Please explain this limit problem
The discussion focuses on understanding the steps involved in calculating the sum of natural numbers from 1 to N. It explains a grouping method where pairs of numbers from opposite ends of the series are added together, leading to a formula of (N + 1) * (N/2). Participants clarify how the replacement of 'n' with 'n-1' in the fourth step relates to the summation process. The explanation aids in grasping the overall limit problem and its derivation. The conversation concludes with a participant expressing appreciation for the clarification.
rishi kesh
OP warned about not using the homework template
Please explain the above limit problem.i am able to understand last steps but can't get initial 4 steps.
The sum of natural numbers 1 to N. Is that the part you are confused about?
Let's do an example. Say you want to add the numbers 1 to 10. You can group them: Take the first number and the last number (1 + 10) then 2nd number and next to last (2 + 9), then (3 + 8) etc. Each grouping adds to 11 {N+1}. There are 5 groupings {N/2}. So in general, we have (N + 1) * (N/2). This works with odd N values as well.
Likes rishi kesh
Let's do an example. Say you want to add the numbers 1 to 10. You can group them: Take the first number and the last number (1 + 10) then 2nd number and next to last (2 + 9), then (3 + 8) etc. Each grouping adds to 11. There are 5 groupings. So in general, we have (N + 1) * (N/2). This works with odd N values as well.
This trick is something interesting to know about. I will remember it.appreciate your help :smile::smile:
Likes scottdave
But of you look at the 4th step they replaced 'n' by n-1 ..how do that work?
The comment appears to be misplaced. The replacement occurs one step above, going from ##\sum_{r=1}^n## to ##\sum_{r=1}^{n-1}##.
Oh i got it. :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
