Point of Intersection involving logarithms
The discussion focuses on solving for the point of intersection between the logarithmic functions \(y=\log_{2}(2x)\) and \(y=\log_{4}(x)\). The correct approach involves setting the equations equal and manipulating the logarithmic identities, ultimately leading to the equation \(2x=\sqrt{x}\). The solutions derived from this equation are \(x=0\) and \(x=\frac{1}{4}\), with \(x=0\) being excluded due to domain restrictions. The final intersection point is confirmed as \(x=\frac{1}{4}\).
  • Understanding of logarithmic functions and their properties
  • Familiarity with base conversion in logarithms
  • Knowledge of solving quadratic equations
  • Basic algebraic manipulation skills
  • Study logarithmic identities and their applications in solving equations
  • Learn about base conversion techniques in logarithmic functions
  • Explore quadratic equations and their solutions in depth
  • Practice solving intersection points of different types of functions
Students studying algebra, particularly those focusing on logarithmic functions, educators teaching mathematical concepts, and anyone looking to enhance their problem-solving skills in calculus and algebra.
Potatochip911
Solve for the point of intersection between ##y=\log_{2}{(2x)}## and ##y=\log_{4}{(x)}##
3. The Attempt at a Solution [/B]
Setting the two equations equal:
$$\log_{2}{(2x)}=\log_{4}{(x)}\\
2x=2^{\log_{4}{(x)}} \\
2^{2x}=4^{\log_{4}{(x)}}\\
2x=2\log_{4}{(x)}\\
x=\log_{4}{(x)} \\
4^x=x \\ $$
I'm really confused and I'm pretty sure I've done something wrong at this point.
2x=2^{\log_{4}{(x)}} \\ On the right hand side, write 2 as 41/2 .
2x=2\log_{4}{(x)}\\
x=\log_{4}{(x)} \\
4^x=x \\ $$
You're right about that.
If you use each side of
##\displaystyle \ 2x=2^{\log_{4}{(x)}}\ ##​
as the exponent with a base of 2, you get
##\displaystyle \ 2^{2x}=2^{\left(\displaystyle {2^{\log_{4}{(x)}}}\right)}\ ##​
Furthermore,
##\displaystyle \ \left({2^{2}}\right)^{\log_{4}{(x)}}\ne2^{\left(\displaystyle {2^{\log_{4}{(x)}}}\right)}\ ##​
Furthermore,
Managed to get the correct answer after rewriting ##2## as ##4^{1/2}## like you mentioned. $$2x=2^{\log_{4}{(x)}} \\
2^{2x}=2^{2^{\log_{4}{(x)}}}\\
2^{2x}=2^{4^{1/2 \cdot \log_{4}{(x)}}}\\
2^{2x}=2^{x^{1/2}} \\
2x-\sqrt{x}=0 \\
\sqrt{x}(2\sqrt{x}-1)=0 $$ Giving x=0 and x=1/4, with x=0 not being a solution since it's not in the domain, thanks for the help!
2x=2^{\log_{4}{(x)}}$$
A suggestion to make things a bit easier is:
Rather than using 2 as the base, use 4 as the base. Then change the base on the left hand side to 22 .
##\ \left(2^2\right)^{\log_{2}{(2x)}} =2^{\log_{2}{(4x^2)}}=\,? \ ##
Okay it was definitely easier to do it this way.
  • · Replies 22 ·
  • · Replies 25 ·
