Physics Problem with Spring Constant and Kinetic Friction
The discussion centers on calculating the ratio of the spring constant to the kinetic friction coefficient for a cubic object weighing 36 kg, moving at a steady speed of 1.3 m/s, with a spring stretching 3.4 cm. The relevant equations include Fk = μkN, Fspring = -kx, and F = ma. The final ratio is determined to be 10,376.47, calculated using the normal force (N = 36 kg * 9.8 m/s²) and the displacement (x = 0.034 m). Units should be included in the final answer for clarity.
  • Understanding of Newton's laws of motion
  • Knowledge of spring mechanics and Hooke's Law
  • Familiarity with kinetic friction concepts
  • Ability to perform unit conversions in physics
  • Study Hooke's Law and its applications in mechanics
  • Learn about kinetic friction and its coefficient calculations
  • Explore the relationship between force, mass, and acceleration in physics
  • Practice solving problems involving forces and motion with varying parameters
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of spring systems and friction in mechanical contexts.
Q7heng
A person attaches a spring to an cubic object that weighs 36kg and pulls this object along a table made of material X horizontally with a steady speed of 1.3m/s. The spring stretches a distance of 3.4cm. Find the ratio of the spring constant to the kinetic friction coefficient.
I suppose FkkN
Fspring=-kx
F=ma
Not sure if any other ones are needed, but I couldn't find a way to solve this and get a reasonable answer.
What does this information tell you?
I'm not sure, but I tried to apply it to the F=MA formula... Am I on track?
Okay, we'll work it through that way: "Steady speed" means what in terms of "A?"
Acceleration=0 at steady speed, but the trouble I'm having is converting everything to Newtons, since spring constant is Newtons/meter, and kinetic friction coefficient is Force of Kinetic Friction/Normal Force. The problem didn't give any units related to those calculations, maybe there is a way to convert it but I have yet figured it out/learned it.
Q7heng said:
I suppose Fk=μkN
This looks perfectly useful. What's the normal force?
Q7heng said:
Fspring=-kx
Nothing wrong with this.
You aren't required to generate a numerical answer for every problem on the planet. Sometimes it's just a matter of coming up with a symbolic expression.
Q7heng said:
Acceleration=0
FkkN
Fspring=-kx
F=ma
All good so far. Now, what is the relationship between F, Fk and Fspring?
F=Fk+Fspring right?
If that is so then:
F=MA, A=0, and F=0
So 0=Fk+Fspring
0=-kx+μkN
kx=μkN
k/μk=N/x, since we are trying to find the ratio between the spring constant and the kinetic friction coefficient
Since N, normal force, is 36*9.8N right now, and x, distance, is 3.4cm or 0.034m right now, then it is 36*9.8/0.034=10,376.47, which is the ratio of spring constant to kinetic friction, is that correct?
Q7heng said:
F=Fk+Fspring right?
If that is so then:
F=MA, A=0, and F=0
So 0=Fk+Fspring
0=-kx+μkN
kx=μkN
Yes, that all looks right. But you should include the units in the answer.
Thanks!
  • · Replies 16 ·
  • · Replies 36 ·
