Point charges on square - find magnitude of force
The discussion focuses on calculating the magnitude of the force experienced by a negative point charge located at one corner of a square, with three positive point charges at the other corners. The charges have a magnitude of 12.92 x 10^-6 C, and the square has a side length of 65.5 cm. Using Coulomb's law (F = k * |q1 * q2| / r^2), participants detail the process of finding the force vectors exerted by the positive charges on the negative charge, emphasizing the importance of vector addition and direction. The final formula for the net force incorporates the components of the forces from each charge.
  • Coulomb's Law for electric forces
  • Vector addition and components
  • Basic trigonometry (sine and cosine functions)
  • Understanding of electric charge and field concepts
  • Learn how to apply Coulomb's Law in different configurations of point charges
  • Study vector addition techniques for forces in two dimensions
  • Explore electric field calculations using kq/r^2
  • Investigate the effects of charge distribution on net force and electric fields
Students and professionals in physics, electrical engineering, and anyone involved in electrostatics or force calculations in charged systems.
pringless
Four point charges, each of magnitude 12.92 x 10^-6 C, are placed at the corners of a square 65.5 cm on a side. Given K_e = 8.98755 x 10^9 Nm^2/C^2. If three of the charges are positive and one is negative, find the magnitude of the force experienced by the negative charge. Answer in units of N.
can someone help me out with this? thanks
Can you find the force that each positive charge exerts on the negative charge? (Hint: Coulomb's law) Draw yourself a picture to keep the direction of each force straight. Now add the force vectors up. (Another hint: take advantage of fact that the charges are symmetrically distributed; you should be able to tell which direction the net force points.)
im not sure what u mean
this is what i tried
i found the magnitude of each vector using kqq/r^2
then i squared all 3 magnitudes and added, and then took the square root. but its wrong.
what can i do?
You found each separate force vector. Excellent. Now describe the direction of each vector. You must first add these vectors before you can find the magnitude of the resultant force. I have attached a picture of the four charges that may prove helpful. Why don't you use the picture to describe the forces.
Oops... here it is.
how do i receive the attachment?
Oh well, the attachment doesn't seem to be working. Why not draw one of your own?
i think i have the directions correct, how do i add the vectors here?
To add the vectors, I suggest finding their components. Add the components, then you can find the magnitude of the resultant.
i keep getting it incorrect
i would use cos45 for the x compoenent and sin45 for the y right?
then i add those components to the other two magnitudes?
Not quite. Let's do it step by step. It looks like my diagram did finally make it into the system; go to my previous posts and take a look.
Charges at A, B, and C exert forces on the negative charge at D. Tell me the x and y components of each of those forces.
F_db*cos45 and F_db*sin45 ?
Which force is this? Do it systematically for each force:
What force does A exert on D: magnitude and x & y components.
What force does B exert on D: magnitude and x & y components.
What force does C exert on D: magnitude and x & y components.
this is my view of it.
A+ B+
C- D+
F_ad = kqq/R^2
F_dc = kqq/R^2
F_bc = kqq/(sqr(x))^2 [x = distance of side of square]
F_bc_x = kqq/(sqr(x))^2 * cos45
F_bc_y = kqq/(sqr(x))^2 * sin45
A+ B+
C- D+
I just realized that you were drawing your own diagram. D'oh!
F_ad = kqq/R^2
F_dc = kqq/R^2
Here's what I get (using your diagram) for the forces on C:
F_{AC} = \frac{kq^2}{x^2} (magnitude)
F_{BC} = \frac{kq^2}{2x^2} (magnitude)
F_{DC} = \frac{kq^2}{x^2} (magnitude)
Now the components:
F_{AC-x} = 0; F_{AC-y} = \frac{kq^2}{x^2}
F_{BC-x} = \frac{kq^2}{2x^2}cos(45); F_{BC-y} = \frac{kq^2}{2x^2}cos(45)
F_{DC-x} = \frac{kq^2}{x^2}; F_{DC-y} = 0
Add the components:
F_{x} = \frac{kq^2}{x^2}(1 + \frac{cos(45)}{2})
F_{y} = \frac{kq^2}{x^2}(1 + \frac{cos(45)}{2})
Now the magnitude of the resultant:
F_{net} = \sqrt{2}\frac{kq^2}{x^2}(1 + \frac{cos(45)}{2})
Plug in the numbers and you'll get your answer. (Unless I goofed.)
for the part where you showed the y component do you mean sin45 or is it really cos45?
sin(45)=cos(45), so it doesn't matter.
hah oh right..forgot
thanks for ur patience and help doc, ill reply back to tell you if the answer is correct
It's correct. Thanks a bunch Doc.
You are welcome. :smile:
I have a similar problem only it wants the magnitude of the net electric field that exists on the center of the square. I swear I have tried everything to get this answer but I have not been successful and needless to say, the book isn't helpful at all. The formula for an electric field is kq/r^2 or F/q(test charge). I realize this topic is a bit old but I stumbled upon it while searching for help. Any help you could provide would be a great help. Thanks a lot :)
