Potential Difference between two positive point charges
14 replies · 11K views · last reply
flannabhra
Two equal positive charges Q are fixed on the x-axis, one at +a and the other at -a.
(a) The electric field E at the Origin O
(b) The electric potential V at the origin O
E=-dV/dr --> V=kQ/r
VNet = V0 + V1
I got V0 = -kQ/r (because the vector r is negative)
..and V1 = kQ/r
V = 0
Is this correct?
Thank you for your help!
E=-dV/dr --> V=kQ/r
VNet = V0 + V1
..and V1 = kQ/r
V = 0
Is this correct?
No, the potential of a charge q located at x=a is kq/|x-a|, notice the absolute value.
Hi Flannabhra!
Let's answer a few questions:
a.) What kind of quantity is the electric potential, V?
b.) Describe to me the significance of 'r'.
E=-dV/dr --> V=kQ/r
VNet = V0 + V1
..and V1 = kQ/r
V = 0
Is this correct?
That's not correct.
First of all, what was your answer for part (a) and how did you get it.
For you attempt at part (b):
What does the variable, r, represent?
The operation of division is not defined for a vector --- that is to say, division by a vector is not defined.
Electric potential is a scalar quantity.​
SammyS said:
That's not correct.
First of all, what was your answer for part (a) and how did you get it.For you attempt at part (b):
I got E = 0 for part (a) but i now feel that it is wrong based on your responses. The variable r represents the distance from the point charge to the Origin.
That is the correct answer for part (a), but do you know why it is?
Distance is a non-negative quantity, as pointed out by Dick. So r can't change the sign of the potential.
Well a logical explanation sufficed for me(the Electric Fields would be of equal magnitude in opposite directions), but I would like to understand the explanation of it based on formulas.
On the matter of r, I was under the impression that you could take the direction that r is pointing from the reference point and use that as the direction for r. I.e. the equation for E would be:
E = kQ/r3 * r
- in which r is the vector r and the r in the denominator is raised to the third power so as to keep the equation true.
E = kQ/r3 * r
Yes. That answers the question regarding part (a) very nicely.
I don't understand this.. What is x in this situation if r is the distance from the point Q to the origin?
JC Palmer said:
Hi Flannabhra!
Hi!
a) I believe that in this situation, V is scalar.
b) 'r' is the distance from the point Q to the origin
For the charge at x = -a, r = ai , where i is the unit vector in the positive x direction.
For the charge at x = a, r = -ai .
In each case the distance is a, and the vector, r, points away from the charge.
So since the Electric Potential is scalar, is V = 2kQ/a correct?
Thank you so much for your help SammyS!
That's correct.
amirgul2007 said:
My qs is what is the potential difference between two similar charges?
You'll need to be more precise. The potential at a point charge is theoretically infinite (+ or -), point charges being purely theoretical things.
