Potential Energy of a System of charged particles
The discussion focuses on calculating the potential energy (PE) of a system of charged particles using the equations V = kQ/r and PE = Vq. The user is struggling with the correct application of these formulas, particularly in determining the voltage (V) at specific locations and how to account for both attraction and repulsion forces affecting potential energy. It is clarified that voltage is a scalar quantity and that the total voltage from multiple charges can be found by summing the individual voltages. The user gains clarity on visualizing the system, especially regarding the total potential energy when considering the movement of charges. Understanding these principles is crucial for accurately solving the problem.
sniper_spike
V = kQ/r
PE = Vq
Tried a lot of ways... get an order of magnitude less than the answer and also off by a bit too.
Please help. I think you are supposed to take V at each location then multiply by q since this is PE. I carry everything in vector form but my numbers are confusing. Attraction is supposed to be negative PE. Well we have attraction/ repulsion both working on a particle. It gets attracted and repelled to a certain direction. Is this contributing negative or positive potential energy?
I've had a lot of partial insights but no complete solution. Thanks
sniper_spike said:
V = kQ/r
PE = Vq
V due to what? Multiply by which q ?
What do you get for V at the location of Q1, for example?
V at Q1 should be..
k5.3e-6 *(-1.5i - 1.5j) ```` k3.7e-6 *(1.5i - 3j)
1.5^2 + 1.5^2 `````````` 1.5^2 + 3^2
= -15900i - 15900j + 4440i - 8880j
= -11460i -24780j
= 27301r N*m/C
I mean q at that location.
So |PE| would be qV = 27301* 2.8e-6 = 0.0764 J
sniper_spike said:
V at Q1 should be..
Voltage is a scalar.
Then how do i figure out the total voltage from two different particles?
I can only think of taking a scalar value between one charge and the point Q1,
and doing a scalar addition of that voltage with the voltage between the other and point Q2. Do i simply do this for all the particles to get a scalar total?
The voltage at one charge due to the other two is simply the sum of the voltages due to each of those two. But be careful re the total PE of a system with more than two charges. I would suggest imagining one charge moving away to infinity, then the other.
your visualization seems to be the case. Thank you so much. Quite clear now.
