Position and acceleration in simple harmonic motion given velocity
16 replies · 3K views · last reply
zenterix
This problem is from Apostol's Calculus, Volume I.
A particle undergoes simple harmonic motion. Initially its displacement is 1, its velocity is 1, and its acceleration is -12.
Compute its displacement and acceleration when the velocity is ##\sqrt{8}##.
##F=ma##
A spring attached to a mass undergoes simple harmonic motion.
From Newton's second law we have ##ma=-qx## where ##q## is the spring constant.
$$x''+\frac{q}{m}x=0$$
A second order equation with constant coefficients.
The characteristic equation is ##r^2+\frac{q}{m}=0##. The roots are complex.
The discriminant is ##\Delta = -\frac{4q}{m}<0##.
Let ##k=\frac{1}{2}\sqrt{-\Delta}=\frac{1}{2}\sqrt{\frac{4q}{m}}##
Then the general solution to our differential equation is
$$x(t)=c_1\cos{kt}+c_2\sin{kt}$$
Since ##x(0)=1## then ##c_1=1##.
Then
$$v(t)=-k\sin{kt}+c_2k\cos{kt}$$
Since ##v(0)=1## then ##c_2=\frac{1}{k}##.
Then,
$$a(t)=-\frac{k}{m}x(t)$$
Since ##a(0)=-\frac{k}{m}=-12## then we can solve for ##q=\frac{24^2m}{4}##.
Thus, at this point we have
$$x(t)=\cos{kt}+\frac{1}{k}\sin{kt}$$
$$v(t)=-k\sin{kt}+\cos{kt}$$
$$a(t)=-\frac{k}{m}\cos{kt}-\frac{1}{m}\sin{kt}$$
Suppose ##v(t)=2\sqrt{2}##.
If we can solve for the corresponding ##t## then we can plug this ##t## into ##x(t)## and ##a(t)##.
But how?
You don't need to involve mass, force or spring constant. Neither do you need to solve any DE.
Just start with the trig function for x(t). Find ##c_1, c_2## as you did, but then apply the same method to acceleration to find k.
If we differentiate ##v(t)=-k\sin{kt}+\cos{kt}## to obtain ##a(t)=-k^2\cos{kt}-k\sin{kt}##, use ##a(0)=-12## and solve for ##k## we find ##k=2\sqrt{3}##.
Thus, ##v(t)=-2\sqrt{3}\sin{(2\sqrt{3}t)}+\cos{(2\sqrt{3}t)}##.
If we equate this to ##2\sqrt{2}## we still need to solve for ##t##.
zenterix said:
If we differentiate ##v(t)=-k\sin{kt}+\cos{kt}## to obtain ##a(t)##, use ##a(0)=-12## and solve for ##k## we find ##k=2\sqrt{3}##.
There are several ways to proceed.
You can move one of the trig functions across and square.
Or get the RHS into the form ##\sin(\alpha)\cos(\beta)+\cos(\alpha)\sin(\beta)##.
Or start over with the SHM form ##A\sin(\omega t+\phi)##.
I suggest doing this without ever involving trig functions (ie, you do not need the actual explicit form of the solution). Note that, apart from ##x’’ + \omega^2 x = 0##, this has a first integral ##x’^2 + \omega^2 x^2 = E## for some constant ##E##.
Should it be?
$$ \cancel{2 \dot x ^2 + \omega^2 x^2 = E} $$
Never Mind!
Either way this is great simplification from messing around with ##x = A \sin( \omega t + \phi )## ( I never would have thought of it)
Let’s just say it is not my first rodeo 😉
  • Haha
And I suspect the author intends this approach. Had the question been to find displacement / acceleration / velocity at a particular time the shortcut would not have been available.
Among somethings I picked up during years of teaching GR: If you can avoid the nitty gritty details of finding the explicit solution by using constants of motion, then you better do so.
How does ##\int (x''(t)+\omega^2x(t))dt## give us ##x'^2(t)+\omega^2x^2(t)##?
Not directly. It's a standard trick: multiply the equation by ##\dot x## first. Then all terms are integrable.
I'm not familiar with the trick @haruspex proposes, but I began by changing the independent variable in the derivative to ##x##, by application of the chain rule.
$$x''+\omega^2x=0\tag{1}$$
$$x'x''+\omega^2x'x=0\tag{2}$$
$$\frac{x'^2}{2}+\omega^2\frac{x^2}{2}=C_1\tag{3}$$
$$x'^2+\omega^2x^2=C\tag{4}$$
From (1), since ##x''(0)=-12##
$$-12+\omega^2\cdot 1=0\tag{5}$$
$$\omega^2=12\tag{6}$$
From (4), since ##x'(0)=x(0)=1##
$$1+\omega^2\cdot 1=C\tag{7}$$
$$C=1+\omega^2\tag{8}$$
Again from (4), since at some time ##t## we have ##x'(t)=\sqrt{8}## then
$$8+\omega^2x^2(t)=1+\omega^2\tag{9}$$
$$x^2(t)=\frac{-7+\omega^2}{\omega^2}=\frac{-7+12}{12}=\frac{5}{12}\tag{10}$$
$$x(t)=\sqrt{\frac{5}{12}}\tag{11}$$
Then from (1) again
$$x''(t)=-\omega^2x(t)=-12\sqrt{\frac{5}{12}}\tag{12}$$
Unfortunately, the solution manual has
$$x(t)=\frac{1}{3}\sqrt{6}\tag{13}$$
$$x''(t)=-12x(t)=-4\sqrt{6}\tag{14}$$
I redid the calculations using the sinusoidal expressions and solved them with Maple. They agree with the solution proposed here in this forum. The solution manual seems to be incorrect.
The general solution to this equation is
$$x(t)=c_1\cos{\omega t}+c_2\sin{\omega t}\tag{2}$$
$$x(0)=c_1=1\tag{3}$$
$$v(t)=-\omega \sin{\omega t}+c_2\omega\cos{\omega t}\tag{4}$$
$$v(0)=c_2\omega=1 \implies c_2=\frac{1}{\omega}\tag{5}$$
Thus,
$$v(t)=-\omega\sin{\omega t}+\cos{\omega t}\tag{6}$$
$$a(t)=-\omega^2\cos{\omega t}-\omega\sin{\omega t}\tag{7}$$
$$a(0)=-\omega^2=-12\implies \omega^2=12\implies \omega=2\sqrt{3}\tag{8}$$
Thus,
$$v(t)=-2\sqrt{3}\sin{2\sqrt{3}t}+\cos{2\sqrt{3} t}\tag{9}$$
and we want to find the time ##t## at which ##v(t)=\sqrt{8}=2\sqrt{2}##.
The times comes out to be ##-0.179##.
If we sub into ##x(t)## then we get ##0.645##, which is ##\sqrt{\frac{5}{12}}##.
If we sub into ##a(t)## then we get ##-7.74##, which is ##-12\sqrt{\frac{5}{12}}##.
Your (11) is missing one solution, but otherwise ok.
Yes, the two methods are effectively the same:
##\ddot x+\omega^2 x=0##
##2\ddot x\dot x+2\omega^2 x\dot x=0##
Integrating wrt t:
##\dot x^2+\omega^2x^2=constant##
Or using ##\ddot x= \frac{d\dot x}{dt}=\frac{d\dot x}{dx}\frac{dx}{dt}=v'v##
##v'v+\omega^2 x=0##
Integrating wrt x:
##v^2+\omega^2 x^2=constant##
Just to illustrate for future use…
##A\sin(\theta)+B\cos(\theta)=C##
1.
##A\sin(\theta)=C-B\cos(\theta)##
##A^2\sin^2(\theta)=(C-B\cos(\theta))^2=A^2(1-\cos^2(\theta))##
a quadratic in cos theta
2.
Define ##\phi## by ##\cos(\phi)=\frac A{A^2+B^2}## etc:
##\cos(\phi)\sin(\theta)+\sin(\phi)\cos(\theta)=\frac C{A^2+B^2}=\sin(\theta+\phi)##
