Physics Heat Ice Water Mixture Question And Find Initial Mass Of Ice
The discussion centers on calculating the initial mass of ice in an ice-water mixture contained in a calorimeter. The total mass of the mixture is 180g, with a 100g aluminum calorimeter. When 35g of steam at 100°C condenses, the temperature of the mixture rises to 50°C. Using the heat capacities of water (4.2 x 10^3 J/kg°C) and ice (2.1 x 10^3 J/kg°C), along with the latent heat of vaporization (2.3 x 10^6 J/kg), the final calculation reveals that the initial mass of ice was 138g.
  • Understanding of heat transfer principles, specifically Q = mcΔT and Q = mL
  • Knowledge of specific heat capacities for water and ice
  • Familiarity with the concept of latent heat of vaporization
  • Basic algebra for solving equations involving mass and energy
  • Study the concept of calorimetry and its applications in thermal energy calculations
  • Learn about the specific heat capacities of different materials
  • Explore the principles of phase changes and latent heat
  • Practice solving problems involving energy conservation in thermal systems
This discussion is beneficial for students studying thermodynamics, physics educators, and anyone involved in calorimetry or thermal energy calculations.
justinh8
An ice-water mixture has a mass of 180g and is contained in a 100g aluminum calorimeter When 35g of steam at 100 degree Celsius is condensed in the water, the temperature rises to 50 degree Celsius. How much ice was in the container initially?
The heat capacity of water is 4.2 x 10^3
The heat capacity of ice is 2.1 x 10^3
The latent heat of vaporization is 2.3 x10^6
Q =mc delta t
Q = mLv
I didnt really have an attempt because i didnt know where to start, all i did was find the Q =mLv
Q =mc delta t
Q = mLv
An ice/water mixture will be at 0 degrees.
What you have here is:
Some water heated up from 0 to 50,
Some ice melted, then heated up form 0 to 50
Some aluminium heated up from 0 to 50
Some steam condensed, then cooled from 100 to 50.
The first 3 required heat to happen,
The fourth gave up heat while happening.
The heat given up and the heat required are the same.
As for masses, you know the Al and the steam. The water and ice total 180.
Ya I understand that part but how do i find the energy required for the Ice and Water if i don't have a mass? but only a mass for both of them together?
Once the ice melts, you have 180g of water at 0 degrees.
100g of Al and 180g of water need just so much energy to reach 50 degrees.
the extra energy from the steam must have been used to melt the ice; so you can calculate how much ice there was.
Oh, Ok i think i got it, i ended up with 138g of ice in the mixture initially which is correct according to the answers. Thanks!
10K
