Position of particles on a detector after decay
The discussion revolves around the decay of a hypertriton, which is produced at the origin and decays into a pion and helium-3. The participants are tasked with simulating the positions of the decay products on a detector located at a specific distance along the x-axis, while considering relativistic effects and angular distributions of the decay products.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss generating random angles for the decay products and question the validity of this approach in the context of the center of mass system. There is mention of needing to consider angular distributions and transformations to the detector system. Some participants explore the implications of the hypertriton's lifetime on the decay position and the calculations involved in determining the y-hit positions on the detector.
The discussion is active with participants seeking clarification on the relationship between decay angles, positions, and the effects of relativistic transformations. Some guidance has been offered regarding the need for Lorentz transformations and the importance of angular distributions in the calculations. Multiple interpretations of the problem setup are being explored.
Participants are navigating between different scenarios regarding the hypertriton's lifetime and its implications for the decay process. There is a mix of assumptions about the decay occurring at the origin versus considering the travel time before decay, which adds complexity to the problem. The original poster expresses uncertainty about the simplicity of their approach and the need for further understanding of the underlying physics.
Cocoleia
A hypertriton (a bound system with a L hyperon together with a deuteron core (proton
and neutron) is produced at the origin of the coordinate, (x,y)=(0,0) with a velocity of 0.94c
(beta=0.94), flying along the x-axis. The mass of the hypertriton is 2.991 GeV/c2
. It decays into pi (mp- = 0.14 GeV/c2) and 3He (m3He = 2.809 GeV/c2). The hypertriton immediately decays at the origin. Now you have a detector at x=0.4. Create y-hit distributions of p- and 3He with
10000 hypertriton decay events.
I am writing a code to do this, but I am having trouble understanding.
I will be randomly generating angles (only forwards) for my particles in this code.
I am thinking, if I know the angle of the particle and the distance in x that it travels (0.4m) then can I just use a simple sin (basic geometry) to find the position in why
so y = sin(theta) * (0.4)
I feel like this is way too simple so I am missing something crucial in the question
In the center of mass system of the hyperthing, the decay products will fly off in back to back directions, so you can't just 'generate random angles' for your particles. You have to assume an angular distribution in the c.o.m. system and then transfom to the detector system.
Okay, and once I do this, I will have angles that I will be able to use? Is my logic for just doing sin(theta)*x correct? Or there will be some more lorentz transformation type things involved ?
Yes, transform means Lorentz transform. Transverse momentum is only from the decay, longitudinal from c.o.m. motion + decay.
So I will need to use something like
But if the decay happens at the origin, then it is not traveling in the moving frame and therefore this would not be applicable?
Let's say in my second example it travels 180 picoseconds before decaying. Then I would find x' by this formula and use that to find the distance with the sin(theta)?
http://www.helsinki.fi/~www_sefo/phenomenology/Schlippe_relativistic_kinematics.pdf
I have been reading a few things, let's say https://hepweb.ucsd.edu/ph110b/110b_notes/node43.html
So if the lifetime is 0, then it doesn't make much of a difference for the reference frames right ?
I have already derived all equations for momentum and energy, I'm confused how to consider the position
Let's say I take my second example, where the hypertriton lives for 180 picoseconds before decaying into the pion and helium. Obviously, it will not decay at the origin anymore since it travels somewhere during that lifetime
This is what I did. Does it make sense? Now I know it decays at x=4.96x10^-10 and can use that for my calculations (with the angles, etc)
So it would travel 0.3999999995m in the x direction, at whatever angle theta (suppose it is known) AND i could do tan(theta) * x = y to find which point it hits on the detector
What do you mean: "if" ? The problem statement says so (to make it easier for you)
You don't need the position. You need angles.
Re lifetime: I get ##\gamma = ## 2.9 too. So in the lab it lives 2.9 * 180 ps ##\approx## 0.5 ns. That is 15 cm. Looks to me as if you mix up frames of reference or something. Aha:
What's this calculation ? Your calculation to get 5e-10 misses by a factor of ##c## !
How do you get 0.4 m ? (not 0.3999999995 !) Aha: subtract 5e-10 (from 0.4 ##\pm ## ?? :rolleyes: ) -- I was under the impression 'it' is the hyperthing, not the decay products.
(and your ##\gamma## looks uncomfortably similar to a ##\sqrt{}## :nb) )
So not 0.5 nm but 15 cm (with a Poisson distribution! It is a decay process!), and in the x direction (before decay it does not deflect).
However, to make it easier for you they set the lifetime to 0 and thereby the decay at (0,0). At least that's how I read the problem statement, but you may have better information... (is this really an exercise, intro physics homework ? )
Now generate an angular distribution for the momenta in the com and transform them to the lab.
Study the link in #6; it's a lot better than the ucsd one :wink:
Re lifetime: I get ##\gamma = ## 2.9 too. So in the lab it lives 2.9 * 180 ps ##\approx## 0.5 ns. That is 15 cm. Looks to me as if you mix up frames of reference or something. Aha:What's this calculation ? Your calculation to get 5e-10 misses by a factor of ##c## !
Yes, I have everything mixed up.
I have one first problem where the lifetime is 0 and another where it is 180. I was just comparing them to see if I understood the general concept.
I mean, I am at the level of introduction to physics but that's potentially not the work I'm given. It's not homework though, it won't be graded. It's actual work :wink:
I will work on this and read the other document more thoroughly and check back :confused:
Just out of curiosity, once I have the lab frame momentum how do I convert this to the position on the detector (how do i find where they will hit)
Is this what you mean by angular distribution of momentum
with (0) being in the rest frame
When you say you are "writing a code", what do you mean? The problem looks like a fairly standard one involving the calculation of a probability density function under a transformation (that is, a change of variables). A closed-form analytical solution looks perfectly feasible, but only if you have taken some material about probability densities and the like. If that material is totally new to you I could see the virtue of something like a Monte-Carlo simulation, to obtain an "experimental" y-distribution.
Yes, it's just a first exercise to introduce me to the material and the software. eventually it will be a monte carlo simulation... right now I'm just trying to understand the problem and do some basic C++ coding.
The thing is I'm very new to this and I don't understand what relationship i am supposed to find between the angle, momentum and the position where my particle will hit on the detector. Will it involve angular momentum ?
No. Stick to the simple kinematics of transforming linear momentum.
I sympathize with the newcomer stress - brings back memories. There's so much everybody - except you - seems to know but is unable to explain in a helpful manner.
Yes I see this...
So I have derived / found the equations for momentum of two body decay:
Then in the lab frame
Now, I also see that
I just don't now how to piece this together to get the height at which the particle hits the detector. Somehow use this last formula, tan(theta') * 0.4 will give me the answer I am looking for ?
Based on this principle
Looks good to me !
(note the striking similarity with Exercise 1 in the helsinki link :wink: ).
Must say: a little googling nowadays brings to the rescue a huge load of resources ! :cool:
(in the early days of bitnet and earn we would go to the library or try to make a senior colleague explain things a little -- something I would still advise now: very effective and efficient, especially if you butter them up a bit).
BvU said:
Looks good to me !
Thanks for your help. I would love to ask my colleagues for help but everyone is gone this ... just me and my physics. So I turn to Physics Forums o0)
Wait, how did you find 15cm ?
Look at your own diagram in post #18. For any angle ##\theta_1## in the CM frame, particle 1 will either strike the detector or it won't. Clearly, if ##-\pi/2 < \theta_1 < \pi/2## (that is, particle 1 moves at least slightly to the right in the CM frame), the detector at ##x > 0## will be struck. Some particles with ##\theta_1 > \pi/2## or ##\theta_1 < - \pi/2## will also strike the detector; these are the particles that are not moving too fast to the left in the CM frame.
Anyway, for any given value of ##\theta## from ##-\pi## to ##+\pi## you can use formulas to figure out if particle 1 hits the detectort, and if it does, the location of the hit.. You can use a random number generator to generate a large sample of CM_frame angles (uniformly distributed over the circle) to get a large sample of lab-frame striking locations. Then you can make a frequency histogram of the striking positions, to obtain an "experimental" distribution of striking locations. If you generate, say, 100,000 angles at random you should get a pretty good representation of the actual theoretical location distribution. You can do all that without really knowing any fancy probability concepts and methods; it is just a matter of writing a not-too-complex computer program, or maybe using some type of on-line simulation package.
Cocoleia said:
Yes I see this...
Things simplify a bit if you look at velocities instead of momenta. For a particle-1 velocity ##(U \cos \theta_1, U \sin \theta_1)## in the CM frame, you can use the Lorentzian velocity-transformation equations to get the particle-1 velocity in the lab frame, say ##(u_x, u_y)##---with components depending on ##\theta_1.## For some range of ##\theta_1## you will have ##u_x > 0##, and in that case the particle will, eventually, hit the detector, and does so at time ##T = x/u_x##. The y-location of the hit is ##y = u_y T = (u_y/u_x) x,## which will be some complicated (but easily-computed) function of ##\theta_1##. There is not much point in working out a formula for the lab-frame angle ##\theta'_1## because you will not really need to use it in a simulation.
  • · Replies 22 ·
