Physics Major Schedule: Modern vs. Classical Mechanics
epislon58
Should I take modern physics and classical mechanics in the same semester? Or is that a bad idea. And my concerns are mostly about needing to understand stuff from modern to understand classical. Thank you
They are quite independent - classical mechanics will teach you how to work with Lagrangian's and Hamiltonian's which are required for quantum mechanics; you will do a lot of partial derivatives, and hopefully learn about the calculus of variations.
Modern physics will cover a lot of - surprise! - modern physics! But it will emphasize the _physics_ and not the abstract calculations that are required for analytical mechanics or quantum mechanics. You should learn about quanta from the earliest physical experiments such as the photoelectric effect, the idea of photons, how a laser works, atomic spectra, electronic transitions, etc -- then some nuclear physics (E=mc^2 and more), and some relativity. It can be a great class.
I don't see a problem taking both as long as you are not otherwise overloaded.
It's typical for a physics student to concurrently take classes that focus on completely different areas and scales. It can be a bit mind-bending but you'll adjust.
Thank you I appreciate your input, I just hope my schedule won't be too overwhelming. I am adaptable tho so I should be fine!
how about taking a quantum mechanics class, nuclear and elementary particle , Atomic, Molecular, and Condensed Matter physics class at the same time?
Atomic physics, Particle physics and Condensed Matter physics are given in the same semester, atleast in my country.
