Point charge(Q) has a divergence zero
  • Context: Undergrad
  • Thread starter Thread starter bharath423
    Divergence Point Zero
The discussion revolves around the divergence of the electric displacement field (D field) due to a point charge (Q) and its implications in relation to Gauss's law. Participants explore the mathematical properties of divergence, the behavior of fields at singularities, and the application of Gauss's law in these contexts.
  • Some participants note that the D field due to a point charge has a divergence of zero when calculated away from the singularity at r=0.
  • Others argue that Gauss's law indicates the divergence should be finite due to the presence of charge, raising questions about the conditions under which divergence is calculated.
  • A participant points out the singularity at r=0, stating that a regular volume integral cannot be performed over a region that includes this singularity, but a surface integral can be formed.
  • It is suggested that to apply Gauss's law correctly, the function must be defined at all points in the region, which is not the case here.
  • One participant proposes that if divergence could be calculated at r=0, it would yield results consistent with Gauss's law, leading to a discussion about divergence being zero everywhere except at sources.
  • Another participant emphasizes that divergence should be treated as a distribution when dealing with singularities, and suggests a method for calculating divergence near point charges.
  • References to Griffith's Introduction to Electrodynamics are made for further clarification on the topic.
Participants express differing views on the application of Gauss's law to the divergence of the D field at singularities. While some agree that divergence is zero away from sources, others challenge the implications of this in relation to Gauss's law, indicating that no consensus exists on the interpretation of divergence in this context.
Limitations include the undefined nature of the vector field at r=0, which complicates the application of Gauss's law. The discussion also highlights the need to consider singularities when calculating divergence and the distinction between functions and distributions in physics.
bharath423
The D field due to a point charge(Q) has a divergence zero
D = (Q/(4*pi*r2)) ar (ar --- unit vector)
if we calculate the divergence we get zero.
but Gauss law says that the divergence is a finite value not zero because a charge is present in there.
is it that in calculating divergence we also take a particular surface?
where I am wrong? I am confused of divergence..i tried wikipedia but could understand it upto my extent..i think somebody could help me
1.Note the singularity of your vector field at r=0.
2. You cannot make a regular volume integral over a region that includes this singularity, but you can perfectly well form a regular surface integral over a region containing that point in its interior.
3. In order for the premises of Gauss' law to be strictly fulfilled, your function must be defined at ALL points in the region; since this is not the case here, you cannot really apply Gauss' law.
4. It IS possible, however, to construct an irregular volume integral in this case, though, by representing the divergence of your vector field as a Dirac delta "function".
so the divergence at a point shows the sink or source at a given point...so if at r=0 we are able to calculate the divergence then it would be equal to Gauss law result..is that what you are saying?
if that is so, then divergence for every field except at the source of the field, every where it should be zero then..is it true?
We CAN'T compute it at r=0 because the vector field isn't defined there. Therefore, rigorously, it has no meaning trying to apply Gauss' law, and thus, Gauss' law isn't "invalidated" by this case since the vector vield falls outside the class of vector fields Gauss' law is speaking about.
Yes.
so divergence is calculated at a particular point only...then in case we calculate for a surface then we get all the sources and sinks which is nothing but the total charge...and this is what gauss law says ..im correct??
I'd have to disagree with you there. Many quantities in physics are loosley called "functions", but are really distributions. This is true of charge density. For some idealized continuous charge distributions, you can represent the charge density as a function, but most of the time it can only be represented as a distribution. So, since Gauss' Law (for \textbf{E} or \textbf{D}) involves charge density (total or free), which is a distribution, it should be understood that the divergence of \textbf{D} should be treated as a distribution and calculated accordingly.
@bharath423
You need to be careful when calculating the divergence near point, line, or surface charges. The easiest method to find the correct distribution is to calculate the divergence normally everyhwere except near you singularities (in this case, everywhere except a small region around your point charge), and then calculate the flux through any closed surface surrounding a single singularity, and using the divergence theorem, deduce what the divergence must be in the visciunity of that singularity.
For your case, you should take a look at Griffith's Introduction to Electrodynamics where the Author calculates the divergence of \frac{\hat{\mathbf{r}}}{r^2}. IIRC it is near the very end of the 1st chapter.
  • · Replies 18 ·
