Pointwise vs. uniform convergence
The discussion centers on the concepts of pointwise and uniform convergence in the context of bounded functions. A function is pointwise bounded on a set E if for every x in E, there exists a finite-valued function φ such that |f_n(x)| < φ(x) for n = 1, 2, .... In contrast, a function is uniformly bounded on E if there exists a constant M such that |f_n(x)| < M for all x in E and all n. The participants clarify that while pointwise boundedness can imply uniform boundedness in finite domains, this equivalence does not hold in countable or uncountable domains due to the potential for supremum to be unbounded despite pointwise boundedness.
  • Understanding of pointwise and uniform convergence
  • Familiarity with bounded functions and their definitions
  • Knowledge of supremum and maximum concepts in real analysis
  • Basic grasp of function behavior over finite and infinite domains
  • Study the definitions and differences between pointwise and uniform convergence in detail
  • Explore examples of functions that illustrate the distinction between pointwise and uniform boundedness
  • Learn about the implications of boundedness in finite versus infinite domains
  • Investigate the role of supremum in real analysis and its relation to bounded functions
Mathematicians, students of real analysis, and anyone interested in the properties of functions and convergence in mathematical analysis.
ForMyThunder
A function is pointwise bounded on a set E if for every x\in E there is a finite-valued function \phi such that |f_n(x)|&lt;\phi(x) for n=1,2,....
A function is uniformly bounded on E if there is a number M such that |f_n(x)|&lt;M for all x\in E, n=1,2,....
I understand that in uniform boundedness, the bound is independent of x and in pointwise convergence it is dependent. My question is this: if we take M=\max\phi(x), then since \phi is finite-valued, wouldn't this make every pointwise bounded function a uniformly bounded function? I don't understand.
If E is the set (0,1) and \phi=\frac{1}{x}...
I think you can figure out the rest
Oh, thanks. It said finite-valued which I took to mean bounded.
I think for domain being a finite set, both notions coincide because maximum is indeed supremem. However, when it is either countable or uncountable domain, it is not necessary to have the equivalence between maximum and supremum. And it can turn out that supremum is unbounded depsite boundedness at each x. Office_Shredder showed a nice example.
Finite-valued must have merely meant that |\phi(x)| &lt; \infty for all x.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
