Potential Energy/ dipole moment curves
The discussion revolves around the creation and interpretation of potential energy curves and dipole moment curves in the context of molecular physics and chemistry. Participants explore the theoretical and experimental aspects of these concepts, including the relationship between potential energy and dipole moments, as well as the extraction of molecular properties from these curves.
  • One participant inquires about the core ingredients needed to create a potential energy curve, suggesting that quantum chemistry and the time-independent Schrödinger equation are involved.
  • Another participant states that potential energy curves and dipole moment curves are not directly related, but acknowledges that dipole moments can be extracted from quantum chemistry calculations.
  • There is a discussion about the Born-Oppenheimer approximation, with one participant questioning whether the Schrödinger equation should be solved for electrons and nuclei separately.
  • Participants discuss the extraction of rotation-vibration wave functions and energies from the potential energy curve, indicating a method to solve for molecular motion.
  • One participant expresses the goal of creating a molecular line list, highlighting the challenge of producing theoretical calculations that can be compared to experimental spectra.
Participants express differing views on the relationship between potential energy curves and dipole moment curves, with no consensus reached on the best approach to solving the Schrödinger equation in this context. The discussion remains unresolved regarding the specifics of extracting molecular properties and the implications of the Born-Oppenheimer approximation.
Limitations include potential assumptions about the applicability of the Born-Oppenheimer approximation and the complexity of relating theoretical calculations to experimental results, which are not fully addressed in the discussion.
jl29488
Hi,
I wasn't sure if this is more Physics/Astro or chemistry because its actually all 3.
i've got some conceptual issues with some tasks at hands, and was wondering if anyone could clear that up for me.
(These questions are all regarding molecules)
1) How do you create a potential energy curve? What are the core ingredients? (quantum numbers etc..?)
2) How does a potential energy curve relate to a Dipole moment curve.
3) What can you extract from these curves?
Thanks so much!
Chemistry news on Phys.org
Theoretically, you need to do some quantum chemistry, basically solving the many-body problem (nuclei + electrons) using the time-independent Schrödinger equation. By varying the distance between the atoms, you get the variation of the energy as a function of that distance, resulting in the potential energy curve. Experimentally, you need some fitting procedure, where manipulate a potential energy curve until it produces the correct set of observed levels.
It doesn't. You can extract the dipole moment from the same quantum chemistry calculations. I'm not sure how you get the dipole moment from experiments, but I guess it is related to line strength.
A lot of what you want to know about the properties of the molecule.
Thanks for the reply.
Would I not solve the Schrödinger equation for the electrons and nuclei separately (Born oppenheimer approx) ?
Also, how can I extract the rotation-vibration wave functions and energies for solving for the motion of the nuclei/electrons?
Sorry if this my questions don't sound particularly ordered. I am just trying to create a mind map of how its all interlinked.
The eventual goal is to create a Molecular line list.
The nuclei are still there, just not moving! I didn't mention the BO approx explicitly, but it is what I was referring to in saying "varying the distance between the atoms."
Once you have the potential energy curve, you can solve the Schrödinger equation for the motion of the nuclei, and get ro-vibrational states.
Do you mean you want to theoretically calculate a series of lines, in order the be able to identify actual spectra? If that is the case, good luck! Producing work good enough to compare to experimental values is not a trivial task.
16K
  • · Replies 25 ·
  • · Replies 28 ·
