Please Explain (actually explain) The Monty Hall Problem
  • Context: Undergrad
  • Thread starter Thread starter Timbre
The discussion revolves around the Monty Hall Problem, a probability puzzle involving a game show scenario where a contestant must choose between three doors, behind one of which is a prize. Participants explore the implications of the initial choice and the information revealed by the host's actions, questioning the relevance of the first choice in determining the final probability of winning.
  • One participant argues that the first choice is immaterial and does not affect the outcome of the game, suggesting that the game continues regardless of the initial selection.
  • Another participant counters that the act of the host revealing a losing door provides crucial information that impacts the probabilities involved.
  • A different viewpoint emphasizes that the first choice does not provide relevant information, asserting that the final decision is what ultimately matters.
  • Some participants illustrate the problem using variants with more doors, arguing that the principle remains the same and that switching doors increases the chances of winning.
  • There is a contention regarding the assumption of equal probability in the final choice, with some asserting that the probabilities are not equiprobable after the host's reveal.
Participants express differing views on the relevance of the first choice in the Monty Hall Problem. While some believe it has no bearing on the outcome, others argue that it does provide information that influences the final probabilities. The discussion remains unresolved, with multiple competing perspectives present.
Participants reference various scenarios and analogies to illustrate their points, indicating that the discussion is nuanced and depends on interpretations of probability and information theory. There are unresolved assumptions regarding the nature of the game and the implications of the host's actions.
  • #91
FactChecker said:
Yes, it does make a difference. There is a difference between an accidental result of rare luck versus the intentional act of avoiding opening one door. Consider the example (again) of the game with 100 doors. In the first case of luck, the only inference that can be made from opening 98 doors without revealing the prize is that a rare, lucky event was just witnessed.
The host must know the car location to comply with the rules:
1. Host cannot open a player door choice until after player last choice.
2. Host cannot open a car door until after player last choice.
The game rules prevent the host from accidently revealing the car location, ending the game, and denying the player a 2nd choice.
If player chooses a car door, it survives by rule 2.
If player chooses a goat door, it survives by rule 1.
The host opening 98 goat doors does not change the contents of any doors.
All goat doors are identical thus they have no special status.
The end result is 1 car door and 1 goat door with the player not knowing which one wins.
This is equivalent to tossing a coin.
  • #92
Are you saying that if you stick with your original choice then you win 50% of the time?
  • #93
In the Monte Hall game, the player only has one choice that he does before Monte opens any door.
So you don't think that Rule 2 and the fact that Monte did not open that remaining door gives any sort of hint that should be used to adjust the odds but that same implication does not apply to your door? As has been explained dozens of times on this thread alone, you are wrong.
  • #94
Except that you can be objectively shown to be wrong.
The simulation in post 27 proves that switching doors will result in winning twice as often.
If your logic/intuition does not lead to that result, then it is demonstrably faulty.
  • #95
Only if the two options are equal probability, which they are not. Simply having two options does not mean that the probability is 1/2
https://www.ac-psych.org/en/download-pdf/volume/10/issue/4/id/164
  • #96
if there are 100 doors, then you have only 1% chance of having picked the car door when you are offered the option to switch, and if you haven't picked the car door (99% chance), then switching wins (every time), but if you have picked the car door (1% chance), then switching loses (every time).
The door you picked is ineligible for opening prior to the switch offer.
There's one door you picked, which still has 1% chance of having been and still being the car door, and the remaining door, which has the other 99% chance of being the car door.
  • #97
I think the sieve method is very good at explaining Monty Hall problem. On the otherhand I prefer another explanation, when the host opens envelopes randomly, I didnt read the posts well, so I am probably repeating. This version is equivalent to the game where contestants are given an envelope and asked one by one to open it. At each stage the ones left are at equal footing, the winning chance increases as long as the envelope was empty. It is easy to imagine being part of the contest and hoping the opened envelope is empty, so I can still win, but everyone else is looking at the situation the same way.
The sieve version kind of means that all the other envelopes are sieved except yours and in the random version no sieving is happening or it done the same way to all envelopes.
  • #98
FactChecker said:
I disagree. In @Dale 's 100-door example, our selected door initially had a 1/100 chance of being the correct door. The other 99/100 chances were in the other doors. The host is not allowed to open your door or the winning door. He opens 98 other doors. That gives you a lot of information -- there are 98 doors that you know are losers. Furthermore, you know that his selection of those 98 doors did not miss the prize out of blind luck. So the 99/100 chance is now associated with the one remaining door that you did not select.
If there were 100 doors, each would not contain .01 car. The reality would be1 door containing a car and 99 doors containing goats. As the host opens 98 goat doors, the contents of the remaining doors does not change. That would be an illusionist trick you might see in Las Vegas.
If the player chose the car door, it survives since the host cannot open the car door nor the player choice.
If the player chose a goat door, it survives since the host cannot open the player choice.
The goat doors can be opened in any random order since order is not a factor. Any goat door could be the 1st or last or anywhere in between, thus no special status.
The host has reduced the set of doors to 2. There are only 2 possible results. Win a car or win a goat
If you believe the probability is1/3, what is the 3rd choice?.
  • Sad
  • #99
There are two choices. One has 1/3 chance having the car and the other has 2/3 chance to have the car. Your error is in thinking that the two options are equally likely to have the prize.
Everyone agrees that there are two options. Your mistake is thinking that the probability is equal.
If the player selects a goat then that goat door does have special status. That special goat door cannot be chosen by the host, according to the rules you yourself described.
The standard Monty Hall problem has been simulated and tested experimentally. The probability of winning is 1/3 for staying with the original choice and 2/3 for switching. That is a measurable experimental fact. Since your reasoning leads to a demonstrably false conclusion, you know that your reasoning is wrong. We have pointed out exactly where it is wrong. Your goal now needs to be to understand why it is wrong, not to continue arguing for an empirically wrong position.
  • #100
So you have set A with 1 box and set B with 99 boxes.
You'll agree that the car is more likely to be in set B, It's more likely that the car is in one of the 99 boxes you didn't choose.
When you remove boxes from set B, it's still more likely that the car is in set B. Finally, when only 2 boxes remain, the car is more likely to be in the remaining box from set B than in the box from set A that you initially chose.
  • #101
The possibilities are:
  1. Contestant chose the car, host opened the left hand goat door ##p=1/6##.
  2. Contestant chose the car, host opened the right hand goat door, ##p=1/6##.
  3. Contestant chose the left hand goat, host opened the other goat door, ##p=1/3##.
  4. Contestant chose the right hand goat, host opened the other goat door, ##p=1/3##.
Only in cases 1 and 2 does the contestant win by sticking, with a total probability of ##1/3##. As @Dale pointed out, just because there are equal numbers of possible outcomes it does not mean that the probabilities of those outcomes are equal.
  • #102
It is true that what you get at the end is a 50/50 odd. But the important information comes from the first round, about the odds you picked a goat:
jack action said:
Look at it the other way around; what are the probabilities it is a losing door instead of a winning door? Facts:
  • On the first round, he has knowledge of his first chosen door, that it's 2/3 a losing door.
  • On the second round, he has knowledge of the remaining door, that it's 1/2 a losing door.
2/3 > 1/2, therefore his first chosen door has a bigger probability that it is a losing door; he better select the other one.
Repeating the process with 100 doors and Monty opening 98 doors makes it even clearer:
  • On the first round, he has knowledge of his first chosen door, that it's 99/100 a losing door.
Why would you stay with a door that you are 99% sure it hides a goat when you could choose one that only has 50% chance of hiding a goat?
  • #103
The real difference is between luck versus the sure thing of a rule.
If Monte blindly opens a goat door, that is luck that changes the odds of both your door and the remaining unopened door equally.
On the other hand, if Monte opens a door following the rule that he can not open the prize door, there is no luck involved. It was guaranteed. The odds of your door having the prize are unchanged at 1/3 and the odds of the other door having the prize are changed to 2/3.
  • #104
What's behind each door does not change, and the collective chance of the non-selected doors (that's (n-1)/n, in the case of 100 doors, that's 99/100) does not change, but opening the non-selected non-car doors causes that 99/100 chance to be aggregated into and distributed over fewer doors; opened doors are no longer eligible, but any unopened door could still have the car behind it. When 98 doors have been opened, the number of non-selected over which the 99% chance is distributed has been reduced to 1 door.
Correct.
In the 3-door game, the concept of the host making a 50-50 random selection arises for when he encounters 2 doors eligible to be opened, which happens only when the contestant has picked the car door.
It's not 1/3 for 100 doors; it's 1/3 car and 2/3 non-car for 3 doors; for 100 doors, it's 1/100 car and 99/100 non-car ##-## those are the chances for the contestant when he picks a door.
When Monty opens a door, the chance for that door reverts to the remaining unopened doors (not including the one the contestant picked ##-## that chance doesn't change; it remains 1/n ##-## one out of the number of doors). The contestant can keep his 1/100 chance by sticking, or he can take his 99/100 chance of having not picked the car door, and switch to the other door that now has all of that 99/100 chance of being the car door. That accounts for all 100/100 chance.
So, with 100 doors, you have 99/100 chance of picking a non-car door, and a 1/100 chance of picking the only car door. Your chance if you stick stays the same, so if you picked the car, switching loses, but that will happen only 1/100 of the time; the other 99/100 of the time, you didn't pick the car door, so switching wins.
  • #105
It's not 50%.
Among car-door pickers (1/3 of contestants),
all stickers win, all switchers lose;
Among goat-door pickers (2/3 of contestants),
all switchers win, all stickers lose.
You can't know in advance which kind of picker you are, whether you're a car-door picker or a goat-door picker, but you can decide in advance whether to be a switcher or a sticker, and if you're a switcher, you win the 2/3 of the time that you didn't pick the car door, but if you're a sticker, you have to make do with the 1/3 chance you have of picking the car door at the outset.
  • #106
Just to be clear. None of this is about "the contents changing". It is only about changing your estimate of the odds of doors having goats or the car.
  • #107
Correct.
The probability is not independent of the environment,
and must be recalculated for a change in the environment.
If adding doors decreases the probability then
subtracting doors should increase the probability.
Where is your consistency?
Begin with 5 doors, and the car behind door 1.
Left column is probability of the car being in the set.
1/5 1 2 3 4 5
1/4 1 2 3 4
1/3 1 2 3
1/2 1 2
1/1 1
As each goat car door is removed, the probability increases.
If the host removes the last goat door, the player would win the car for certain.
That would not provide much entertainment.
  • #108
@phyti - seriously, play the game.
Get a king and two aces from a standard deck of cards, and a coin. Shuffle the cards and deal face down. Acting as the player, pick a card and turn it sideways to indicate your choice. Now act as host. Flip all the cards face up and pick the card that you would reveal to the contestant - if there is more than one, toss the coin to decide which one to reveal. Record whether the player would have won by sticking or switching.
Repeat until you're convinced (back of the envelope, 40 repeats will exclude one of the possibilities with 95% confidence and 225 will exclude at the proverbial ##5\sigma##), or until you realise that the contestant chooses a winner first time one time in three, and therefore sticking wins one time in three.
  • #109
1/5 1 2 3 4 5
1/4 1 2 3 4
1/3 1 2 3
1/2 1 2
1/1 1
The probability is 1 for each of these rows. The car is behind door 1 and each set contains door 1. So for each set the probability of the car being in the set is 1.
  • #110
1/5 1 2 3 4 5
1/4 1 2 3 4
1/3 1 2 3
1/2 1 2
1/1 1
I think that this is an entertaining explanation for people who already understand that the game favors switchers over stickers, 2/3 to 1/3; however, for those who don't, it's maybe a little overly indirect:
  • #111
I notice that if Alice is playing the game and has got as far as Monty opening a door when Bob walks in, Bob would have 50/50 odds on the remaining doors. At least, he would until he asked Alice which door she picked, at which point he would get the same 2/1 odds in favour of the door Alice didn't pick that she has.
  • #112
1/5 1 2 3 4 5
1/4 1 2 3 4
1/3 1 2 3
1/2 1 2
1/1 1
You simply need three glasses, a stone, and a contestant.
1- Hide the stone in one of the three glasses.
2- Tell the contestant to choose a glass.
3- Instead of revealing whether that glass contains the stones, uncover one of the glasses they didn't choose that doesn't contain the stone.
4- Finally, offer them a switch and wait for their response.
5- Record the results, and once you've verified that what we're saying is correct, write to PF to thank us for the explanation..
  • #113
Cool, but three playing cards would be a lot more efficient an expedient.
  • #114
True, I didn't see the simplified version Ibix proposed. Simply using the three cards is enough.
  • #115
You could use the whole deck. The ace of spades is the prize and every other card is not. After the contestant chooses one card face down then Monty discards 50 non-prizes face up and offers the switch with the remaining card.
It should be pretty easy to distinguish a probability of 1/2 from 1/52. With 9 trials there is p=0.980 that 1/2 will have less than 7 successes and p=0.988 that 51/52 will have more than 7 successes.
EDIT: I just tried this version 5 times. One person (a young child) quickly decided to stay with their original choice twice and lost both times. One other adult went through the 50 non-prizes twice, thought about it for like 2 or 3 minutes, then decided to switch and won. Another two adults understood immediately, switched and won.
So overall 5 out of 5 experiments had the expected (by me) result. This result is consistent with 51/52, and rather inconsistent with 1/2, but not conclusively.
  • #116
It should also be noted that, in practice, offering a switch is a provocation. Far more people than usual, when offered a switch, think, "If they're offering me a switch, it must mean something". They accept the switch without needing to understand the probabilistic framework.
It's a difficult experiment to conduct without skewing the results. I'm testing the card version of Ibix, and I've noticed that too many people accept the switch based on the flawed argument described above.
  • #117
javisot said:
...I've noticed that too many people accept the switch based on the flawed argument described above.
OK, a case of wrong logic leading to the right answer. IOW, Monty's actions are trying to help them win.
  • #118
It's a Rorschach test. I would reject the switch because I am a paranoid person. ;-)
  • #119
Yeah! That may actually be the gotcha - a deliberate ruse, depending on whether one trusts Monty to give away a whole car, or nah.
  • · Replies 212 ·
17K
  • · Replies 30 ·
  • · Replies 89 ·
11K
  • · Replies 21 ·
16K
