Physics Elastic Collision Question
21 replies · 6K views
eo1989
a .060kg tennis ball, moving with a speed of 2.5 m/s, collides head-on with a .09kg ball initially moving away from it at a speed of 1.15m/s. Assuming a perfect collision, what are the speed and direction of each ball after the collision
MaVa + MbVb = MaV’a + MbV’b (conservation of momentum)
½MaV²a +½ MbV²b = ½MaV’²a + ½MbV’²b (?)
I plugged in the numbers into both equations and got...
1. (.06kg)(2.5m/s) + (.09kg)(1.15m/s) = (.06kg)(V1f) + (.09kg)(V2f)
and...
2. 1/2(.06kg)(2.5m/s)^2 + 1/2(.09kg)(1.15m/s)^2 = 1/2(.06kg)(V1f)^2 + 1/2(.09kg)(V2f)^2
i then started to solve the second equation...
.25 = 1/2(.06kg)(V1f)^2 + 1/2(.09kg)(V2f)^2
this is where I became confused...I got rid of the first part (1/2(.06kg)(V1f)^2) and just solved the second part [ 1/2(.09kg)(V2f)^2]
.25 = 1/2(.09kg)(V2f)^2
.25 = .05(V2f)^2
.25/.05 = (V2f)^2
5 = (V2f)^2
sqrt(5) = V
2.24 = V
I then went back and plugged 2.24 into the first equation ...and then rearranged the equation:
(.06kg)(2.5m/s) + (.09kg)(1.15m/s) = (.06kg)(V1f) + (.09kg)(V2f) =
- (.06kg)(V1f) = (.09kg) (2.23) - (.2523)
-.06kg (V1f) = -.0528
(-.0528) / -(.06) = V1f
v= .88
I know the answers are supposed to be .88 and 2.23 (back of the book), but it seems like I just randomly solved this (I don't get exactly how i got this), is this right?
I really need to pass physics (architecture major) but i don't understand it, any help would be greatly appreciated.
"this is where I became confused...I got rid of the first part (1/2(.06kg)(V1f)^2) and just solved the second part [ 1/2(.09kg)(V2f)^2]"
You can not do that. You can not just omit a term from an equation.
You have two equations with two unknowns.
Solve the first equation for v1f and substitute the expression you get in the second equation. ehild
when you say to solve the first equation for V1f do you mean:
.2535 = (.06kg)(V1f) + (.09kg)(V2f)
.06kg(V1f) = .2535 + .09kg(V2f)
.06kg/.06(V1f) = .2535/.06 + .09kg/.06(V2f)
V1f = 4225 + 1.5 V2f
It is good up to here, but the next steps are wrong:
Check it.
ehild
can you please just get me going in the right direction i can't figure out how to solve it because of the two unknowns
is this right...
-.06(V1f) = .09 (V2f) - .2535
i got this:
V1f = - 1.5 (V2f) + 4.225
...but, how do i plug this into the second equation?
1/2(.06kg)(2.5m/s)^2 + 1/2(.09kg)(1.15m/s)^2 = 1/2(.06kg)[(-1.5)(V2f) +4.225)^2 + 1/2(.09kg)(V2f)^2
.25 = 1/2(.06kg)[(1.5)(V2f) + 4.225]^2 + 1/2(.09kg)(v2f)^2
...would this be right?
There should be a - sign in front of (1.5) (v2f).
Keep at least 4 significant digits on the left side of the equation.
It is not needed to use units in the equation. If you do, use them everywhere.
ehild
.2470 = 1/2(.06)[-(1.5)(V2f) + 4.225]^2 + 1/2(.09)(v2f)^2
.2470 = .03(-(1.5)(V2f) + 4.225)^2 + .045(V2f)^2
.2470 = .03((-1.5V2f) + 4.225)^2 + (.045V2f)^2
Is this right so far?
.2470 = .03((-1.5V2f) + 4.225)^2 + .045(V2f)^2
Do I distribute the .03 and .045, or am I missing something?
Oh, I see. So would I just leave the equation as is? .2470 = .03((-1.5V2f) + 4.225)^2 + .045(V2f)^2
How do I go about answering when V2f is in there twice? Would I have to subtract one of them like so...
.2470 - .045(V2f)^2 = .03((-1.5V2f) + 4.225)^2
Sorry for all the questions I'm just really confused about this problem.
You can do that but it has not much sense.
First evaluate the square. Apply the identity: (a+b)^2=a^2+2ab+b^2
Next distribute 0.03.
Arrange the equation so one side is 0. Group like terms.
It is a quadratic equation. Use the quadratic formula to solve it.
You can find step-by step explanations for solving equations at
http://www.sosmath.com/algebra/solve/solve0/solve0.html.
ehild
this is what I have so far:0 = 6.75(V1f)^2 + 53.55 + .045(V2f)^2 - .2470
Not to be so negative...but I think I did something wrong
It is not correct.
Evaluate the square by using the identity (a+b)^2=a^2+2ab+b^2: a=*-1.5 (v2f), b=4.225.
(-1.5(V2f) + 4.225)^2= 2.25 (v2f)^2-3(4.225) (v2f)+4.225^2=2.25 (v2f)^2-12.675 (v2f)+17.8506.
This expression is multiplied by 0.03. Distribute.
ehild
After distributing I got:
.0675 V2f^2 - .3802 V2f + .5355
The original equation was:
I added .045 V2f^2 to .0675 V2f^2 and then subtracted .2470 from .5355
and got:
.1075 V2f^2 - .3802 V2f + .2885
Using the quadratic formula:
.3802 +/- √-.3802^2- 4 (.1075) (.2885) / 2(.1075)
adding:
.3802 + √.1445 - .1240 / .215
.3802 + √.0205 / .215
.3802 + .1431 / .215
.5233 / .215 = 2.43
subtracting:
.3802 - .1431 /.215
.2371 / .215 = 1.10
Did I do something wrong because my book says the answers should be .88 and 2.23
and got:
You made a mistake when adding .045 V2f^2 to .0675 V2f^2.
0.045 +0.0675 = 0.1125, so the quadratic equation is
0.1125 V2f^2 - 0.3802 V2f + 0.2885=0
wrong.
quadratic equation: ax^2+bx+c=0
quadratic formula:
[tex] <br /> v2f=\frac{-b\pm\sqrt{b^2-4ac}}{2a}}[/tex]
we have:
a=0.1125
b=-0.3802
c=0.2885
[tex] v2f=\frac{0.3802\pm\sqrt{(-0.3802)^2-4 \cdot0.1125\cdot0.2885)}}{2\cdot0.1125}=\frac{0.3802\pm\sqrt{0.1445-0.1298}}{0.225}=\frac{0.3802\pm0.1212}{0.225}[/tex]
One root is 2.23, the other is 1.15, just the same as if the balls did not collided.
So v2f= 2.23 m/s. Find v1f.
ehild
Okay, I plugged the numbers in and sure enough it was .88. Thank you very much for helping me with this problem. I'll review this problem because I m sure it will be on my test Tuesday.Once again, thank you.
