What Is the Correct Angle Between Two Vectors If Their Cross Product Is Known?
The discussion centers on determining the angle between two vectors A and B given their cross product. The calculated angle is approximately 37 degrees, derived from the relationship between the magnitudes of the vectors and the sine of the angle. However, it is noted that both 37 degrees and its supplementary angle, 143 degrees, satisfy the sine condition, leading to confusion about which angle is the correct answer. The consensus is that without additional information about the orientation of the vectors, both angles could be valid. Ultimately, the conclusion is that both angles should be considered acceptable solutions.
Tarrok
Two vectors A and B have magnitude A = 3.00 and B = 3.00. Their vector product is A x B= -5.00k + 2.00i. What is the angle between A and B?
Magnitude of vector product = magnitude of A * magnitude of B * sin of the smaller angle between A and B
|C|=|A||B|*sinX
|C|=(5^2+2^2)^(1/2)=3*3*sinX
sinX=(5^2+2^2)^(1/2)/9
X = arcsin[(5^2+2^2)^(1/2)/9]=36.75 degrees
According to the answer, the angle is 37 degrees. As shown above, I see where this comes from. However, we know that sin(36,75)=sin(143,25).
So the magnitude of vector C, where vector C is the cross product of vectors A and B is
3*3sin(36,75)=3*3sin(143,25)=5,385
My question is:
Why is 37 degrees the only correct answer if 143 degrees also works?
Thanks for help
Hmm. Good question. I think you have a point. There isn't enough information given about the original vectors A and B to deduce anything about their relative orientation other than the plane that they lie in. So reversing the direction of either A or B will yield a cross product using the supplementary angle (and reverse the direction for the cross product of course). But there's no way to distinguish say, A from -A, or B from -B, or the orientation that the cross product "should" have.
So I'd say that both answers should be acceptable.
I welcome corrections to my thinking here...
