Physics maths calculus charge calculations
Charge (q) can be calculated by integrating current (i) over time. For a constant current of 5mA over 0.03 seconds, the charge is 0.00015 coulombs. When the current is given as a function i=60t^2, integration from 0 to 0.03 seconds yields a charge of 0.0000054A, which converts to 0.000000162 coulombs. The discussion emphasizes the importance of correctly interpreting units, particularly when dealing with amperes and milliamperes. Proper integration is crucial for accurate charge calculations in both scenarios.
electro 1982
charge (q) in coulombs, can be calculated byt integrating the current (i) in amperes (A) with respect to time. determine the charge on a capacitor as a result of current flowing for 0.03 seconds if:
a. the current is a constant 5mA (0.005A)
b. the current is a function of time given by i=60t^2
i believe q=(i)(t)
if current (i) is integrated with respect to time = it^0+1/0+1 = q=i*t^1 = q=(i)(t)
a. i believe to be q=0.005*0.03=0.00015 coulombs
b. however i assume that i need to integrate i=60t^2
but the A/mA is confusing me i think
should it be 20t^3 or 0.02t^3?
and to find the charge do i just multipli the answer by t ? or is there any further calculation needed?
any help would be appreciated
i
I would integrate the function as it's given to you.
(1) \int_{0}^{0.03} 0.005 dt
(2) \int_{0}^{0.03} 60t^2 dt
For (1), it becomes clear by integration that it is indeed just I*t, the integration of a constant function multiplied by the elapsed time.
For (2), I think you're on the right track. I wouldn't amend 60 to be 0.06 since the whole functional expression (60t2) is your current. It would be useful if they let you know if that expression is A or mA, but since there is no information otherwise, I would assume it to be A. You can also compare your answers for the two questions if that makes it at all clearer.
sorry i forgot to add that to the question part b. is to calculate current in mA
So that functional expression is in mA? In that case, I'd still do the integration like normal, just convert afterward. (you integrate in mA, so you have mA*s = mC...now convert to C)
so i should work with 20t^3
(20*0.03^3)-(20*0^3)=0.00054-0=0.00054mA
=0.0000054A
q=0.0000054*0.03=0.000000162coulombs
thank you for your comments
