Potential in case of concentric shells
- Thread starter gracy
- Start date
- Tags
- Potential
82 replies · 18K views
- 10,557
I think the confusion stems from your reading of this para in post #17:gracy said:But that's we did .We did not involve these induced charges in calculation of final potential.
So, if you pick any point inside sphere B at a distance x from the center, at that point, the potential will be kq/2a. Out of that potential, kq/x will be contributed by +q on sphere A and the rest will be contributed by the induced charges on sphere B.
What cnh is saying there is that you can predict by other means what the net potential will be in the annulus, and know that the induced charges will be such as to achieve that. We do not ignore the induced charges, but we do not need to know what they are in order to find the potential.
gracy
- 2,486
- 83
Now what if question asks find the potential of shell B due to induced charges?will we able to calculate it?
- 42,960
- 10,557
Yes. We know what the potential would be without induced charges, and we know what the net potential is with the induced charges. The difference is due to the induced charges.gracy said:Now what if question asks find the potential of shell B due to induced charges?will we able to calculate it?
gracy
- 2,486
- 83
I thought we only know/calculated net potential of shell B i.e with the induced charge which is equal to ##\frac{Kq}{6a}##haruspex said:Yes. We know what the potential would be without induced charges, and we know what the net potential is with the induced charges. The difference is due to the induced charges.
- 42,960
- 10,557
That's what we have calculated, but we could also calculate the potential at B if there were no shell C.gracy said:I thought we only know/calculated net potential of shell B i.e with the induced charge which is equal to ##\frac{Kq}{6a}##
gracy
- 2,486
- 83
You mean to know /calculate what the potential would be without induced charges we will have to ignore shell C but why?
gracy
- 2,486
- 83
To follow what haruspex said in #34 we should know what the potential of B would be without induced charges.I am confused about how to calculate that.I mean that's what we did while calculating net potential of shell B because we did not involve induced charges in calculation of net potential of shell B.So we will get same result for potential of B without induced charges.And henece potential of shell B due to induced charges will come out to be zero
Staff Emeritus
Homework Helper
- 11,986
- 1,583
I'm not clear as to exactly what you are intending to say here.gracy said:To follow what haruspex said in #34 we should know what the potential of B would be without induced charges.I am confused about how to calculate that.I mean that's what we did while calculating net potential of shell B because we did not involve induced charges in calculation of net potential of shell B.So we will get same result for potential of B without induced charges.And hence potential of shell B due to induced charges will come out to be zero
The potential (due to all charges) at a point on the surface of shell B is ##\displaystyle \ k\,\frac{q}{6a} \ ##.
The potential (due only to the charge on shell A) at a point on the surface of shell B is ##\displaystyle \ k\,\frac{q}{2a} \ ##.
The potential (due to all the induced charges) at a point on the surface of shell B is ##\displaystyle \ -k\,\frac{q}{3a} \ ##.
gracy
- 2,486
- 83
why did you not involve charge -q which has been provided by Earth to shell C?
- 42,960
- 10,557
That was the third item, "potential due to all induced charges". The induced charges on shell B cancel each other.gracy said:why did you not involve charge -q which has been provided by Earth to shell C?
Staff Emeritus
Homework Helper
- 11,986
- 1,583
I did.gracy said:why did you not involve charge -q which has been provided by Earth to shell C?
That charge is at a distance of ##\ 3a\ ## from the origin. It produces no electric field at distances closer to the origin than ##\ 3a\,,\ ## and therefore the potential due to the that induced charge (-q on shell C), is constant at points closer to the origin than shell C.
Any effect from the induced charges closer to the origin than that (those on shell B) cancel each other out.
gracy
- 2,486
- 83
Then what is that constant potential?SammyS said:and therefore the potential due to the that induced charge (-q on shell C), is constant at points closer to the origin than shell C.
Staff Emeritus
Homework Helper
- 11,986
- 1,583
I don't know why I didn't ask you first, but you should know that or know how to find that.gracy said:Then what is that constant potential?
1.) What is the potential due to the charge -q at a distance ##\ 4a \ ## from the origin ( Common center) ?
2.) What is the potential due to the charge -q at a distance ##\ 3a \ ## from the origin ( Common center) ?
gracy
- 2,486
- 83
Assuming charge q on shell C or you are asking in general?SammyS said:What is the potential due to the charge -q
Staff Emeritus
Homework Helper
- 11,986
- 1,583
Maybe the wording is confusing?SammyS said:I don't know why I didn't ask you first, but you should know that or know how to find that.
1.) What is the potential at a distance ##\ 4a \ ## from the origin due to the charge -q ?
2.) What is the potential at a distance ##\ 3a \ ## from the origin due to the charge -q ?
(The charge -q resides on shell C in both cases.)
Homework Helper
- 15,536
- 1,917
Gracy, you should remember:
If charge Q is distributed uniformly on a spherical surface of radius R, its field and potential outside the sphere is the same as if the charge were concentrated in the center. Inside the sphere, the electric field is zero and the potential is constant.
The sphere in question is C now, the charge is -q and the radius is 3a. Outside the sphere, r≥3a, the potential due to this charge is k(-q)/r . On the sphere, it is k(-q)/(3a). If r<3a, the potential is constant. The potential is a continuous function, so it is k(-q)/(3a) everywhere inside the sphere, even on B, at r=2a.
gracy
- 2,486
- 83
No ,I thought it is charge supplied by Earth to shell C.SammyS said:A charge of -q on shell C. That's the induced charge, right?
Staff Emeritus
Homework Helper
- 11,986
- 1,583
Yes, it's supplied by "earth", but it is also induced by the other charges.gracy said:No ,I thought it is charge supplied by Earth to shell C.
Alternatively: The −q charge is indeed induced, whether the shell, C, is grounded (Earthed) or not. The grounding simply allows the +q charge, which would be on the outside surface of shell C to "escape".
Added in Edit:
Gracy,
EHild also responded to this, almost simultaneously (I guess she then deleted her reply). It's late here, so I will go off to bed now. You will be in very good hands with her.
gracy
- 2,486
- 83
induced charge -q is on inner surface of shell C.And charge -q which has been supplied by Earth is on outer surface of shell C to balance induced +q charge there ,Am I right?SammyS said:Yes, it's supplied by "earth", but it is also induced by the other charges.
Homework Helper
- 15,536
- 1,917
Well, this means that zero charge is on the outer surface of C, and -q induced charge on the inner surface. So that -q is induced charge.gracy said:induced charge -q is on inner surface of shell C.And charge -q which has been supplied by Earth is on outer surface of shell C to balance induced +q charge there ,Am I right?
In case of zero charge you can say that it is the resultant of one million C positive charge and one million C negative charge, but it has no sense at all.
gracy
- 2,486
- 83
Yes,Am I right in post#52?ehild said:Well, this means that zero charge is on the outer surface of C, and -q induced charge on the inner surface. So that -q is induced charge.
- 2,377
- 349
Pardon me for stepping in late but I would make the following observations on this problem. The potential for a spherically symmetric charge distribution will be [itex]V=\frac{kQ}{r}[/itex] for Q the charge within the sphere of radius r, but only for a particular choice of gauge. The more general formula is [itex]V=\frac{kQ}{r}+G[/itex] for G a gauge constant. Usually G=0 so that the potential at r=infinity is zero but you can set it to any value since it is only potential differences that matter. In this problem, you do not want the potential to change within the conductors and you want the potential of the grounded conductor to be zero.
Working in an arbitrary gauge can allow you to solve the problem a bit more easily.
Clearly the E field inside A is 0. The potential inside (and at) A is subject to our choice of gauge.
If q is the charge on A, the potential between A and B is [itex]\frac{kq}{r} + G[/itex] with [itex]\frac{kq}{a} + G = V_A[/itex] and [itex]\frac{kq}{2a}+G = V_B[/itex].
Since B has no net charge the potential between B and C is again [itex]\frac{kq}{r} + G[/itex]. [Otherwise we might have to paste together distinct gauge conditions, different constants so potential is not discontinuous across a shell of charge density.]
This must at C give us [itex]V_C =\frac{ kq}{3a} + G[/itex], (lets say just as we reach the interior surface of C).
Using [itex]V_C=0[/itex] at ground to fix our gauge you get [itex]G = -\frac{kq}{3a}[/itex] and so [itex]V_B= \frac{kq}{2a}-\frac{kq}{3a} = \frac{kq}{6a}[/itex].
Note however that as we cross a shell of charge (inner or outer to one of the conductors) we will need to adjust the gauge. For example between inner and outer surface of B shell, there is zero charge interior to spherical shells, the potential there is however not 0/r +G. It is the same as at the inner surface and the outer surface of B. But in each of these three locations you have distinct interior charge.
gracy
- 2,486
- 83
That's what I wroteehild said:There is no charge on the outer surface of C
That is outer surface of shell has zero charge.gracy said:And charge -q which has been supplied by Earth is on outer surface of shell C to balance induced +q charge there ,
gracy
- 2,486
- 83
##V##=##\frac{Kq}{4a}##?SammyS said:) What is the potential at a distance 4a from the origin due to the charge -q ?
##V##=##\frac{Kq}{3a}##SammyS said:What is the potential at a distance 3a from the origin due to the charge -q ?
Homework Helper
- 15,536
- 1,917
You are right, but Gracy wants to solve the problem with the Superposition principle, that is to get the potential as the sum of a single charged shells, A of radius a and charge q, and the other single single shell C of radius 3a and charge -q.jambaugh said:Pardon me for stepping in late but I would make the following observations on this problem. The potential for a spherically symmetric charge distribution will be [itex]V=\frac{kQ}{r}[/itex] for Q the charge within the sphere of radius r, but only for a particular choice of gauge.
Capacitance of three concentric shells
- Kashmir
- · Replies 3 ·
- Introductory Physics Homework Help
- Replies
- 3
Potential in case of concentric shells program
- gracy
- · Replies 7 ·
- Replies
- 7
Electrostatic energy of concentric shells
- Data Base Erased
- · Replies 11 ·
- Replies
- 11
Potential energy in concentric shells
- gracy
- · Replies 64 ·
- Replies
- 64
What happens when one of two concentric spherical shells is grounded?
- Davidllerenav
- · Replies 11 ·
- Replies
- 11
Potential energy by concentric shells
- Buffu
- · Replies 1 ·
- Replies
- 1
Potential Difference b/w concentric shells -- confusion
- IonizingJai
- · Replies 4 ·
- Replies
- 4
Voltage, electric field and potential energy for concentric shells
- tinesi
- · Replies 3 ·
- Replies
- 3
Potential Difference between concentric shells
- zorro
- · Replies 4 ·
- Replies
- 4
How Does Charge Distribute Between Two Concentric Shells Connected by a Wire?
- Conductivity
- · Replies 2 ·
- Replies
- 2
