Pioneer Anomaly: Unravelling Physics' Mysteries
  • Context: Graduate
  • Thread starter Thread starter Ivan Seeking
    Anomaly pioneer
The discussion revolves around the Pioneer Anomaly, specifically the anomalous acceleration observed in the Pioneer 10 and 11 spacecraft. Participants explore various theoretical explanations, including potential implications for string theory, the influence of extra dimensions, and alternative models such as MOND and dust interactions. The scope includes theoretical physics, cosmology, and potential experimental confirmations.
  • Some participants suggest that the Pioneer Anomaly could provide insights into dark matter and extra-dimensional forces, as speculated by cosmologists.
  • One participant questions how extra dimensions could influence the dynamics of spacecraft, proposing that if true, it would confirm aspects of string theory.
  • Another participant raises the question of why the anomalous acceleration is observed in distant spacecraft but not in other orbiting bodies, proposing a clock drift explanation related to Hubble acceleration.
  • A different viewpoint posits that a more massive-than-expected Kuiper Belt, particularly dust, could account for the observed anomalies, suggesting that gravitational forces from dust particles might affect spacecraft differently depending on their location.
  • One participant introduces the concept of a Berry phase as a potential explanation for the anomaly, linking it to quantum states and geometrical properties.
  • Another participant expresses skepticism about MOND as an explanation, arguing that the observed effect should vary more than it does over the distances involved.
  • Some participants speculate on the possibility that the perceived slowing of the spacecraft might be an illusion caused by interactions with fields that affect timing measurements.
  • Concerns are raised about the consistency of explanations involving dust, questioning whether a uniform dust density could produce the observed constant acceleration.
Participants do not reach a consensus, as multiple competing views and hypotheses are presented regarding the cause of the Pioneer Anomaly. The discussion remains unresolved with various theories being explored and debated.
Some limitations include the dependence on assumptions about dust density and the nature of the vacuum in space, as well as unresolved mathematical steps in the proposed explanations.
  • #31
Could it have been close enough to alter the course of pioneer?
Astronomy news on Phys.org
  • #32
Would you like to do the math to see if it could've?
What inputs will you need? What equations?
(PS: it's quite simple to do this)
  • #33
Nereid said:
Do you have a reference reporting the Ulysses acceleration? What about other probes (e.g. Voyagers)?
Ulysses is mentioned in passing in the main Pioneer article. I don't have a good reference for Voyagers. I have seen it discussed in footnotes in other papers and the popular press, but believe that the definitive articles on these have not been published (indeed perhaps "suppressed").
  • #34
I too have seen references to Voyager, mostly along the lines of 'they're much more active spacecraft , more possible outgassings, radiation modelling much more difficult' etc. IIRC, Pioneer is so much 'cleaner', which is partly why I'm curious about Ulysses ... it's nowhere near as simple a craft as the Pioneers, plus it's still very active ...
Given how faint the Pioneer anomaly signal is (it's what's left after you've accounted for everything else you can model well), I don't think any "suppression" is needed.
  • #35
Nobody wants to stick their neck out on a signal that cannot be ruled out as noise. The pioneer data is pretty clean so it is not very controversial to suggest things are not working the way we thought they should. Data from the other probes, as Nereid noted, is not nearly so clear cut. There are hints of possible pioneer-like anomalies, but, not nearly clear cut enough for somebody working on those projects to expose their face to that big an egg. I wouldn't call it suppression, more like self defense. Physicists are both vain and cruel. Jumping the gun is a good way to get hung with a nickname like 'Old Hisser'.
  • #36
Hi, I'm new and I wonder if this will explain the pioneer anomaly. I think of the universe as an expanding hypersphere. Maybe gravity goes out to the 4th dimension and therefore it takes a 'shortcut' to voyager and slows it down more than calculated. I hope this makes sense to you.
  • #37
Hi abycjyvey welcome to these Forums!
Although I don't really follow your 'shortcut to the 4th dimension to Voyager' idea, the Pioneer anomaly may have something to do with the Universe's expansion.
Why?
Because the anomalous acceleration is approximately equal to cH the Hubble acceleration, which itself can be explained by a clock drift between atomic and ephemeris clocks.
Such a drift may be linked to the evolution of the universe as a whole by Mach's Principle (through a secular evolution of G).
But there are two other 'cosmic coincidences' here.
The first as I have posted on these Forums before is that Stephenson et al. have studied changes in the length of the day from ancient eclipse records and conclude that, after tidal breaking has been taken into account, there is a residual spinning up of the Earth of 0.6 millisec/day/century. This may be unremarkable and caused by the Earth recovering from the last Ice Age, however I cannot help noticing that this rate of spin up is exactly equal to Hubble's parameter!
(6.10^-4/3600.24/100) yr-1 = 1/(14.4Gyr)
The second is MOND. MOND modifies the normal Newtonian (weak field GR) gravitation so that if the Newtonian acceleration aN is smaller than a0 then the acceleration of an object is given by:
a ≈ (aNa0)1/2,
and Milgrom states MOND--theoretical aspects
The value that fits the data discussed above is about 10−8cm s−2
the remarkable feature here is MOND's critical acceleration is also approximately equal to the Hubble acceleration.
So may it be that these three anomalies can be explained by applying the expansion of the universe to local gravitationally bound systems as well as to the universe as a whole?
Just a thought.
Garth
  • #38
An interesting idea ... do you have some math to describe it a little more quantitatively? What other good (astronomical?) observations would your idea account for? How consistent is your idea with GR?
Garth: I think you mean H0, don't you? If so, then the MOND figure would be either a coincidence, or easily testable (what value best fits the rotation curves of very distant spirals?).
Wrt Stephenson et al, would you mind taking some time to read through the http://www.phys.canterbury.ac.nz/research/laser/index.shtml ? I'm wondering, first, are they within shooting distance of being able to independently (indirectly) measure the 'Stephenson spin-up'? IIRC, they think they may be able to measure the rotation of the solar system around SagA* ... sometime 'soon'.
The http://arxiv.org/abs/gr-qc/?0104064+v4 (may be easier for some folk to get to Anderson et al from here).
  • #39
Hi garth,
Why suddenly rubbish "the top scientists"?
I haven't. I've rubbished the current cosmic model.
Evidence is building that the standard model, which has required a series of 'fixes', (Inflation, DM, DE), needs revising
A gross understatement if you ask me!
but the general approach has been sound,
No way. It was sound to start with. Dark matter was the most logical, intuitive way to solve the the galaxy anomalys ( rotation , mass descrepancy ). But when it became apparent dark matter theory was producing more anomalys than answers, it should have been ruled out.
There you go, I'm rubbishing the top scientists now.
i.e. to conflate tested theory (GR) with precise observations. (Hubble Deep Field, WMAP, S/N Ia etc.)
I really don't like this. All the meticulous science that has to be done. Yet the simple truth is, if the galaxy anomalys can't be solved with the currrent model, all this work of fitting data with current theory is obsolete. It's analogous to fine tuning the motor of a car when it's found it's impossible to fit any wheels.
  • #40
a0 = cH0 yes!
That's a very good point. Has anybody already looked at this? One problem with MOND is the value of a0 is only approximate, because of this I am not totally bowled over by its ability to predict galaxy rotation profiles and it would mean that we have to look at high z galaxies to test this hypothesis. Then there would be problems calibrating them.
That's a very interesting link - thank you. The Earth's rotation fluctuates in a short time scale considerably at these levels; witness the effect on its rotation of the recent disastrous Indian Ocean tsunami, so Stephenson smoothes out over many centuries to obtain his result.
meemoe_uk I was referring to your
meemoe_uk said:
Personally, I think the fact that we're using Hubble red shift gives plently of scope for crazy results, since Hubble redshift is part of the crazy cosmological physics scene, which is undoubtably mad, what with all that galactic rotation anomaly and what not.
I'm actually with you on the need to modify GR - see most of my other posts! But don't be 'shrill' about it, you will be heard more readily!
Garth
  • #41
meemoe_uk said:
... No way. It was sound to start with. Dark matter was the most logical, intuitive way to solve the the galaxy anomalys ( rotation , mass descrepancy ). But when it became apparent dark matter theory was producing more anomalys than answers, it should have been ruled out.
What dark matter theory has produced more anomalies than answers? What are the anomalies, and who says they rule out dark matter?
Again, what galaxy anomalies, why can't they be solved and which experts are saying they can't be solved under the current model? Why would scientists conclude current theory is obsolete before comparing the data to current theory? It seems more reasonable to carefully analyze the data and establish what does not and cannot be made to work under current theory before announcing it dead. That simply has not happened. If it did, scientists would be falling all over each other trying to find the new physics. Just because more and better observations result in more questions does not signal a problem with theory - at least not until observation shows things that are forbidden, or absurdly improbable under current theory. No self respecting scientist tosses in or is receptive to 'epicycles', like dark matter, without having ruled out all other reasonable possibilities. We very rarely see things forbidden by theory. We frequently see things not anticipated by theory. That suggests what we already knew - our basic theories are pretty darn good, just incomplete.
  • #42
I'm not a mathematician or physicist so please don't ask me difficult questions :smile: . But I think this: 'An alternative to dark matter is to suppose that gravitational forces become stronger than the Newtonian approximation at great distance' (http://en.wikipedia.org/wiki/Dark_matter) suggests that what I said before might be correct.
  • #43
You are thinking along a 'right' track abycjyvey, though not the only one, and not the standard model one, but this is what MOND postulates:
gravitational acceleration a ~ 1/r2 for a >> a0
and a ~ 1/r for a << a0
where a0 is empirically determined to be about 10-8cm/sec2.
What intrigues me, as I said above, is that first of all a0 is about the same as the anomalous Pioneer anomaly (the subject of this thread!) and secondly that both are approximately equal (within a factor of 2) to the Hubble acceleration cH0.
Is this a coincidence? Beware there are many 'crackpot' theories to be hatched here!
Garth
  • #44
All of them.
Well here's 3 to start with...
1. To get the galaxy to rotate the way it does using standard gravity, the radial distribution of dark matter must be a bell curve. But models show dark matter cannot exist in this distribution, it can only be stable in a 'spike' distribution, which wouldn't cause the rotation that is observed.
2. Originally, dark matter was thought to be just cold baryonic material. But after observations showed that cold baryonic material couldn't fully explian the galaxy kinematics, theorists fell back onto other forms of known energy. One by one, each of these materials been shown to be highly unlikely, so now DM guys say dark matter is composed of stuff never seen before. This is, of course, totally ridiculous. In my opinion, they've only got away with it for 3 lame reasons. (i) They slowly built up to it, moving away from likely candidates ( baryons ), to daft ones. Each step seems only slighty more desparate than the last. (ii) it is the fashion in quantum physics to propose and discover new particles with odd characteristics. Dark matter guys used this fashion to propose a model that worked only with crazy particles.(iii) they are the experts right?what they say MUST be true. not.
3. Dark matter, coupled with standard gravity doesn't explain why omega = 1.
The MOND guys do.
e.g. Stacy McGaugh
http://www.astro.umd.edu/~ssm/mond/mondvsDM.html
I've already stated 2 in a previous post. I sense you are disagreeing with my posts without reading them.
If you ask me, it's because cosmo guys have been concentrating on the wrong theory.
You've already asked this is the same post.
I don't know. Why are you asking?
Yep. That's what's been done.
And here we come to your misunderstanding. It has happened, i.e. the 3 anomalys I've discribed. And theorists are inventing new gravity models. But you are looking at the wrong bunch of theorists, the old established dark matter guys. You'll never get any new theory from them. If you'd read some science history, you'd see the old guys rarely come up with new stuff, and rarely like new stuff. e.g. Planck, founder of quantum theory that he is, didn't like quantum theory, and spent his life trying to reconcile his BBR theory with classical theory. There's an old saying, "physics advances, death by death [ of physicists ].". It's the young unknown guys that come up with new stuff.
Correct, but galaxy rotation is an old observation. DM guys have had at least 35 years and $billions to solve it. They've failed.
I can't think of anything more absurd in the history of physics than the implications of currrent DM and DE models. By your own logic, we should drop DM, because it's absurd.
I think you'll find no other possibilitys where ruled out before DM. DM was\is the first possibility explored.
But under current models the galaxy is forbidden to rotate the way it does.
Frequently? Only in observational cosmology, and if theory, given ample time, cannot explain these observations, then we should chuck it out. Basic science.
Only if the theory can explain the unexpected observations. Since DM hasn't explained galactic rotation, what you say doesn't apply for DM.
Chronos, DM theory is losing support. After 35 years it's produced next to nothing. It's is only a matter of time before it passes into history. When are you going to abandon it?
  • #45
Hi Lurch.
But the proposed mechanism is not the gallactic wind itself,
Yes, I know this is incidental, but if we are considering the shockwave, then we should consider the galactic wind, because the direct wind influence could be as substancial as the shockwave. But never mind this. It was just incidental.
In this case the EM pressure would be expected to be nearly uniform and allways directed toward the sun, because the Terminus of the Soalr Wind is roughly spherical.
I really don't seee this. I think the 'solar wind field' will be a pronouced elipsoid, with the contracted part of the elipsoid facing the galactic wind, and extended part on the other side (natch),( sorry can't be bothered with correct geometry terminology!)
Consider the solar wind which is traveling in the same direction as the galactic wind. Logically, it would not meet any boundary abrupt enough to induce a shockwave?, in contrast to solar wind heading against the wind. It may encounter turbulence.
Also, even if I was to accept the shockwave force is into the sun at all point, I don't understand how you deduce the force is constant. You mention and compare 'most fliulds' .In a simple water flow shockwave, the shockwave force is constant. But this is dependent on the water being uniform density. But we are dealing with a non-uniform fluid, i.e. inverse square field. In such a fluid, the shockwave force would disapate to zero as it traveled back to the sun.
Explain
  • #46
Meemoe. I agree it would be hard to disagree with your posts without reading them. On the other hand, since I quoted from your posts, odds are good I did read them and merely disagree. That is not a bad thing. PF would not be fun if we agreed on everything. I enjoy the challenge of checking my facts and sources. I'm sure you do too. In that spirit:
meemoe_uk said:
All of them.
All? How many are there? Any examples?
Chronos said:
What are the anomalies?
Assuming the term 'standard gravity' means GR, I ask:
1] Why must the radial distribution of dark matter must be a bell curve? Who said this and what mathematical and empirical evidence do they cite.
2] What models show dark matter cannot exist in this [bell curve] distribution and what mathematical and observational evidence supports this assertion?
3] Who says is dark matter only stable in a 'spike' distribution? What is meant by a 'spike' distribution? What is the theoretical and observational basis for deriving this conclusion?
I only addressed your first point, as you probably noted. The others are pretty much just a rehash.
  • #47
well, Stacy goes on about his own DM theory and how it failed, and then went on about how all DM theory suffer from the same intrinsic illness. You could look at his website. Considering this has been going on for 35 years I'd imagine there been hundreds of failed DM theorys.
The answer to your technical questions - I don't know the specifics of why they some distributions aren't stable. All I know is, current models are run on computer simulations, and modellers watch as the model galaxy collapses\fails. To do this you either need a super computer, to model the 1000000+ particles, or a smart approximation algorithm to run on a slower computer.
Here's a good place to start a gravity modeling interest...
http://dmoz.org/Science/Astronomy/Software/Computational_Astrophysics/
  • #48
There's something I don't understand about the theory that says it's caused by collision with dust.
The Pioneer spacecraft are traveling away from the Sun. Most of their velocity is in the radial direction (~12 km/s radial, ~2km/s tangental) with respect to the Sun.
But the dust, in order to maintain a relatively circular orbit around the Sun must be traveling with almost all its velocity in the tangental direction (~0 km/s radial, ~4 km/s tangental). This means that the collisions are not head-on.
So why is the direction of acceleration completely towards the Sun rather than at an angle to the Sun/Pioneer line?
  • #49
If the velocities are as you site then the relative velocity of Pioneer to the dust is about 12 km/s radial and 2 km/s tangential (this is the delta radial velocity and the delta tangential velocity).
Also, the radial surface area is going to be greater than the tangential surface are since the Pioneer probes are not spheres. Imagine a big platter with a relatively compact mass connected to it.
Also, it isn't clear to me that a slight tangential decelleration is ruled out by the data. The tangential effect would be an order of magnitude less than the radial effect.
  • #51
matt.o said:
this link may interest you guys!
http://arxiv.org/abs/astro-ph/0503368
Excellent catch. The paper argues that if the density of outer system dust falls off as 1/r and the mass of that dust is somewhat more the current estimates (less than an order of magnitude) that the Pioneer effect would be produced from the gravitational effect of the dust.
It also notes that Nieto, et al are working on a paper on the collision with dust theory which they compare briefly at the end of the paper noting that the collision theory requires a constant dust density compared to evidence the cite that the dust density is not constant but falls off.
  • #52
The dust causing gravity is my favorite theory so far, but it is not without its flaws. This article states that the entire mass of the dust is [tex]1.97 M_{Earth}[/tex].
But there is a problem.
A little background first:
The solar system can be treated like a galaxy in this situation. The Sun orbits the galaxy with the exact same period that it would orbit a single large object at the same distance as the Sun / Galactic center distance, and with a combined mass of all the galaxy's mass interior to the Sun. Therefore, any mass exterior to the Sun's position in the galaxy can be safely ignored.
In a sense, this is like the physics question of how much you'd weigh inside a hollow sphere. Your weight would be 0 no matter where in the sphere you were, and no matter how massive the sphere was. If there was a hollow sphere, with 1 Earth mass and 1 Earth radii, 1 cm thick, (very dense material!, but hypothetical, so why not), and you stood on the surface, you'd find that gravity was 9.8, just like the real Earth. But if there were a hole in the surface, and you jumped through the hole, you'd immediately be weightless.
Dust in the Kuiper Belt would behave the same way. Since its assumed to be distributed uniformly, anything orbiting the Sun interior to this dust belt would not feel the gravitational effect of the dust. But anything exterior to the dust would feel it. It would be the same as if you concentrated all the dust together and added it to the Sun.
So far, this seems to work quite nicely for the Pioneer anomoly. There is no anomoly if you are interior to the belt in the same plane as the belt.
But now the problem:
How much dust would it take to cause an additional acceleration of [tex]8.7*10^{-8} cm/s^2[/tex]
[tex]a = \frac{GM}{r^2}[/tex]
therefore
[tex]M=\frac{ar^2}{G}[/tex]
[tex]8.7*10^{-8}cm/s^2 = 8.7*10^{-10} m/s^2[/tex]
[tex]G=6.673*10^{-11}Nm^2/kg^2[/tex]
[tex]r = 1*10^{13}m[/tex] (roughly the current Pioneer / Sun distance)
[tex]M = \frac{8.7*10^{-10}*(10^{13})^2} { 6.673*10^{-11}}[/tex]
[tex]M=1.3*10^{27}kg[/tex]
[tex]\frac{1.3*10^{27}kg}{5.98*10^24 kg/M_{Earth}} = 218.12 M_{Earth}[/tex]
which is much higher than the article's value of [tex]1.97 M_{Earth}[/tex]
  • #53
I'm a bit short of time or I would do the math myself, but I believe even the 1.97M figure would be enough to influence the outer planets orbits. 218M unquestionably would.
  • #54
The article argues that there is a modest effect on outer planet orbits, and implies that current predictions are based on the wrong "initial conditions" so to speak.
  • #55
Not if its all exterior to the outer planets, and evenly distributed. Then the outer planets are like a person in a hollow sphere, unable to feel the effects of the sphere's gravity.
Jupiter orbits exterior to Mars, but tugs Mars eccentricity into and out of round periodically. (Jupiter does this to Earth too but to a much lesser degree). But if Jupiter exploded and formed a belt of dust with 1 jovian mass, evenly distributed over Jupiter's orbit, Mars would no longer know this mass existed.
Observations with IR suggest that 218 Earth masses of dust in the Kuiper belt is unrealistically high.
The article claims that the dust belt begins just past the orbit of Uranus. It talks about an effect on Neptune, but not the planets interior to the dust belt.
  • #56
I did not know of the "Pioneer Anomaly" when I wrote Dark Visitor, but did know that in the early part of the last century that Neptune's orbit was disturbed - Based on his analysis of this disturbance, Percival Lowell founded the observatory near Flagstaff AZ and financed the discovery of Pluto, but Pluto needed to be many times the mass of the Earth to have produced the perturbations. We now know that Pluto is smaller than the moon, so the perturbation, if real, was something else. I used these "Pluto facts" plus the fact that when the universe was about 25 times smaller, the first stars were forming, were larger, aged rapidly and several generations of them left pairs of gravitationally bound black holes behind, long before our sun was born.
If the first member of a BH pair, approaching from the north polar region, passed not too far from our solar system, cutting thru the plain of the ecliptic in 1928, it could have been the cause of Neptune's perturbation and tilted Pluto's orbit plane. The second member of the pair could be approaching about now, but still not detected as black holes do not reflect sunlight.
The hero of my story (Astronomer Jack) has been carefully measuring Pluto and Neptune for several years and from their unexplained residual perturbations computed a rough trajectory for the now approaching second member of the 1928/2008 pair.
In fact there are several reasons why Jack's small (2.2 solar mass) BH now 130 AU from the sun might be more directly noticed. The Pioneer acceleration anomaly would be nearly two orders of magnitude greater, but you might want to think about the other reasons.
Dark Visitor was written as a recruiting tool for the hard sciences. I am a retired professor and very concerned that the western world is now in the process of losing scientific leadership to hard working, studious Asians, as it has already lost technological leadership and many good jobs. I don't want my grandchildren to have only "non-exportable" jobs like cutting some one's hair or selling fast food, etc.
If you share my concern, please visit www.DarkVisitor.com where you will learn how to read entire book for free, get a list of all the science hidden in it, sample text, etc. The target reader is not currently interested in science -that is why it is a scary, but possible real, story of a coming cosmic disaster that change Earth's orbit enough (more elliptic by about 10%) to initiate a new ice age beginning in 2008.
  • #57
Garth said:
One question is why is this anomalous acceleration detected on distant spacecraft but not on other orbiting bodies?
It may be explained by a clock drift between atomic clock time and ephemeris clock time, the acceleration being approximately the Hubble acceleration, http://arxiv.org/abs/gr-qc/0403013
ap ~ cH.
Such a clock drift is predicted by SCC.
Garth
Thanks Garth for this interesting reference. The paper is rather convincing and is based on established principles. There is also an interesting analogy with Puthoff's theory (discussed in earlier treads) on the influence of gravity on the electrical permittivity and magnetic permeability of the vacuum (same dependence)- see equation 12.
Now, if this explanation is, even partly, correct, it would probably mean that a number of cosmological "observations" such as redshifts, distances to galaxies, estimates of dark matter (which I think does not exist) and dark energy, etc are erroneous and need to be corrected for this effect. Would you agree on this ?
  • #58
Let me answer cautiously.
Astrophysics is the application of laboratory or 'local' physics to the universe 'out there'. Cosmology is the extension of that discipline to the largest possible scales.
The overall theory that describes the cosmological environment, in which the locally understood and tested theories of atomic processes and nucleosynthesis etc. are set, is General Relativity.
That theory has been well tested in local solar system experiements and on the largest scales produces the standard [itex]\Lambda[/itex]CDM model. That model fits the multitude of observations of Hubble Red Shift, BBN, CMB anisotropies, distant Type Ia supernovae, large scale structure etc. very well.
However it does so by introducing a series of 'entities', Inflation, exotic non-baryonic DM and DE that have not been identified in local physical experiments.
When we discover the Higgs Boson/Inflaton, the DM particle and identify DE in the laboratory (LHC?), measure their properties and show that those observed properties match the cosmological observations then and only then will we know what we are really talking about.
In the meantime questions remain about the development of a Quantum Gravity theory, and pertinent to that, whether GR really does describe local gravitational fields accurately. The Pioneer Anomaly (its Doppler drift is almost equal to the Hubble Constant) may indicate that it does not.
Remember the discovery of Pluto because of a residual anomaly in Uranus' orbit after Neptune had been taken into account? Pluto is too small (by a factor of 2 OOM) to have been the Planet X they were looking for. So unexplained residuals may still exist in the orbits of the outer planets as well!
I think we should have open minds while these questions remain, other theories that are alternatives to, or modifications of, GR have a mountain to climb, however they should not be discarded because of that. Alternative theories to GR (such as http://en.wikipedia.org/wiki/Self_creation_cosmology will shed further light on the issue in April!
Garth
  • #59
Hi,
Another simple way to understand the pioneer anomaly:
Suppose that at a distance between us and Pioneer the cosmological scale factor in conformal time units switches (a discrete jump) from a(t) to 1/a(t).
As a consequence there will be a 1/a^2(t) deceleration of Pioneer clock (i.e frequency of the radio wave we receive from it) relative to our Earth clock (in a theory where the background effects are not suppressed by the local gravitational field as in GR)..
As a straightforward result: (df/dt)/f=-2H0 as you can check and as is observed. This is also, as in SCC, a deceleration of clock explanation of the anomaly but in quite different way: it needs at least to spatial areas with different background evolutions.
The dark gravity theory (gr-qc/0610079) equations admit both a(t) and 1/a(t) solutions and nature has to choose between them at some places in a discrete way in order to restore a better discrete symmetry involved in the fundations of the theory which i cannot devellop here.
As you can see in the paper by ANderson , the effect appeared quite abruptly in 1983 around 12.5 A.U
Within the error bars i couldn't hope a better signature : Pioneer just crossed the background discontinuity in 1983 at 12.5 A.U
The foreseen consequences for the near future are here: www.darksideofgravity.com/armagfr.htm[/URL]
regards,
F Henry-Couannier
  • #60
Keep in mind the lunar laser ranging project has been collecting data for nearly 40 years. It should be interesting to compare GPB results with those of that study.
