Polynomial Existence and Irreducibility over Rational #'s
11 replies · 3K views · last reply
RJLiberator
Prove that for all n ≥ 1, there exists a polynomial f(x) ∈ ℚ[x] with deg(f(x)) = n such that f(x) is irreducible in ℚ[x].
In mathematics, a rational number is any number that can be expressed as the quotient or fractionp/q of two integers, a numeratorp and a non-zero denominatorq
f(x) is called irreducible if it is not reduicble.
f(x) is reducible if there exists g(x)*h(x) such that f(x) = g(x)*h(x) and deg(g(x)) < deg(f(x)), deg(h(x)) < deg(f(x)).
http://mathworld.wolfram.com/IrreduciblePolynomial.html
Is it possible to use the quadratic discriminant here to show when no roots exist?
b^2 - 4ac ≥ 0
So we say whenever b^2-4ac < 0 then f(x) is irreducible.
And it would seem clear that you could always make a=c and a^2 > b^2...
Ouch. Nvm, this doesn't work for higher degree terms actually.
In that case, hm.
Could we work with cases, possibly induction?
Case n = 1. Then by definition f(x) is irreducible.
Induction step: n+1 can be irreducible.
Then no, this is not working.Is the division algorithm necessary?
Theorem 7 Let f be a polynomial with rational coefficients in lowest terms so that the numerators of the coefficients are relatively prime (i.e., have no common prime factor). Let d be the least common multiple (lcm) of the denominators of the coefficients of f. Let g = df. Then g has integer coef- ficients. Furthermore, f is irreducible over the rationals if and only if g is irreducible over the integers
Am I going in the right direction by observing the division algorithm?
Have you ever thought about unity roots or just powers of 2, e.g.?
Well, with powers of two we use the quadratic discriminant and see that b^2 - 4ac >= 0.
So we have that when b^2-4ac < 0 we have an irreducible polynomial.
This special discriminate is only for 2nd degree polynomials.
You only have to point out one irreducible polynomial for each degree.
So taking algebraic roots that are not in ℚ will do the job, e.g. roots of ##2^n##, e.g.
Even the roots of ##1^n## will be probably all but at most two outside of ℚ, which has to be proved.
(Att.: the all but 1 or 2 fact reduces the degree of the searched polynomials!)
Hm. I understand your point that the discriminant is only for second degree polynomials.
So I only have to point out one irreducible polynomial for each degree, I agree.
Algebraic roots that are not in Q will do the job, roots of 2^n. I'm not really following what you mean here.
I'm struggling to understand this hint, I can understand it is important.
Sorry, I have been too sloppy on that. I meant ##x^n -2 = 0## or ##x^{n-1}-1=0##.
This delivers ##n## roots, and with Euler's Formula it is easy to show that these roots are not in ℚ. However, ##±1## might be roots of the latter polynomial which are in ℚ! So you have to divide the polynomial by ##x±1## to get the irreducible part. But this irreducible part will then of course be only of degree ##n-1## or ##n-2##.
Okay, so what we are saying is:
Take an example polynomial x^n - 2 = 0
and show that it delivers n roots, say with Euler's Formula.
Then show that these roots are NOT in Q.
That was the plan, yes.
So let's try this:
Observe: x^n-2 = 0.
x^n = 2
x = nthroot(2)
Therefore, for every n this is not possibly in Q.
We observe now x^1 is irreducible by definition.
So now, I've shown that there exists a reducible polynomial for every degree n in Q[x].
RJLiberator said:
So let's try this:
Observe: x^n-2 = 0.
x^n = 2
x = nthroot(2)
You do know that there are polynomials with no roots in Q which are NOT irreducible, yes? Give me an example.
x^2+1 = 0
I think I solved this problem in class today. So help is no longer needed, it was the more exhausting proof of my latest homework assignment.
RJLiberator said:
x^2+1 = 0
Ok, but how did you prove it? x^2+1 IS irreducible over Q and has no roots. (x^2+1)(x^2+1) also has no roots. Is it irreducible?
