Potential difference between two large plate changing with time
The discussion centers on calculating the velocity of an electron moving between two large parallel plates with a time-varying potential difference defined by V=at, where 'a' is a positive constant. The user initially derived the velocity as v=(eaL/2m)^(1/3) but found a discrepancy with the expected answer of v=(9eaL/2m)^(1/3). The confusion arose from the integration of acceleration, which was unnecessary since the velocity could be directly obtained from the relationship x = ∫v dt. The final correction involved recognizing the proper placement of the constant '9' in the equation.
  • Understanding of classical mechanics, specifically kinematics.
  • Familiarity with the concepts of electric potential and electric fields.
  • Knowledge of calculus, particularly integration techniques.
  • Basic understanding of particle physics, including properties of electrons.
  • Study the derivation of motion equations under varying acceleration.
  • Learn about electric fields and forces acting on charged particles.
  • Explore advanced integration techniques in calculus.
  • Investigate the behavior of charged particles in electric fields in more complex scenarios.
Students and professionals in physics, particularly those focusing on electromagnetism and particle dynamics, as well as educators looking to clarify concepts related to motion in electric fields.
AGNuke
The potential difference between two large parallel plates is varied as V=at; a is a positive constant and t is time. An electron starts from rest at t=0 from the plate which is at lower potential. If the distance between the plates is L, mass of electron m and charge on electron -e then find the velocity of the electron when it reaches the other plate.
I attempted the question by equating the relation between time & velocity and time & distance.
A=\frac{Vq}{x}=\frac{eat}{mL}
\int_{0}^{v}dv=\int_{0}^{t}{Adt} \Rightarrow v=\frac{eat^{2}}{2mL}
\int_{0}^{L}dx=\int_{0}^{t}vdt+\int_{0}^{t}atdt \Rightarrow L=\frac{ea}{2mL}\int_{0}^{t}t^{2}dt+\frac{ea}{mL}\int_{0}^{t}t^{2}dt=\frac{eat^3}{2mL}
Now dividing the cube of first equation with square of second equation, to eliminate the time, I got v=\left ( \frac{eaL}{2m} \right )^{1/3}
Now my problem is that the answer stated is v=\left ( \frac{9eaL}{2m} \right )^{1/3}
Any problems as for what I have done? :confused:
Hi AGNuke! :smile:
I don't understand why you're integrating adt …
why not just use x = ∫vdt ? :confused:
Oops... my fault. I thought that since acceleration is also changing, I better write it too, but I forgot that I already made it up for it when writing v.
Thanks tim, I got my 9 in the place.
