Potential of infinite sheet with thickness
The discussion focuses on calculating the electric potential inside and outside an infinite insulating sheet with uniform density ρ and thickness d. The electric field inside the sheet is defined as E = ρx/ε₀, leading to the potential V_f = -ρx²/(2ε₀) for x < d/2. For the region outside the sheet (x > d/2), the electric field is E = ρd/(2ε₀), and the potential can be derived using Gauss's Law, confirming the expression V_f = -∫(E ds) from both regions. The participant seeks validation for their approach to finding the potential outside the sheet.
  • Understanding of electric fields and potentials in electrostatics
  • Familiarity with Gauss's Law and its application
  • Knowledge of calculus for evaluating integrals
  • Concept of uniform charge density in electrostatics
  • Study the derivation of electric fields using Gauss's Law in different geometries
  • Learn about potential energy in electrostatic systems
  • Explore the concept of electric field lines and their relationship to potential
  • Investigate the effects of varying charge densities on electric fields and potentials
Students and professionals in physics, particularly those focusing on electrostatics, electrical engineers, and anyone involved in theoretical physics or electrical field analysis.
susdu
Describe the potential inside and outside an infinite insulating sheet with uniform density ρ and thickness d, as a function of x (distance from the center of the sheet). zero potential has been set at its center. What is the potential on the surface of the sheet?
Potential and E.field definitions.
I know that inside the sheet (x&lt;\frac{d}{2}) the field is given by
E=\frac{ρx}{ε_0}.
so, potential inside the sheet (with ##V_i=0## at ## x=0##) is:
##V_f=-\int^x_0 E\,ds=-\frac{ρx^2}{ε_0}##
similarly, outside the sheet (x&gt;\frac{d}{2}) field is
E=\frac{ρd}{ε_0}.
however, I'm not sure about the expression for outside the sheet, is it
##V_f=-\int^\frac{d}{2}_0 E\,ds-\int^x_\frac{d}{2} E\,ds##
I would use the Gauss Law. Let's consider a cylindrical surface with it's axis perpendicular to the sheet that "sticks out" of the sheet equally. Gauss Law states, that:
\epsilon _0 E \int ds = Q
And Q=density of charge x volume.
From symmetry we know that there's no flux through the curved surface of the cyllinder, so we have flux only through bases of the cyllinder:
\epsilon _0 E 2\pi R^2 = \rho \pi R^2 d
So E=\frac{\rho d}{2\epsilon _0}
And E is constant everywhere outside the sheet.
I already know the expressions for E.field outside/inside the sheet.
I need an expression for potential.
susdu said:
##V_f=-\int^\frac{d}{2}_0 E\,ds-\int^x_\frac{d}{2} E\,ds##?
Looks right to me.
