Plotting Kinetic Energy of Mass Against Time and Distance
The discussion revolves around a physics problem involving the calculation of kinetic energy for a mass subjected to a horizontal force. The mass is initially at rest and moves a specified distance under constant acceleration, with participants exploring the relationships between kinetic energy, time, and distance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants attempt to calculate work done and kinetic energy using various equations. Some question the validity of their calculations, particularly regarding the relationship between kinetic energy and work done. Others explore how kinetic energy changes with time and distance, suggesting the need for a deeper understanding of the physics involved.
The discussion is ongoing, with participants providing feedback on calculations and suggesting further exploration of the relationships between kinetic energy, time, and distance. Some participants have offered guidance on how to approach the problem, while others are still seeking clarification on specific calculations and concepts.
There are discussions about the assumptions made in the problem, such as ignoring air resistance and the implications of friction. Participants are also addressing discrepancies in calculated values for acceleration and kinetic energy, indicating a need for careful consideration of the physics principles involved.
rikiki
A horizontal force of 80N acts on a mass of 6kg resting on a horizontal face. The mass is initially at rest and covers a distance of 5m in 0.92s under the action of the force. Assuming there are no energy losses due to air resistance and therefore that the acceleration is constant.
A) Calculate the energy expended in the acceleration.
B) Plot a graph of the kinetic energy of the mass against time.
C) Plot a graph of the kinetic energy of the mass against distance.
K.E.= (mv^2)/2,
V= ∆s/∆t
S= d/t
A) Work=force ×distance
W=fD
W=80 ×5
W=400J
B) Speed= distance/time
S= d/t
S= 5/0.92
S=5.4348m/s
Velocity= (change in speed)/(change in time)
V= ∆s/∆t
V= 5.4348/0.92
V=5.907ms^(-1)
K.E.= (mv^2)/2
K.E.= (6 × 5.907^2)/2
K.E.= 104.678J
If correct, on the x-axis i'd have time in s, on the y-axis K.E. in Joules. I'd draw a straight line from 0,0 to 0.92,104.678?
C) Similarly to answer B, except with distance on the x-axis and K.E. on the y axis. I'd draw a straight line from 0,0 to 5,104.678?
If anybody is able to check my answers and provide some guidance i'd be most grateful.
W=fD
W=80 ×5
W=400J
looks good to me.
S= d/t
S= 5/0.92
S=5.4348m/s
Not when you are accelerating - your speed is changes with time.
You need the equation of how speed depends on time.
[itex]v(t)=at+v_0[/itex] (use the v-t graph for the motion).
If you put [itex]F=ma[/itex] into [itex]W=Fd[/itex] you get [itex]W=mad[/itex] (you always knew work was mad right?) You are given the mass and the distance, you just calculated the work - so [itex]a=W/md[/itex]. (or just a = F/m but the previous was more entertaining!)
You should be able to finish from there.
Note: you won't get very far by just applying equations - you need to understand the physics they describe.
Thanks for your help. So I've got:
Kinetic Energy= (mass × velocity^2)/2
K.E.= (mv^2)/2
Velocity= initial velocity+(acceleration ×time)
V=v0+at
Work=mass ×acceleration ×distance
W=mad
a= w/md
a= 400/(6 × 5)
a=13.33 ̇m/s
V=v0+at
V=0+(13.33 ×0.92)
V=12.266 ̇ms^(-1)
K.E.= (mv^2)/2
K.E.= (6 ×12.266^2)/2
K.E.=451.36J
With my graphs looking like the attachments. Does this now seem correct?
Should KE change at a constant rate?
Lets see, v is proportional to t since v(t)=at
KE is proportional to v-squared
so how does KE change with time?
If you still don't see it, computer the kinetic energy at times: t= 0.1s, 0.2s, 0.3s etc and plot them.
(I could just tell you but if you do this you will learn.)
Time v K.E.
0 0
0.1 5.07
0.2 21.32
0.3 47.98
0.4 85.29
0.5 133.27
0.6 191.9
0.7 261.2
0.8 341.16
0.9 431.78
0.92 451.36
So Kinetic Energy will increase exponentially?
Thanks for you help so far it's been awesome of you.
Confirm your conclusion! If it is exponential, then a plot of ln(KE) against time will be a line. Is it?
What if you plot KE against t2: is that a line?
You were kind-of expected to reason like this:
[itex]K=\frac{1}{2}mv^2[/itex] but [itex]v=at[/itex]
so: [itex]K=\frac{1}{2}ma^2t^2[/itex]
so: kinetic energy depends on the square of the time.
Should the kinetic energy exceed the work done?
The question states ignore all forces and assume the acceleration is constant. So 451 J seems excessive
I get the acceleration to equal 12.551 m/s (constant) and velocity at 11.547 @ .92 seconds
Using k=1/2*m*v^2
.5*6*11.547^2=399.99 J
Then use V=at to get the velocity to use at different times I.e 0.1, 0.2 to plot the graph
This KE
EK gained should not exceed the work done, no.
But your re-calc'ed EK is 399.99J and the work done is Fd=400J so you are fine.
The difference is lost to friction with the surface - but that's a very very slippery surface!
Check your working:
... a distance of 5m in 0.92 seconds - constant acceleration.
a=2d/t2 = 10/(0.92)2 = 11.815ms-2
... that looks better.
I think you used work to compute acceleration - but you forgot friction (only air resistance was ruled out.)
v=at will give you EK vs t data - correct.
v2=2ad will give you EK vs d data
That makes sense,
I now get KE = 354.442 J at 0.92 seconds (v=at)
And..
KE=177.22 J at 5 meters (v^2=ad)
But you have 5m at 0.92s... so they can't both be right?!
Which one is correct?
Pardon my mistake...
I calculated v^2=ad when I should have used v^2=2ad
Giving 354.442 J
Then use the (d) at 1, 2, 3 m etc and implement them into the equation to get my graph points..
Does 354.442 J seem like it will be the correct answer?
Well if you look at it, it is less than the work, which is good.
The difference is the energy lost to friction.
Also you did it two different ways and got the same answer.
Which should give you confidence.
Use points closer together. I use gnu octave:
Code:
a=11.19;
m=6;
t=0:0.02:0.92; %prepares 46 points
d=0:0.125:5; %prepares 40 points
Et=0.5*m*(a*t).^2;
Ed=m*a*d;
subplot(2,1,1)
fplot(t,Et)
title{"Kinetic Energy vs time"}
subplot(2,1,2)
fplot(d,Et)
title("Kinetic energy vs distance")
Thanks for the great help Simon,I'll get on with them graphs
Calculate the coefficient of friction between the mass and the surface
a = 11.815 m/s2
Fn = m*a Difference between 80N and the friction Ff
m*a = 6*11.815 = 70.89 N
Ff = 80 – 70.89 = 9.11 N
Ff = mu*m*g
mu = Ff / (m*g)
9.11/(6*9.81)= 0.154
Using conservation of energy is more elegant and gets you there faster:
Total work is equal to the work done to accelerate the mass plus that done against friction. Thus, work against friction = 400-354.44=45.56J = Ff.d
Thus Ff = 45.56/5 = 9.11N ... just the same.
You're getting the hang of this :)
so what do the graphs look like?
Did anyone publish the plotted graphs for this..?
Using k=1/2*m*v^2
This KE
How did you get acceleration to equal 12.551 m/s?
Using w/md=a I got 13.33 m/s which ended up giving me 451.19J @ 0.92s which has already been pointed out to be too high a value for the KE. I can't see where I'm going wrong??
Anyone got the solution to this question for calculating the acceleration as 12.551?
Which formula was used.
Anyone able to help with the correct acceleration formula for this problem, like Carlo, i used Newtons second law which ended up giving me 451.19J, more than the work done value so incorrect.
Coefficient
a = 11.815 m/s2
Ff = mu*m*g
mu = Ff / (m*g)
Charger9198, can I ask where you got the 'a = 11.815 m/s2 from please?
Thanks
anyone got a definite solution to this?
im struggling to get my answers for acceleration to match up with yours
i am also working on this question
here is the graph i have for kinetic energy against time
i am now working towards the kinetic energy against distance graph, any help is much appreciated!
MOLLYCODDLE
s=(at)^2 / 2
So from the question, s=5m
5=a(0.92)^2 / 2
re-arrange
5=a(0.4232)
a=5/0.4232 = 11.815ms^-1
Reebo was your graph correct for post #23? If so what equations did you use to find the values for the various time intervals? Also did you manage to complete the second graph?
Big Jock said:
Hi Simon could you please tell me the formula used to plot a graph of kinetic energy of mass against time? I have distance intervals from 0m to 5m. I know the kinetic energy against time formula is
Ke=1/2ma^2t^2
just struggling with this last one.
Hope you can help
There should be enough information in the posts.
What have you tried?
Its ok Simon I worked it out. Like you said more than enough info in the posts.
As regards to the co-efficient of Friction calculation, between the Mass and surface. Isn't the formula F=umg, where u=Co-eff of friction, m=Mass and g=gravitational effect?
So with F=umg, then u=F/mg
Giving u=80/6x9.81 = 1.359 as the frictional co-efficient?
I am really stuck on the 2nd graph on this question. Plot a graph of the kinetic energy of the mass against distance?
Any help would be greatly appreciated. I have tried to work out the formula but I have confused myself now.
  • · Replies 22 ·
