Potential dividers and the formula Vout = Vin * R2/(R1+R2)
  • Context: High School
  • Thread starter Thread starter John421
    Formula Potential
The discussion revolves around the application of the voltage divider formula Vout = Vin * R2/(R1+R2) in circuit analysis, particularly in the context of connecting loads with varying resistances to the output voltage (Vout). Participants explore the implications of load resistance on the calculated output voltage and the conditions under which the formula remains valid.
  • Some participants assert that the formula is intended to calculate the voltage received by a load connected to Vout, but question its applicability when the load has significant resistance.
  • Others propose that when a load resistance (R3) is connected, it should be considered in the calculations by using the parallel resistance formula R2||R3.
  • A participant suggests that the formula yields accurate results primarily when R3 is much larger than R1, indicating a specific condition for its validity.
  • Concerns are raised about the impact of the load resistance on the output voltage, with some participants suggesting that the formula provides only an approximation under certain conditions.
  • There is a discussion about the significance of the source resistance of Vin and its effect on the overall circuit analysis.
  • Some participants question the clarity of the original post, seeking to understand whether the discussion is focused on circuit analysis or the design of a regulated voltage supply.
Participants express differing views on the applicability of the voltage divider formula in practical scenarios, particularly regarding the influence of load resistance. There is no consensus on the conditions under which the formula is valid, and multiple competing perspectives remain throughout the discussion.
Participants highlight the importance of considering load resistance and source resistance in calculations, indicating that assumptions about these values can significantly affect the outcomes. The discussion also touches on the limitations of the formula when applied to varying load conditions.
John421
I believe that the formula Vout = Vin * R2/(R1+R2) is used to calculate how much voltage whatever is connected to Vout will be receiving.
So if:
  • Vin = 12V
  • R1 = 10 ohms
  • R2 = 5 ohms
Then Vout should be getting 4 volts
But if we then connect an appliance with a resistance of 2 ohms to Vout
  • The circuit's overall resistance becomes 11.43 ohms
  • R1 receives 1.05A and so reduces the voltage by 1.05A * 10 ohms = 10.5 volts
  • Vout and R2 only get 1.5 volts
So what's the point of the Vout formula? I imagine that anything you connect to Vout will have a resistance, resulting in Vout not getting whatever you calculated using the formula.
Sometimes Vout is indeed connected to something that has a very high resistance (for example an Operational Amplifier, the gate of a FET or a capacitor).
If that's not the case then you have to take the load resistance into account...
So if:
  • Vin = 12V
  • R1 = 10 ohms
  • R2 = 5 ohms
Lets call the 2 Ohm resistor R3. Then you can replace R2 in the equation with R2||R3 ...
Vout = Vin * R2||R3 / (R1 + R2//R3)
R2||R3 = 1.43 Ohms
So
Vout = 12 * 1.43 / (10 + 1.43)
= 1.5V
The equation also assumes that the source resistance of Vin is small. If not then you have to add it to R1.
PS: You might like to think about the range of values for which the resistance at Vout can be ignored. For example work out the effect on Vout if it was 20 Ohms, 200 Ohms or 2KOhms.
PPS: What is the resistance of the meter used to measure the voltage at Vout? Could that effect the measured voltage? What if R1 and R1 were 1M Ohm?
I've played around with different combinations of numbers, and the formula only seems to get close if R3 (the component at Vout) has a resistance that is much higher than that of R1. It doesn't seem to matter if R2 is high or low as long as R3>>>R1
So would it be correct to say that R1 is always a low resistance resistor, R2 is usually variable, and Vout (R3) always has a much higher resistance than R1, and in this situation you would use this formula? And that this formula just supplies a 'good enough' estimation?
So if:
  • Vin = 12V
  • R1 = 10 ohms
  • R2 = 5 ohms
R2 represents anything you put between the Vout terminals. The formula allows you to calculate the effect of R2 with whatever Voltage is applied and whatever value is selected for R1.
The issue is that if R2 represents anything you put in the Vout terminals, the above diagram wouldn't make any sense
What matters is the relationship between R3 and R2 (rather than R3 and R1). R3 won't matter if R3 >> R2. That applies any time you have two resistors in parallel.
If R3 isn't >> R2 then replace R2 in the equation with R2||R3.
Works for the LDR as well.
Q
I don't get the point of your original post. Are your trying to understand circuit analysis formulas, or are you trying to design a regulated voltage supply?
anorlunda said:
QI don't get the point of your original post. Are your trying to understand circuit analysis formulas, or are you trying to design a regulated voltage supply?
Yes. We can say that the formula is correct (as long as the load resistance is included in the value for the 'bottom' resistor). Anything else is just a matter of detail and what you actually want the circuit to do.
John421 said:
How is this?
  • · Replies 18 ·
  • · Replies 16 ·
