f)^2 + 1/2(.09kg)(V2f)^2
i then started to solve the second equation...
.25 = 1/2(.06kg)(V1f)^2 + 1/2(.09kg)(V2f)^2
this is where I became confused...I got rid of the first part (1/2(.06kg)(V1f)^2) and just solved the second part [ 1/2(.09kg)(V2f)^2]
.25 = 1/2(.09kg)(V2f)^2
.25 = .05(V2f)^2
.25/.05 = (V2f)^2
5 = (V2f)^2
sqrt(5) = V
2.24 = V
I then went back and plugged 2.24 into the first equation ...and then rearranged the equation:
(.06kg)(2.5m/s) + (.09kg)(1.15m/s) = (.06kg)(V1f) + (.09kg)(V2f) =
- (.06kg)(V1f) = (.09kg) (2.23) - (.2523)
-.06kg (V1f) = -.0528
(-.0528) / -(.06) = V1f
v= .88
I know the answers are supposed to be .88 and 2.23 (back of the book), but it seems like I just randomly solved this (I don't get exactly how i got this), is this right?
I really need to pass physics (architecture major) but i don't understand it, any help would be greatly appreciated.
"this is where I became confused...I got rid of the first part (1/2(.06kg)(V1f)^2) and just solved the second part [ 1/2(.09kg)(V2f)^2]"
You can not do that. You can not just omit a term from an equation.
You have two equations with two unknowns.
Solve the first equation for v1f and substitute the expression you get in the second equation. ehild
when you say to solve the first equation for V1f do you mean:
.2535 = (.06kg)(V1f) + (.09kg)(V2f)
.06kg(V1f) = .2535 + .09kg(V2f)
.06kg/.06(V1f) = .2535/.06 + .09kg/.06(V2f)
V1f = 4225 + 1.5 V2f
It is good up to here, but the next steps are wrong:
Check it.
ehild
can you please just get me going in the right direction i can't figure out how to solve it because of the two unknowns
Lets start from here: 0.2535=0.06*v1f+0.09*v2f
You want v1f be alone on one side of this equation. Subtract 0.09*v2f from both sides. Do it now.
ehild
is this right...
-.06(V1f) = .09 (V2f) - .2535
eo1989 said:
is this right...
-.06(V1f) = .09(V2f) - .2535
Yes. Now get rid of the coefficient of v1f: divide both sides by -0.06.
i got this:
V1f = - 1.5 (V2f) + 4.225
...but, how do i plug this into the second equation?
1/2(.06kg)(2.5m/s)^2 + 1/2(.09kg)(1.15m/s)^2 = 1/2(.06kg)[(-1.5)(V2f) +4.225)^2 + 1/2(.09kg)(V2f)^2
.25 = 1/2(.06kg)[(1.5)(V2f) + 4.225]^2 + 1/2(.09kg)(v2f)^2
...would this be right?
There should be a - sign in front of (1.5) (v2f).
Keep at least 4 significant digits on the left side of the equation.
It is not needed to use units in the equation. If you do, use them everywhere.
ehild
.2470 = 1/2(.06)[-(1.5)(V2f) + 4.225]^2 + 1/2(.09)(v2f)^2
.2470 = .03(-(1.5)(V2f) + 4.225)^2 + .045(V2f)^2
.2470 = .03((-1.5V2f) + 4.225)^2 + (.045V2f)^2
Is this right so far?
Why do you square 0.045? It has to be outside the parentheses.
ehild
.2470 = .03((-1.5V2f) + 4.225)^2 + .045(V2f)^2
Do I distribute the .03 and .045, or am I missing something?
You can distribute a sum: a(b+c) = ab+ac. (v2f)^2 is not a sum.
ehild
Oh, I see. So would I just leave the equation as is? .2470 = .03((-1.5V2f) + 4.225)^2 + .045(V2f)^2
How do I go about answering when V2f is in there twice? Would I have to subtract one of them like so...
.2470 - .045(V2f)^2 = .03((-1.5V2f) + 4.225)^2
Sorry for all the questions I'm just really confused about this problem.
You can do that but it has not much sense.
First evaluate the square. Apply the identity: (a+b)^2=a^2+2ab+b^2
Next distribute 0.03.
Arrange the equation so one side is 0. Group like terms.
It is a quadratic equation. Use the quadratic formula to solve it.
You can find step-by step explanations for solving equations at
http://www.sosmath.com/algebra/solve/solve0/solve0.html.
ehild
this is what I have so far:0 = 6.75(V1f)^2 + 53.55 + .045(V2f)^2 - .2470
Not to be so negative...but I think I did something wrong
It is not correct.
Evaluate the square by using the identity (a+b)^2=a^2+2ab+b^2: a=*-1.5 (v2f), b=4.225.
(-1.5(V2f) + 4.225)^2= 2.25 (v2f)^2-3(4.225) (v2f)+4.225^2=2.25 (v2f)^2-12.675 (v2f)+17.8506.
This expression is multiplied by 0.03. Distribute.
ehild
After distributing I got:
.0675 V2f^2 - .3802 V2f + .5355
The original equation was:
I added .045 V2f^2 to .0675 V2f^2 and then subtracted .2470 from .5355
and got:
.1075 V2f^2 - .3802 V2f + .2885
Using the quadratic formula:
.3802 +/- √-.3802^2- 4 (.1075) (.2885) / 2(.1075)
adding:
.3802 + √.1445 - .1240 / .215
.3802 + √.0205 / .215
.3802 + .1431 / .215
.5233 / .215 = 2.43
subtracting:
.3802 - .1431 /.215
.2371 / .215 = 1.10
Did I do something wrong because my book says the answers should be .88 and 2.23
and got:
You made a mistake when adding .045 V2f^2 to .0675 V2f^2.
0.045 +0.0675 = 0.1125, so the quadratic equation is
0.1125 V2f^2 - 0.3802 V2f + 0.2885=0
wrong.
quadratic equation: ax^2+bx+c=0
quadratic formula:
<br /> <br /> v2f=\frac{-b\pm\sqrt{b^2-4ac}}{2a}}
we have:
a=0.1125
b=-0.3802
c=0.2885
<br /> v2f=\frac{0.3802\pm\sqrt{(-0.3802)^2-4 \cdot0.1125\cdot0.2885)}}{2\cdot0.1125}=\frac{0.3802\pm\sqrt{0.1445-0.1298}}{0.225}=\frac{0.3802\pm0.1212}{0.225}
One root is 2.23, the other is 1.15, just the same as if the balls did not collided.
So v2f= 2.23 m/s. Find v1f.
ehild
Okay, I plugged the numbers in and sure enough it was .88. Thank you very much for helping me with this problem. I'll review this problem because I m sure it will be on my test Tuesday.Once again, thank you.
  • · Replies 17 ·
  • · Replies 17 ·
