K X-Ray Production in PIXE: 2 MeV vs. 4 MeV
In the discussion on K X-ray production in Proton-Induced X-ray Emission (PIXE), it is established that increasing the beam energy from 2 MeV to 4 MeV affects the cross section for K X-ray production differently for Nickel (Ni) and Sulfur (S). The general consensus is that elements with more electrons, like Ni, will exhibit a higher cross section at increased energies compared to elements with fewer electrons, such as S. However, the ratio of cross sections between the two elements can vary based on their electron configurations and the energy levels at which ionization occurs.
  • Understanding of Proton-Induced X-ray Emission (PIXE)
  • Familiarity with cross section concepts in particle physics
  • Knowledge of atomic structure and electron configurations
  • Basic principles of ionization energy
  • Research the relationship between beam energy and cross section in PIXE
  • Study the electron configurations of transition metals like Nickel
  • Learn about ionization energies of different elements
  • Explore mathematical models for calculating cross sections in particle interactions
Students and researchers in nuclear physics, particularly those studying particle interactions and X-ray production mechanisms in materials.
Silviu
In PIXE (Proton-Induced X ray Emission), if you increase the beam energy from 2 MeV to 4 MeV, do you expect that the factor of increase in the cross section for the K X ray production from Ni is higher than that from S, or vice-versa?
The professor didn't give us any equation, just a conceptual explanation of the process. It makes sense that the cross section increases with the energy of the incident particle but I am not sure how this increase depends on different elements. So I am not sure how to approach this problem. Any idea?
Which atom has more electrons that can make the transition ## h\nu_{x-ray}##?
Hello! I guess the one with more electrons has a higher cross section. My question was more how do you calculate the change in the ratio of the cross sections. Like if the cross section of the one with more electrons is a and for the other one is b, when the energy is 2 MeV, of course when you go to 4 MeV the one with more electrons will still have a higher cross section, but I am not sure what happens to the ratio ##\frac{a}{b}## because the ration can both increase or decrease while its value to be greater than 1
If atom a has much fewer electrons which can be ionized, increasing the energy will have a smaller effect on the observed crossection.You observe a certain prosecution for atom a at 2 Mev but increasing the energy will not have much of an effect because all of it's electrons were ionized at the lower energy. Where as atom b still has electrons which can be ionized at the higher energy.
