Polynomial of Jordan Decomposition
14 replies · 3K views · last reply
azdang
Let A be a real or complex nxn matrix with Jordan decomposition A = [tex]X \Lambda X^{-1}[/tex] where [tex]\Lambda[/tex] is a diagonal matrix with diagonal elements [tex]\lambda_1,...,[/tex] [tex]\lambda_n[/tex]. Show that for any polynomial p(x):
p(A)=[tex]Xp(\Lambda)X^{-1}[/tex]
[tex]p(\Lambda)[/tex] should really be the matrix with p([tex]\lambda_j[/tex]) on its diagonal for j=1,...,n but I couldn't figure out how to make that matrix in latex.
I'm guessing there should be a way to take p of both sides and somehow extract the X and X inverse, but I can't seem to figure it out. Does anyone see anything? Thank you.
Hi azdang! :wink:
(for matrices etc in LaTeX, see http://www.physics.udel.edu/~dubois/lshort2e/node56.html#SECTION00850000000000000000 )
Hint: if the polynomial is A2, then A2= XΛX-1XΛX-1 = XΛ2X-1 = … ? :smile:
Hey tiny-tim. Thank you for your response. Quick question: Is it okay to assume p(A) = [tex]A^2[/tex]? (This would be the polynomial p(x)=[tex]x^2[/tex] right?) Can we say that because the problem say 'for any polynomial'? Or is there a more general way to prove this?
Also, I do see then that [tex]\Lambda^2=p(\Lambda)[/tex], so that is all clear. Thank you very much. I'm just wondering if we should find a way to represent p(x) more generally?
Yes, we need to deal with a general p(x).
So you do still need to prove it for p(A) = An, for any n …
my n = 2 was just an example for you. :wink:
Alright, cool.
So, we could say p(x) = xn.
Then, p(A)=An=[tex](X \Lambda X^{-1})^n[/tex]=[tex]X \Lambda X^{-1}X \Lambda X^{-1}...X \Lambda X^{-1}[/tex].
All of the X's and X-1 will cancel out except for the ones on the edges so we are left with: p(A)=[tex]X \Lambda^n X^{-1}[/tex].
So, we know p([tex]\Lambda[/tex])=[tex]\Lambda^n[/tex]. Can we say that that is equivalent to the matrix with p([tex]\lambda_j[/tex]) on its diagonal where j=1,...,n because it is a diagonal matrix?
just got up :zzz: …
azdang said:
… So, we know p([tex]\Lambda[/tex])=[tex]\Lambda^n[/tex]. Can we say that that is equivalent to the matrix with p([tex]\lambda_j[/tex]) on its diagonal where j=1,...,n because it is a diagonal matrix?
Yes, of course (for Λm). :wink:
(I don't think the examiner would even expect a reason for that :wink:)
And then prove that it's "additive", in the sense that if B = XΛBX-1 and C = xΛCX-1 then ΛB+C = … ? :smile:
I'm kind of confused by this last part. I don't really understand the subscripts on Lambda or where B and C are coming from. Thank you again, tiny-tim, for helping me get through this :)
I mean, if B and C are real or complex nxn matrices with Jordan decomposition B = XΛBX-1 and C = XΛCX-1 and B + C = XΛX-1 where Λ ΛB and ΛC are diagonal matrices, what is the equation relating Λ ΛB and ΛC ? :smile:
But we cannot be guaranteed that the X's in the Jordan decompositions for B and C are the same, can we?
?? :confused:
Assume they are … then prove the proposition … and then use it to answer the original question.
Well then, does [tex]X\Lambda_B X^{-1} + X\Lambda_C X^{-1}=X(\Lambda_B + \Lambda_C)x^{-1}[/tex]?
Then [tex]p(\Lambda_B + \Lambda_C)=p(\Lambda_B)+p(\Lambda_C)[/tex], so the matrix would be the diagonal matrix with [tex]\lambda_B_j + \lambda_C_j[/tex] on the diagonal, j=1,...n, right? I'm not sure if I'm understanding all this, or why we are showing it is additive. Sorry!
That's right! :smile:
Because it's easy to prove the question for p(A) = Am, but not for p(A) = Am + Al …
so we just prove it for Am, show that it's the same X for any m, and then use the theorem above to prove that it's true for any sum of powers of A, ie for any polynomial. :wink:
Okay, I think I'm understanding, though I might have a hard time explaining it. One thing in what you just said that confused me, what do you mean 'show that it's the same X for any m'. I really can't thank you enough for walking me through this btw.
I mean, for example, A2 = XΛ2X-1 and A3 = XΛ3X-1 (and it's the same X, which was worrying you earlier :wink:)
Oooh, okay. Yes, I can see right away that they are the same X!
So, I should really just show this for:
p(x)=[tex]\alpha_0+\alpha_1x+\alpha_2x^2+...+\alpha_nx^n[/tex] for scalars alpha.
P.S. I totally just did this ^ and I TOTALLY get it. Again, thank you very very much!
