Polarization of clear plastic - a puzzle
The discussion centers on the behavior of a semi-transparent red gift wrap plastic when placed between two polarizers. The user observed that the plastic darkened at a specific angle between the polarizers, suggesting it may act as a polarizer. However, when tested with a single polarizer, no darkening occurred, indicating that the plastic is not a polarizer. The conversation highlights the plastic's potential role as a uniform retardation plate, prompting further exploration into wave retarders.
  • Understanding of polarization and polarizers
  • Familiarity with optical materials and their properties
  • Knowledge of wave retarders and their functions
  • Basic concepts of light behavior in different mediums
  • Research the properties and applications of wave retarders
  • Study the effects of biaxial materials on light polarization
  • Explore the photorefractive effects in various plastics
  • Conduct experiments with different types of polarizers and optical materials
Students and educators in optics, physicists interested in light behavior, and anyone experimenting with polarization effects in materials.
alanf
I finished my online E&M class today, and the prof told us to experiment with polarizers. While doing that, I found this: I put a piece of plastic between two polarizers, and found that at a certain angle between the two polarizers, a portion - though not all - of the plastic darkened. So I assumed that portion of the plastic sheet was a polarizer, for whatever reason. And I also assumed that a single polarizer, when used with this piece of plastic, would show darkening. But when I used a single polarizer, nothing happened, no matter how I rotated the polarizer. So that means the plastic actually is not a polarizer, right? So what was going on when it was between the two polarizers? This piece of plastic happens to be semi-transparent red gift wrap, if that helps.
Science news on Phys.org
Plastic can exhibit a wide variety of polarization effects: overhead transparency sheets are biaxial materials, most bulk plastic exhibits photorefractive effects, a single layer of Scotch tape is nearly a 1/8 wave retarder, IIRC:
http://www.quekett.org/resources/article-archive/magic-polarised-light
http://www.lhup.edu/~dsimanek/14/polaroid.htm
Your piece of plastic could have acted as a (somewhat) uniform retardation plate. What happens if you fold it on itself (to double the thickness)?
Thanks Andy. So it sounds like I need to read up on wave retarders. I'll take a look at the plastic again later today.
  • · Replies 22 ·
10K
  • · Replies 20 ·
  • · Replies 28 ·
  • · Replies 52 ·
