Troubleshooting PN and Zener Diode Circuit Fluctuations: Tips and Solutions
  • Thread starter Thread starter ajaykrishna90
    Diode
The discussion centers on troubleshooting fluctuations in a PN and Zener diode circuit when connected manually, as opposed to using a diode box. Users report inconsistent readings, particularly when measuring current beyond 0.3V. A current divider circuit is recommended to extend the ammeter's range, and attention is drawn to the importance of a voltage-dropping resistor to prevent exceeding the diode's current limit. Participants seek additional circuit diagrams for clarity.
  • Understanding of PN and Zener diode characteristics
  • Basic knowledge of circuit design and manual connections
  • Familiarity with current measurement techniques
  • Experience with current divider circuits
  • Research current divider circuit design and implementation
  • Learn about voltage-dropping resistors and their applications in diode circuits
  • Explore advanced ammeter calibration techniques for accurate readings
  • Find and analyze circuit diagrams for PN and Zener diode configurations
Electronics enthusiasts, circuit designers, and anyone troubleshooting diode circuits who require insights into current measurement and circuit stability.
ajaykrishna90
When pn and zener diode is connected according to the circuit diagram(manual not diode box,ie, by connecting wires) it shows great fluctuations and readings can't be able to take. What may be the reason for this and how can i rectify?
Welcome AJ - but you have to provide more info..
I mean, when measuring 0v -0mA then .1v-0mA then 0.2v-0mA then 0.3v-100mA then 0.4v- 500mA ,thats the final range (500mA) for milli ammmeter. So how can i take readings after 0.3v?
If you read up on a current divider - you can make a small circuit to extend the range of your ammeter. The data above looks valid for a diode. Note the diode also has a current limit - , so a voltage dropping resistor may also be important to look into...
Thanks windact. Any simple circuit diagram is available?
29K
  • · Replies 43 ·
