Physics Help, Could someone check my work test coming up soon
9 replies · 9K views
Ion1776
1. A parent pushes a baby stroller from home to daycare along a level road with a force of 38 N directed at an angle of 30° below the horizontal. If daycare is 0.83 km from home, how much work is done by the parent?
(38N)(cos(-30))(.83km)=27.21 J
2. You have a 0.750 kg picture frame on a mantle 1.50 m high. How much work was required to lift the frame from the ground to the mantle?
0.750*9.80=7.35N(1.50)=11.025 J
3. You lower a 2.50 kg textbook (remember when textbooks used to be made out of paper instead of being digital?) from a height of 1.81 m to 1.50 m. What is its change in potential energy?
1.81-1.50=.31
(2.50kg)(9.80)(.31)
=7.60 J
Please if someone could confirm these by working them out, please be sure of the answer before responding, Thanks so much
In 1, a Joule is a Newton meter. So check your units...
In 2, you are loose with your one "equation". The LHS does not equal the middle, but it looks like you got the right answer anyway. You should show all terms and units on each side of your equation.
3 looks okay.
On #1 Should .83 Km be 830 meters, if that is the case will it make the question correct.
(38N)(cos(-30))(830m)= 27309.4568 J?
Need multiple opinions on these physics problems
(38N)(cos(-30))(830m)=7309.4568 J?
1.81-1.50=.31
(2.50kg)(9.80)(.31)
=7.60 J
The left hand side is correct, but the right hand side is wrong. You might want to check that you punched the numbers into your calculator correctly
The orange part is correct. You should note that the blue part is not equal to the orange part, so it is incorrect to state that they are.
1.81-1.50=.31
(2.50kg)(9.80)(.31)
=7.60 J
Has the textbook gained, or lost potential energy?
are the answers correct for 2 and 3?
On 2 what to with the blue side
lost potential energy on 3 right?
So should the answer be (2.50)(9.80)(-.31)=-7.595
So should the answer be (2.50)(9.80)(-.31)=-7.595 FOR #3
