Point on plane closest to point
  • Thread starter Thread starter JeeebeZ
    Plane Point
The closest point B on the plane defined by the equation x + 2y + 3z = 1 to the point A (4, 5, 6) is calculated using vector projections and the normal vector n = [1, 2, 3]. The correct coordinates for point B are (25/14, 8/14, -9/14). The distance from point A to point B is approximately 8.2851, which aligns with results from online calculators when the plane equation is correctly inputted as x + 2y + 3z = 1. Miscalculations and sign errors were common issues discussed among participants.
  • Understanding of vector projections and normal vectors
  • Familiarity with the equation of a plane in three-dimensional space
  • Basic knowledge of distance formulas in Euclidean space
  • Experience with optimization techniques, such as Lagrange multipliers
  • Study vector projection techniques in three-dimensional geometry
  • Learn about Lagrange multipliers for constrained optimization problems
  • Practice calculating distances from points to planes using various methods
  • Explore online calculators and tools for verifying geometric calculations
Students in mathematics, particularly those studying geometry and optimization, as well as educators looking for problem-solving techniques related to planes and distances in three-dimensional space.
JeeebeZ
Find the point B on the plane x + 2y +3z = 1 that is closest to the point A (4,5,6).
2. The attempt at a solution
norm vector = n = [ 1 2 3 ]
A = (4,5,6)
a point C on the plane would (1,0,0)
CA vector = [ 3 5 6 ]
Projection of CA on to n = (CA.n / ||n||^2) n
= (((3*1) + (5*2) + (6*3))/14) n
= 3n
ProgCA(n) = [3 6 9]
So... That's where I am... I don't know if that would be the answer? B = (3, 6, 9)?
The reason I'm confused is if I enter the plane and point into different on-line calculators that are for distance between a point and a plane I get 8.8196 as the shortest distance.
But distance is the ||BA Vector|| = 3.316
I tried swapping the CA vector to AC Vector and I got B = (-3,-6,-9)
But then distance was 19.874.
So that didn't equate either. So.. I'm stuck and don't know what to look for next
Hmmm... I'd have found the equation of the line through A in direction of the normal ... where this intersects the plane is the closest point.
But there are several ways to do it. You could, for instance, find the equation of the distance from an arbitrary point on the plane to point A, then minimize it.
The trick to being confident that your answer is the correct one is to see if you can explain the geometry of your method, like the two examples above.
You can also do some basic tests to check - eg. is B a point in the plane?
A = (4,5,6)
= 3n
You miscalculated something. ((3*1) + (5*2) + (6*3))/14)=31/14
ehild
That would have been the smartest thing to do...
3 + 2*6 + 3*9 != 1... /sigh
I think the meta-skill here, of checking your answers and choosing methods that allow you to be confident of your results, is actually more important than solving the actual puzzle in front of you.
A = (4,5,6)
= 31/14n
ProgCA(n) = [31/14 62/14 93/14]
So I should be looking for A - ProgCA(n)...
( 25/14, 8/14, -9/14 )
(25 + 2*8 - 9*3)/14 = 1
(25 + 16 - 27) / 14 = 1
14 / 14 = 1
1 = 1
So the point B on the plane that is closest to A would be (25/14, 8/14, 9/14)
http://desmond.imageshack.us/Himg513/scaled.php?server=513&filename=junkh.png&res=landing
Hmm.. See I still don't think that's right.. b/c when i calculate the distance it comes out to be 7.825.. and I know it is 8.819 based off of calculators for distance from a plane. And I've used more then one just to make sure that the calculator wasn't wrong. :p
Code:
x    4     1
y = 5 + t2
z    6     3
x = 4    t
y = 5 + 2t
z = 6    3t
4 + t + 2( 5 + 2t ) + 3( 6 + 3t ) = 1
4 + 10 + 18 + t + 4t + 9t = 1
32 + 14t = 1
t = -31/14
Which would give me ( 25/14, 8/14, -9/14 )
Same answer as the last one.. these are the only 2 methods i know and they are both wrong :(
You meant -9/14 for z... It is correct. You might have some rounding errors when calculating the distance. The projection of CA onto n is CAdot n /||n||=31/√14=8.28
Have you learned about the Lagrange multiplier method to find conditional extrema?
http://www.encyclopediaofmath.org/index.php/Lagrange_multipliers.
You have to find the minimum distance between a point in the plane P(x,y,z) and point A, that is the minimum of d2=(x-4)2+(y-5)2+(z-6)2 with the condition that x + 2y +3z -1 =0. Multiply the condition with the Lagrange multiplier λ and add to the function to be minimised. Find the values of x,y,z which make the partial derivatives of (x-4)2+(y-5)2+(z-6)2+λ(x + 2y +3z -1)
all zero and fulfil the condition.
ehild
wow...
I've been entering the calculation as a point P(4,5,6) and equation 1x + 2y + 3z + 1 = 0... not -1 but 1.
So I was entering the equation x +2y +3z = -1... that's why i kept getting 8.8...
I get 8.2851 when i calculate ||A - B||... the online one gives 8.285098499285...
I swear if I could go one day without a sign error somewhere in my problems... I would be happy
Never mind...It happens with everybody. :biggrin:
ehild
