Potential Energy of a Charged Particle in a Uniform Electric Field
The discussion centers on calculating the change in potential energy of a +13.0 µC charge moving in a uniform electric field of 270 V/m directed along the positive x-axis. The charge moves from the origin to the point (20.0 cm, 50.0 cm). The change in potential energy is calculated using the formula -q∆V, resulting in -1.755 mJ, while the potential difference experienced by the charge is determined to be 135 V. The key takeaway is that potential energy is influenced solely by the displacement in the direction of the electric field, which is the x-direction in this case.
  • Understanding of electric fields and their properties
  • Knowledge of electric potential energy calculations
  • Familiarity with the concept of charge and its units (Coulombs)
  • Basic understanding of vector components in physics
  • Study the concept of electric potential energy in uniform electric fields
  • Learn how to calculate work done by electric fields on charged particles
  • Explore the relationship between electric field strength and potential difference
  • Investigate the effects of charge movement in non-uniform electric fields
Physics students, electrical engineers, and anyone interested in understanding the dynamics of charged particles in electric fields will benefit from this discussion.
brunie
A uniform electric field of magnitude 270 V/m is directed in the positive x direction. A +13.0 µC charge moves from the origin to the point (x, y) = (20.0 cm, 50.0 cm).
(a) What is the change in the potential energy of the charge field system?
____ J
(b) Through what potential difference does the charge move?
____ V
ok so
270 V/m ---->
13 x 10^-6 C
origin to (0.2m, 0.5m)
i don't know if any of this is right, just my attempt
distance from origin to point is sqrt(0.2^2 + 0.5^2)
= 0.5385 m
since the field is in the positive x direction, does this mean that the potential is only due to the y direction (since field wants charge to go right n e ways)?
change in the potential energy is the work done between so
= - q ∆V
= - (13*10^-6) (270*0.5 - 270*0)
= - (13*10^-6) (135)
then the potential difference would be the potential energy divided by the charge, so just 135 V
any help is appreciated
hmmmmmmmmmmmm
It seems your problem is your understanding of potential energy. How would you define the electrical potential energy at some point given the fact that you know that the electric field is uniform in one direction?
Wrong. Charges always want to move with the field. Potential is dependent only upon the change in x-value, NOT y.
  • · Replies 22 ·
