Potential Gravitational Energy into Force
The discussion revolves around the relationship between gravitational potential energy and gravitational force, exploring how to derive the equation for gravitational force from potential energy equations. Participants also delve into the distinctions between potential and potential energy, as well as their implications in both gravitational and electric contexts.
  • One participant questions how to derive gravitational force from the equation for potential gravitational energy, suggesting that taking the derivative might be the solution but expressing uncertainty about the reasoning behind it.
  • Another participant states that gravity is a conservative force, implying that the force is defined as the gradient of a potential, but does not elaborate on the implications of this definition.
  • There is a discussion about whether the relationship between force and potential applies to electric potential as well, with some participants affirming that it holds true for static cases.
  • A participant explains that any conservative force can be associated with a potential energy function, referencing the work-energy theorem and the fundamental theorem of calculus to derive the relationship between force and potential energy.
  • Some participants clarify the difference between potential and potential energy, noting that potential energy is a form of energy while potential is often expressed as energy per unit mass or charge.
  • One participant expresses confusion about the approximation of potential energy formulas, questioning the representativeness of formulas in relation to true values.
  • Another participant provides an example of lifting an object to explain the relationship between work, potential energy, and potential, while also discussing the gravitational field strength and its relation to potential.
  • A suggestion is made to explore hydro power calculations for practical understanding of potential energy.
Participants express varying levels of understanding regarding the concepts of potential and potential energy, with some agreeing on their definitions while others remain confused. The discussion does not reach a consensus on the clarity of these concepts or the implications of approximations in potential energy formulas.
Some participants highlight the importance of precise language to avoid conflating potential and potential energy, indicating that misunderstandings may arise from imprecise terminology. There is also mention of the limitations of certain formulas in specific contexts, such as static versus dynamic systems.
This discussion may be useful for students and individuals interested in understanding the foundational concepts of gravitational and electric forces, potential energy, and their mathematical relationships, particularly those transitioning from a focus on forces to energy-based perspectives in physics.
AlexVGheo
How do you derive the equation for gravitational force from the eqauation for potential gravitational energy: e=-Gm/x? For me it seems as though you take the derivative and that would work, but i don't understand why it does?
Welcome to PF;
Gravity is a conservative force - which is why the force is the gradient of a potential.
Its a definition.
Aha, is that also true for electric potential then?
For static cases, yes.
It is true for any conservative force. If you accept the rather intuitive definition that a conservative force is one whose associated work function is path independent, then you can construct a well defined potential energy function for a conservative force using the work-energy theorem: ##W = -\Delta U = U(a) - U(x) = \int _{a}^{x}F(x')dx'##. Now differentiate both sides and apply the fundamental theorem of calculus to obtain ##F(x) = -\frac{\mathrm{d} U}{\mathrm{d} x}##. This can be trivially generalized to higher dimensions.
As such, you can always define an electric potential energy for electrostatic forces (it won't work for electrodynamic systems because the path independence will fail). There is, however, a way to get around this that you will learn about at some point or another in your physics education.
... and you have your answer for the most likely interpretation :)
But your question is not really clear: is what also true? - are you asking if the static electric force on a charge is proportional to the gradient of the electric potential, if this is a definition for electric potential, or something else? There are quite a few ways that question finishes from the context.
I didn't pick it up before but post #1 says "potential energy" but the equation given is for potential - these are different, though related, concepts.
A lot of confusion can stem from just not being careful enough to say what you mean - it risks accidentally conflating mismatched ideas.
Ok, so what is the difference between potential and potential energy? and what is the difference between pe =mgh and pe=-GMm/r?
also, potential energy is a form of energy. potential is not, but is often related. for example, gravitational potential is like an energy per mass. and analogously, in electromagnetism, the electric potential is like an energy per charge.
Thank you for the ilink, it was somewhat enlightening I think I understand the relationship between the forces and potential energy a bit better now =) but i still don't understand the difference beween potential and potential energy? For example if I lift up an object of mass m to a height h then the potential energy is E = mgh so what is the potential?
And I don't understand the approximation, isn't it the job of a formula to be representative of the true value?
Also i am finding this all very interesting, unfortunately I am used to dealing in forces and so I don't know much about energy, is there a book you know of which can explain how to use energy instead of force?
The potential energy is the work needed to get a mass to that height ... thus W=Fd=mgh.
The potential is the work per unit mass, so that would be W/m = gh
The strength of the gravitational field at a position is the acceleration due to gravity at that position - which is the negative gradient of the potential ... which is just -g.
The force is the negative gradient of the potential energy ... F=-mg.
... and this is equal to the rate of change of momentum.
It can take a while to get used to dealing with energy ... pretty much any physics textbook should have something on it under "conservation of energy".
Alex for some practical understanding of potential energy look up calculations of Hydro Power.
  • · Replies 46 ·
  • · Replies 29 ·
  • · Replies 27 ·
12K
  • · Replies 21 ·
  • · Replies 54 ·
