Physics Projectile Motion Question
A fireman needs to determine two angles to effectively spray water from a hose at a fire. The water exits the hose at a speed of 28 m/s, and gravity is set at 9.81 m/s². The discussion emphasizes breaking down the initial velocity into horizontal and vertical components, using trigonometric functions to find the angles. Participants suggest using algebraic equations and energy principles to isolate variables and derive the angles. Ultimately, the problem-solving approach involves substituting known values into the equations to find the correct angles for the projectile motion.
pollytree
The question is: A fireman at point A wishes to put out a fire at B. Determine the two possible angles \theta1 and \theta2 at which this can be done. The water flows from the hose at vA=28m/s and the value for gravity is 9.81m/s2
[PLAIN]http://users.adam.com.au/shortround/pm.JPG
<br /> v = v_0 + a t<br />
<br /> x = x_0 + v_0 t + (1/2) a t^2<br />
<br /> v^2 = v_0^2 + 2 a \Delta x<br />
We need to separate vA into the horizontal and vertical components. But to do this we need to know either \theta or one of the components, but we do not know either.
I have spent a long time on this question and have not got very far. I have tried using trial and error, but I've had no luck. I know that there must be a better way to do it. The angle could be above or below the horizontal. From memory the two angles must be complementary, but I'm not entirely sure on that.
If anyone could just give me a couple of hints to get me going, I would be very grateful.
Ok, first thing you are trying to find the 2 angles. So you can't know them. But you can solve the question using algebraic equations. (Sorry I am new to this so I may not be really clear)
But you do know that one component of the velocity will be (the horizontal one) will be V (velocity) times the cosine of the angle. The vertical component will be the the velocity times the sinus of the angle. There you go you now have divided the speed into its components...
you know every other variable except for the sinus and the co-sinus, so you can solve for (by plugging the components into the relevant equations) them and hopefully get the angle by using arcsin(value of sinus).
I understand that the initial horizontal velocity is 28cos\theta and the vertical component is 28sin\theta.
As iraten said I could then substitute it into <br /> <br /> v^2 = v_0^2 + 2 a \Delta x<br /> <br />, but we do not know the final velocity when the water hits the wall. In the horizontal direction a=0 and in the vertical direction a=9.81m/s2. But I am still unsure on how all of this comes together. Any more help would be great!
you can use the energy equation to find the final velocity: mgh = 0.5mv^2, write down all the equations you can, then try to find a way to isolate sin (remember sin^2+cos^2 = 1)
In my textbook they have an example where the initial velocity is 24m/s and they give the answer as \theta=24.8o below the horizontal and \theta=85.1o above the horizontal.
Okay using v^2 = v_0^2 + 2 a \Delta x I found the final velocity in the y direction to be: ((24sin\theta)2+(2*(-9.81)*6))1/2 = ((24sin\theta)2-117.72)1/2
By putting this back into v = v_0 + a t, with v0=24sin\theta, I found the time was t=1.106 seconds. Finally I put this into x = v_0 t + (1/2) a t^2 and got a value of \theta=51.57o. But this was not the value given by the textbook.
What have I done wrong?
Also iratern, thanks for your help. I am slowly getting there. I have been doing much harder problems than this one fine. I don't know why I just can't get this one :S
sorry I haven't worked out the problem, I would but it's late here so I am on the sleepy side... But it's probably in the algebra or in the simple math keep on it...
In the problem x, y, vo and g is given. You have to find θ.
You know that
x = vo*cosθ*t ..(1) and
y = vosinθ*t - 1/2(g)t^2...(2)
So t = x/(vo*cosθ) and
y = vosinθ*x/vocosθ - 1/2(g)(x/vocosθ)^2
y = x*tanθ -1/2g*x^2*sec^2(θ)/vo^2
y = x*tanθ -1/2g*x^2*[1 + tan^2(θ)]/vo^2
Substitute the values and solve for tanθ.
Thanks rl.baht! I had just managed to work it out using the same method :)
  • · Replies 21 ·
  • · Replies 53 ·
