Piecewise MATLAB ode45 problem for Lennard-Jones
4 replies · 3K views
Adrian Soo
I could run the MATLAB codes but the main issue is that data for T1 and U1 could not be produced. I am currently trying to calculate the displacement of two particles after the collision with walls with length of 10 units.
Here are the codes. If you don't understand its context, you can refer to the Microsoft word files I posted. Note that each particle HAS A RADIUS OF 1 UNIT.​
Lennard-Jones's equation of motion function
function du = lennardJones(~,u)
du = zeros(8,1);
du(1) = u(2);
du(2) = -24*( u(1) - u(3) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^7 + 24*( u(1) - u(3) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^4;
du(3) = u(4);
du(4) = -24*( -u(1) + u(3) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^7 + 24*( -u(1) + u(3) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^4;
du(5) = u(6);
du(6) = -24*( u(5) - u(7) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^7 + 24*( u(5) - u(7) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^4;
du(7) = u(8);
du(8) = -24*( -u(5) + u(7) )/( ( u(1) - u(3) )^2 + ( -u(5) + u(7) )^2 )^7 + 24*( -u(5) + u(7) )/( ( u(1) - u(3) )^2 + ( u(5) - u(7) )^2 )^4;================================================================================
clear all
t0 = 0; % Initial time
deltat = 0.1; % Step size of time
tend = 10; % Final time
u = [4,1,6,-1,1,0,1,0]; % Initial conditions for Lennard-Jones Potential
n = (tend - t0)/deltat; % for 'for' loops
t1 = t0; % Initialise t1 to t0
r = 1;
for i = 1 : n - 1
t2 = t1 + deltat; % Increment in time
options = odeset('RelTol',1e-8,'AbsTol',[1e-8 1e-8 1e-8 1e-8 1e-8 1e-8 1e-8 1e-8]);
[T,U] = ode45(@lennardJones,[t1 t2],u,options); % ode45 applied on LennardJones
if U(1) <= 1 && U(3) >= 9 %When particle collides with the wall at the distance of 9 units on the right
% and 1 unit on the left
clear t1 t2 deltat
t1 = 4.1; % t1 indicates the time it collides with the solid wall
deltat = 0.1; % increment in time
t2 = 10;
k = (t2 - t1)/deltat; %for 'for' loops
u1 = [1,1,9,-1,1,0,1,0]; %initial condition changes after colliding with walls
newtime = 0;
for j = 1:k
newtime = newtime + deltat;
[T1,U1] = ode45(@lennardJones,[t1 newtime],u1,options);
end
end
end
plot(T,U,T1,U1,'o')
output :
Undefined function or variable 'T1'.
Error in hardBoundary (line 37)
plot(T,U,T1,U1,'o')
Do you mean that the post can't be comprehended?
Greg Bernhardt said:
This is an automated courtesy bump.
This message is sent automatically to new posts that do not have any replies after one week.
I don't understand how your program is supposed to deal with collisions. It seems to be integrating over a certain time interval, and then come back to an arbitrary point in time (t=4.1) if there is a collision. Could you describe in more details?
Also, please use code tags when posting code: [C O D E] Some code here [/C O D E] (without spaces in CODE).
Basically, t = 4.1 s means that the particle collides with the hard boundary by using ode45.
How do you know?
As for your original problem: the condition
is never met, hence T1 is never defined.
