Please help me evaluate this seemingly simple integral
  • Thread starter Thread starter tamtam402
    Integral
The discussion revolves around evaluating the integral X(ω) = ∫ x(t)e^(-iωt) dt, where x(t) is defined as e^(-100t)u(t) with the unit step function u(t). The integral is to be evaluated from -∞ to ∞, leading to questions about the contributions from different intervals due to the nature of x(t).
  • Participants explore splitting the integral into two parts based on the definition of x(t) for t < 0 and t ≥ 0. Some question whether the negative half of the integral contributes anything, while others express confusion about the limits and properties of the exponential function in the context of the integral.
The discussion is ongoing, with participants providing insights and corrections to each other's reasoning. Some have noted potential mistakes in the setup and evaluation of the integral, while others are clarifying the role of the unit step function in defining x(t).
There is a focus on the limits of integration and the behavior of the exponential function as the limit approaches infinity. Participants are also addressing language barriers that may affect understanding of the mathematical concepts involved.
tamtam402
Let x(t) = e-100tu(t)
u(t) = 0 for t < 0
u(t) = 1 for t > 0
Evaluate the following integral (from -∞ to ∞):
X(ω) = ∫ x(t)e-iωtdt
See below.
I tried to evaluate the integral by splitting it in two parts, since x(t) takes two different values. Keep in mind I'm replacing ∞ with a to evaluate the limit later.
from -∞ to 0:
X1(ω) = ∫ e-iωtdt
X1(ω) = (1/-iω) e-iωt (from -∞ to 0)
X1(ω) = (1/-iω)(1 - eiωa)
from 0 to ∞:
X2(ω) = e-100∫ e-iωtdt
X2(ω) = e-100 (1/-iω) e-iωt (from 0 to ∞)
X2(ω) = e-100 (1/-iω)(e-iωa - 1)
X(ω) = X1(ω) + X2(ω) = (1/-iω)(1 - eiωa) + e-100 (1/-iω)(e-iωa - 1)
= (1/-iω) (1 - eiωa + e-100e-iωa - e-100)
This is where I'm stuck. The answer is supposed to be X(ω) = 1 / (100 + iω), and I have absolutely no idea how I'm supposed to get there. Would someone mind helping me out?
Doh, it looks like I failed hard, I accidently put x(t) = e-100 instead of x(t) = e-100t. However when I tried to solve the problem earlier I got that right and I still didn't end up with the right answer (I re-did the problem from scratch when posting here). Is there a "trick" to solve this?
shouldn't the negative half of the integral be zero?
also don't forget to take the limit for a as well
lanedance said:
shouln;t thenegative half of the integral be zero?
edit: sorry of some of my vocabulary is hard to understand, english isn't my primary language. I got the positive part of the integral right (it gives me the correct answer), I fixed the mistake I did in my first post. However I can't see how the negative part is supposed to be zero.
Well I see that it's supposed to be zero given the form of the answer, but I don't see how lim a -> ∞(1 - eiωa) can give zero, unless it's a special property of the exponent with the imaginary number i. Note that I'm taking the limit of a to infinity since I replaced the -∞ with -a earlier, thus cancelling the negative sign of the exponent.
based on x(t)=0 for t<0, it should just be the integral of zero
You have defined [itex]u(t)=0[/itex] when [itex]t<0[/itex] and [itex]x(t)=e^{-100t}\cdot u(t).[/itex]
Yes, but I'm not evaluating the integral of x(t), I'm evaluating the integral of X(ω), which is different from x(t). Sorry if the notation is confusing, I used the variables given in the problem.
from -∞ to 0:
X1(ω) = ∫ e-iωtdt
Did you forget x(t) from the integrand?
Wow I'm a dumbass, somehow I had x(t)=1 when t **< 0. Thanks everyone.
No problem. I suspect that we have all made these kinds of mistakes, it often happens to me when the problem statement is complicated. :)
